Old 11-10-2012, 02:34 AM   #1
Default FS12 Nitro engine wont start ?
Hey I have a nitro road car with a fs12 sw engine in it with a tamiya chassis and i cant get the car to start ! The only way it will start is if i pull the glow plug out and put fuel down the carby then it will start first time and run for a few seconds, Would anyone be able to help me ? Thankyou!
Sambo 7 is offline   Reply With Quote
Old 11-10-2012, 03:48 AM   #2
blis's Avatar
Then fuel isnt being supplied via carby..
Check fuel take for leaks, fuel lines, perhaps HSN needle is too lean, blocked or closed. Check fuel pressure line. Check idle gap = approx 1mm
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Old 11-10-2012, 01:58 PM   #3
Cool
Thankyou ill try that let you know
Old 11-10-2012, 02:02 PM   #4
Ok so the idle gap is about 2mm and ive been trying to change it by screwing the "idle screw" nothing happens? what can i do ? Thanks
Old 11-10-2012, 03:49 PM   #5
Geezatec's Avatar
If you have a duel rate wheel on your TX turn it down. It changes the throw on the throttle servo.
Geezatec is offline   Reply With Quote
Old 11-10-2012, 04:02 PM   #6
Thankyou but whats a duel rate wheel on your TX im only new to these cars
Old 11-10-2012, 04:17 PM   #7
blis's Avatar
It's not recommended, but you can disconnect the pressure line from the exhaust pipe, and blow into it and see if fuel is getting into your carby, you should hear it.
As for the idle gap not changing. It should get bigger, if it doesnt, carby may be seized or the screw has slipped out from the slider? If it wont close, it can be the servo and throttle connection preventing it closing. Hence the boys asking your about the rate on your transmitter
Old 11-10-2012, 04:24 PM   #8
The fuels flowing through the carby no the screw hasent come out.... and the connections seem to be fine.. maybe i should go buy a new carby ? thankyou
Old 11-10-2012, 05:03 PM   #9
blis's Avatar
I re-read it again.
By taking the glow plug out you may have un-flooded the engine. Which means there's too much idle and or the bottom mixture screw is too open allowing too much fuel in the mixture.
brb
http://www.rctech.net/forum/10423342-post10.html
So when you remove the plug and turn it over does the cylinder produce a spray or mist?
Old 11-10-2012, 05:10 PM   #10
Yes when the glow plug is out and i pull the starter a mist comes out ?
Old 11-10-2012, 05:20 PM   #11
blis's Avatar
Then you have fuel...
Best thing to do is disconnect the throttle linkage. Put a rubber band across the throttle and a fixed point on the car to keep it closed. Do the 1mm Idle gap and get it to fire first.. as in my link above.
I'd say too much idle open, check throttle linkage, radio throttle trim / sub-trim too.
LAST thing you want is for it to start and scream it's head off with too much idle, and use the rubber band ok!
ALSO, if it's a barrel carby, the idle screw sits in a slot, if that has twisted or slipped, might be worth taking a closer look at it.
Old 11-10-2012, 07:03 PM   #12
Geezatec's Avatar
Misquoted Duel rate wheel. Throttle Trim on your TX, It'll close your air gap to .5 to 1mm. If idle screw doesnt make a differance. Turning idle screw should be turned CCW to lower idle speed and close throotle air gap.
Old 11-10-2012, 07:14 PM   #13
Ok thankyou
Old 11-10-2012, 08:09 PM   #14
Still no go
Old 11-10-2012, 09:38 PM   #15
blis's Avatar
Does it accelerate to a stop when you do this? Or does the engine stall ?
