Old 10-25-2012, 07:53 AM   #1
Default Nitro tc3/ jlr red dot evo3 help
Hey guys, I bought a used ntc3 for really cheap, came with a slow Rb.12 engine, I want to put my jlr evo 3 red dot in the car it fits got the right collet but now my flange bearing doesn't fit the SG shaft- what flange bearing size should I get ?? Or what are my other options ?
Hpi R40 Hara w/ .12JLR
Hpi R40-rolling frame
Tamyia F103 LM -Ole school
soon a 1/8th on road
Duratrax Maximum ST Pro
Hpimichael is offline   Reply With Quote
Old 10-25-2012, 10:09 PM   #2
Undies's Avatar
Yep... other options would be to get a newer car that has parts support and people can assist with setup help.
Or if you really want to persist with the Nitro TC3 get a different rear exhaust motor (Not Picco based) like an OS or a Novarossi.
A Main Hobbies have a Novarossi 353 at a good price at the moment, or get a OS from Tower hobbies.
Undies is offline   Reply With Quote
Old 10-25-2012, 10:32 PM   #3
azeroth's Avatar
Trader Rating: 20 (100%+)
the ntc clutch does not fit the sg shaft ae had you cut the shaft and use there adapter nut but i believe vbx had a bearing to fit
Nitro is for Racing!!!!!!!!!!!!!!!!!!!!!!!!!
YA SMELL WATTs I BE STEPPIN IN????
Yes I race a Snake, VP, Radiopost,Protek,EDS,Matrix
Team Nitro RC Club Lynwood, IL
azeroth is offline   Reply With Quote
Old 10-25-2012, 10:47 PM   #4
Suspended
Smile
Once you have the right ofna collet, everything else fits with shimming....
bertrandsv87 is offline   Reply With Quote
Old 10-26-2012, 09:16 AM   #5
i just dont want to buy an new engine, my red dot was briefly used and has been stored for the past few months. i have the ofna collet and the shim kit but the flange bearing inside diameter is to small to fit over the SG shaft.
Old 10-26-2012, 07:50 PM   #6
i used to run an sg shaft engine (rossi pixi black) in my nitro tc3. ill see if i can dig up what i used for bearings.
Sharkey_t is offline   Reply With Quote
Old 10-27-2012, 12:06 AM   #7
the bearings for the tc3 clutch bell should be 5x10 unflanged, 5x9 flanged. all sg cranks are the same dimension.
Old 10-27-2012, 06:39 AM   #8
Okay sweet thanks so much I guess the previous owner just through what ever on the car,
Old 10-27-2012, 05:20 PM   #9
Suspended
Cool
Bearings not fitting is new to me ! All my clutch Bearings seem to fit nicely in my jlr . 12 tuned... Good luck with it,, but I think a new clutch bearing kit might do the trick......
Old 10-27-2012, 05:37 PM   #10
I'm getting the clutch bearing kit - ingot a hold a the guy who owned it before he got a bearing that just fit in the clutch bell and shimmed it about would work- rookies- do it right the first time ugh, now it's done right thanks guys
Old 11-28-2012, 12:22 AM   #11
Thumbs up Re...Ntcs
Is the Associated NTC3 still available new????
THEBIGBULL is offline   Reply With Quote
Old 11-28-2012, 07:58 PM   #12
i think you can still buy the rtr version, but i havent seen the factory team version listed anywhere for a while.
