Old 04-01-2005, 08:44 AM   #16
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Hi guys,
Im on a truble here, i need to lubricate my ball bearings and thrust bearings of the Centax and i dont have access to special thrust bearing grease ...
Now, i have oil bearing for the ball bearings, and here in Chile i dont have access to buy "right now" special thrust bearing grease ... i visited a hardware store and the alternatives that the guy gave me after my "RC orientation explanation" are :
- Medium-Thick black grease for ball bearings (thats the name of the product, oriented to grease bike bearings).
- 3-in-1 thick oil lubricant for bearings (i found that you in USA have this product http://www.wd40.com/Brands/3in1.cfm)
So ... can use any of that products for my thrust bearing (and maybe for the all around ball bearings too cause im a little short of the kyosho lube i always use) ...
Thanks in advance ...
Pat
Patricio "PATO" Concha
E-Mail : [email protected]
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 04-01-2005, 09:52 AM   #17
HELLION's Avatar
Default No Worries!
Originally posted by Tabushi
Hi guys,
Pat
See if they have assembly lube? white (not the spray) If not real car wheel bearing grease will work .It's a little thick but it's high temp. There are many types you can use Just make sure you grease it offten and check the free play WD 40 is good stuff but way to thin for thrust bearings It's more of a oil then grease
HELLION is offline   Reply With Quote
Old 04-01-2005, 07:10 PM   #18
nitrodude's Avatar
If you have acces to Team Associated parts, you can use their black grease. They use this grease for the trust bearing on their ball diffs. I use this grease on the centax and never had problems.
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
RADIO GEAR ADJUSTMENT PROBLEM JR XS3 aussies1 Electric Off-Road 4 11-30-2006 01:23 AM
2 centax adjustment questions. sstupid Nitro On-Road 1 01-24-2006 07:18 AM
what adjustment? peahbeez Electric Off-Road 2 05-08-2005 04:16 PM
TL-01 adjustment robborc Electric On-Road 3 02-15-2005 08:03 PM
Centax clutch adjustment or Engine Needing Tuning? DOMOisCOOL Nitro On-Road 19 04-28-2004 12:12 AM
