Aluminium bulkheads vs Plastic
All the new cars.. the Serpent, Shepherd, Capricorn have gone with aluminium bulk heads instead of plastic, Xray have stuck with the plastic ones on the NT1.
What's the advantage/disadvantage of both? |
Originally Posted by JamesHealey
(Post 11313664)
brake meltdown
I've seen several racers get away from the plastic housings because their 'braking habits' caused the metal parts to become embedded into the plastic. It's not pretty when it takes you out of contention. There are other 'tweaks' you can do to space out the 'hot parts' but aluminum housing replacements are the logical 'manufacturer' action.......sounds like the builders are getting practical input. :cool:
Originally Posted by nitrodude
(Post 11313950)
Once its all put together its a much stronger assembly, allowing the suspension to do its work better. Plus the fact that with todays technology its cheaper to machine the parts out of bar stock than to make a plastic injection mold.
Bad thing of aluminium parts is that it will bend causing tweak. I have seen people changing the aluminium bulkheads several times.. I am not sure if it is cheaper... Making a good mold for plastics is indeed expensive but milling a complex 3D item as the Serpent gear shaft blocks does also cost some material and machine time. The more simple designs from Shepherd an Mugen can be directly milled or cutted from a plate of aluminium. The only difference between plastics and aluminium is that with aluminium it is much easier to make direct changes or create some different models to test with. On the other hand current 3D platic printers can do the same with plastics |
The aluminum bulkheads are worse than the plastic because you can get alot of problems with bent bulkheads at least with plastic there good or there broke and it's less work with plastic because when you have wreck were you break an arm you should tear the car down to the bulkheads to check and see if it's bent
I feel like the plastic is better because of what one of the other guys mentioned. tweak! you have to watch for it with aluminum bulkheads, even though i have yet to have this issue. I sure love the look of that aluminum on my MTX5!
I prefer plastic as its easier to keep screws in and less likely to suffer from heat transfer.
Originally Posted by Roelof
(Post 11314183)
Funny, if it is made stiffer for a better work of the suspension why have all curent cars a complete flex system?
Bad thing of aluminium parts is that it will bend causing tweak. I have seen people changing the aluminium bulkheads several times.. |
Hm
I like the plastic because it's just so much cheaper. I think I'm paying six bucks a set and only replaced one bulkhead all year anyways. I can't speak to the aluminum because I don't have it, but then again, I'm only paying 300 for the whole kit. I'd probably try aluminum were it offered on my car, just so I'd know for myself if there is any kind of difference, but I'm not unhappy with how it is now.
Thinking about it more, i think if Xray saw it as necessary they would have gone that way with the RX8 seeing it was released aot later then the NT1.
(Post 11314183)
Bad thing of aluminium parts is that it will bend causing tweak. I have seen people changing the aluminium bulkheads several times.. I am not sure if it is cheaper... Making a good mold for plastics is indeed expensive but milling a complex 3D item as the Serpent gear shaft blocks does also cost some material and machine time. The more simple designs from Shepherd an Mugen can be directly milled or cutted from a plate of aluminium. The only difference between plastics and aluminium is that with aluminium it is much easier to make direct changes or create some different models to test with. On the other hand current 3D platic printers can do the same with plastics With cars these days going to mostly aluminum and carbon, it allows the companies to pass material AND machining costs to the consumer. The investment into the CNC machine will get you a lot further than a plastic mold. The CNC machine can be programmed to machine anything. Cycle times maybe a bit longer than a plastic part, but you can just pass that cost to the consumer. You don't have to worry about the material quality except for ensuring its the correct grade. Design change? No problem, just load the new machine path into the CNC and you're off making new design parts. Need the volume of parts that you can easily get from injection molding? No problem, farm all the CNC work to China where they have factories filled with CNC's. 3D printers are amazing, but I believe they are still too expensive for mass producing parts. They are very useful for creating complex prototype parts used for testing, but those parts usually turn into injection molded parts. |
So the general jist is plastic is superior if the design is right first time, but it's more expensive to toolup for and very expensive to change designs.
Aluminium is easier to prototype and cheaper to tool up for the manufacturer but ends up costing more for me. The rigidity issue is moot for me, the NT1 generates traction fine as does the 747. But I can replace my bulkheads cheaper on the NT1. |
Although Xray has stated in their column about the RX8 they do believe plastic is the way it would not supprise me that a next generation cars will get aluminium too. Until that time I think they will have some extra market with users who fear aluminium.
I've only had one aluminum part get bent on the Shepherd 1/8th, the rear suspension front lower pin mount. It was easy to notice that it was bent because the hinge pin didn't line up any more. And it was not expensive to replace, it's only like $12 or something. I have never had or seen a bulkhead get bent.
(Post 11319771)
