Old 10-06-2012, 07:39 PM   #1
1evo RRR Driver's Avatar
Send a message via AIM to 1evo RRR Driver
Default TIRE SHORE QUESTION??
Fellas quick question, can someone who really knows foam tires please answer this for me, why is it that most of if not all of my fellow racers like 32/35 and i try it but always seem to go back to 32/40 or 35/40?? 40rears always seem to have more forward bite n just as much side bite........it feels like on hot days 35 and 37 rears have more wheel spin expert please chime in...........thanks
"He's CHEATIN! cause Im CHEATIN! and He beat ME!" :) "TKI4 PILOT" /XRAY NT1 16' /FUSION X3LCFM / M2c / PROTEK / FUTABA 4PX / SAMURAI
1evo RRR Driver is offline   Reply With Quote
Old 10-06-2012, 07:47 PM   #2
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
One factor could be to even out tire wear as you know how the rears wear faster than the fronts on the sedans. I myself don't like that soft a shore on the front. I opt for 37- 40 fronts. And 40-42 rears
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 10-06-2012, 08:20 PM   #3
So see your like me, not only do u get better tire wear, but just as much performance in warm weather, i think the softer shore would prob excel in cooler weather, i could b wrong tho......
Old 10-06-2012, 08:45 PM   #4
They do give more initial traction but in the heat my seem mushy and at the risk of wear as well I rather make the harder tire work
Old 10-06-2012, 09:15 PM   #5
Exactly, thanks i thought i was doing something wrong cause I'm the only one that still likes 40's cap co1 seems to love em.......
Old 10-06-2012, 10:54 PM   #6
lil-bump's Avatar
Trader Rating: 83 (100%+)
I'm with you. When my club members run 35/40 I find that 38/42 is better for me.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 10-06-2012, 11:21 PM   #7
Pass you soon...
Ok cool so it seems different setups/driving styles prefer harder tires......
Old 10-07-2012, 04:29 PM   #8
Location: Beneath a rock down by the river. Don't have money for van
Tire temperature,if you overheat 32/35 then they don't make you faster than 40/42.
( ͡ ͜ʖ ͡) https://www.facebook.com/becomeasetupguru/
30Tooth is offline   Reply With Quote
Old 10-08-2012, 10:28 PM   #9
hitcharide1's Avatar
Send a message via Yahoo to hitcharide1
Default Well
For what it's worth, I've been running 45 front 40 rear most of the year and haven't had a traction problem yet. Plus I don't have to true tires since the wear is so even from front to back. Go figure...I don't know if anyone else is doing this but it works for me, I'm using very little foam and have no complaints.
hitcharide1 is offline   Reply With Quote
Old 10-08-2012, 10:47 PM   #10
ive always run the same. way back when i was learning to race other racers always said start with a 40 rear and run 1 range higher on the front. if you need more traction drop down a range both front and rear. ive always been doing that, almost always run 45 front 40 rear, always had more grip than i knew what to do with.
Sharkey_t is offline   Reply With Quote
Old 10-09-2012, 03:45 AM   #11
djiewie's Avatar
i run 32/37 leftside and 35/42 rightside on the car on a anticlockwise driving cirquit with long high speed sweepers. Useless info though for anyone without the setupsheet.
djiewie is offline   Reply With Quote
Old 10-18-2012, 02:54 PM   #12
A lot of times during the warm/hot summer time, tracks will get loose and drivers will normally go to softer shores believing that they will pick up more traction. However the reverse will happen. The reason is the softer tires like 32/35 shores have wider pore patterns and pick up more of the oils and track dust and this makes your car loose. Harder tires like 37, 40, and 42 shores have a closer/smaller pore pattern and they then don't pick up the oils and therefore have better grip.
By testing like you have been doing is the best way to select the shore you and your car needs. Good job guys!
TM America is offline   Reply With Quote
Old 10-18-2012, 07:40 PM   #13
Thanks I'll tell my buddies that i was right, after i beat them
Old 10-18-2012, 09:45 PM   #14
Scott B's Avatar
Trader Rating: 43 (100%+)
Haha, you got to show up to the track and race if you want to beat anyone... Lol.
Mugen Racing USA, Sweep Racing Tires, R1 Wurks, Protoform, Speedworld Raceway...
"On-road is racing.. off-road is 50% competitive jumping and 50% crash avoidance"...
Scott B is offline   Reply With Quote
Old 10-18-2012, 10:20 PM   #15
Damn busted........u the only one that reads these forums besides me!!! Lol tire shore won't make me beat you.......need a little more help than that......
World GT Club Racing - To spec or not to spec is the question???? Mr. McGoo Electric On-Road 722 11-01-2014 07:05 AM
JACO tire news Jack Rimer Electric On-Road 609 03-10-2007 11:33 PM
