Old 03-20-2005, 07:10 PM   #1
Default A Couple of Questions
I'm new to NTC and have a couple of questions.
1. When building the diffs would you recommend using some silicone on the gasket or do these seal well if installed dry. (I have a MTX-3)
2. Their manual does'nt say anything about lubing the front one way bearings but I'm assuming these should get a coat of grease - correct?
Thanks for your help.
Lano is offline   Reply With Quote
Old 03-20-2005, 07:40 PM   #2
drfritz's Avatar
Default Re: A Couple of Questions
thin coat of is all you need, let it skin up before you put the diffs togather.
get your self some one way oil, a few drops is all you need to use, any more you run into a slipping problem, same thing goes for the oneway on the two speed.
drfritz is offline   Reply With Quote
Old 03-21-2005, 07:27 AM   #3
thanks, appreciate the help
Couple Questions racer12306 Monster Trucks 4 03-05-2008 07:41 PM
Couple ESC questions oMONSTERo Electric Off-Road 6 09-11-2006 10:51 PM
A couple of quick questions...... TXstreetracer Rookie Zone 6 07-08-2005 08:05 PM
