Old 10-03-2012, 11:32 AM   #1
Default Serpent Excel and new tires... how?
I'm have old serpent excel mk2. What do I need to change in order to put the wheels of the new model?
Sorry for my very bad english, i am from Ukraine.
vadim_cdma is offline   Reply With Quote
Old 10-30-2012, 07:51 AM   #2
Joe Kimble's Avatar
Send a message via Skype™ to Joe Kimble
Hi!
So I believe that your problem is that you cannot "lock" the wheel on the axle because the wheel is too large. Yes?
Here is a solution:
You can dremel the inside of the tip of the quick change aluminum bit until you can "lock" the wheel. I did that with my 950 and it worked for me. But you have to be careful and do it little by little until the fit is perfect and be careful not to break the bit.
Serpent America
Sweep USA
RCShox
Joe Kimble is offline   Reply With Quote
Old 10-30-2012, 07:52 AM   #3
Joe Kimble's Avatar
Let us know if you managed to do it.
Serpent America
Sweep USA
RCShox
Old 10-30-2012, 08:32 AM   #4
Roelof's Avatar
Send a message via ICQ to Roelof
The Excel has a hex adapter to hold the rim. You can try to remove the hex part and see if a new stye rim will fit.
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 10-30-2012, 08:45 AM   #5
Joe Kimble's Avatar
Thanks for the precision Roelof. If I'm not mistaken the hex adaptor system was replaced by the quick change system at some point.
Yes of course if you have the hex system you might want to get the quick change system then dremel the bit to the right size.
What system do you have?
Serpent America
Sweep USA
RCShox
Old 11-01-2012, 05:15 PM   #6
Wanabrc's Avatar
Trader Rating: 70 (100%+)
In order to swap wheels you must have your Excel and a 966 side by side. Start at the left rear of each car and start by swapping pieces one at a time such as the hub, axle, block etc. Don't stop untill you finish off at the right front. Then your wheel conversion will be ready for some new tires.
Wanabrc is offline   Reply With Quote
Old 01-14-2013, 11:29 PM   #7
Trader Rating: 29 (100%+)
Default buy new foam donuts ?
you could strip the old foam's off the rim's, purchase foam donut's and remount them to your old rim's....
Teamgimpy72 is offline   Reply With Quote
Off roader thread Danny Teh Malaysian R/C Racers 6647 04-07-2015 03:57 AM
Serpent 720 rcrossco_1 Nitro On-Road 5073 04-16-2012 09:42 PM
Mugen MTX-2 tekrsq Nitro On-Road 2839 10-15-2006 09:09 PM
