Old 03-16-2005, 02:31 PM   #31
dct147's Avatar
Thanks for your help Giddyup,
It did give a sound as if it`s gonna start twice.
But after that, back at square 1 again.
The engine`s feeling warm. is that a sign that the glow starter`s working?
Thanks for your help.
dct147 is offline   Reply With Quote
Old 03-16-2005, 02:50 PM   #32
AndyT 's Avatar
I had one of those battery operated ignitors as a back-up, and found it needed an Energizer/Duracell type battery for it to give sufficient current to get the plug hot......if i tried a "standard" battery in it, it couldnt start the engine.
AndyT  is offline   Reply With Quote
Old 03-16-2005, 02:52 PM   #33
dct147's Avatar
Thanks once again AndyT,
I`m using Energizer battery.
If the engine`s feeling warm from the outside, does that mean the glow starter`s working? is there a way i can check? because, nothing`s glowing at all.
Old 03-16-2005, 03:25 PM   #34
Did you prime the fuel, try turning the throttle adjuster up more you will here the servo move and the carby will open a bit. It may be still flooded. When the glow plug is out put it in you glow starter it should glow red.
giddyup is offline   Reply With Quote
Old 03-16-2005, 10:19 PM   #35
dct147's Avatar
The glow plug doesn`t red up when i put it in the glow starter. it heats up, but doesn`t red up. Is that a sign that it isn`t working?
Old 03-16-2005, 10:46 PM   #36
When you put it in it should glow red instantly
Old 03-16-2005, 10:58 PM   #37
dct147's Avatar
Damn, that means it`s not working.
Crap. it`s a brand new car.
Hope to get it changed for free.
Old 03-16-2005, 11:20 PM   #38
I've had my FW05T for 6 weeks and still on the original.
Old 03-17-2005, 07:05 AM   #39
dct147's Avatar
Thanks alot guys,
My car`s finally running. I`ve always thought it has a reverse gear. mine doesn`t that`s normal?
But anyway, thanks for all your help
Cheers guys!!
Old 03-17-2005, 07:00 PM   #40
AndyT 's Avatar
Nope no reverse gear that i know of
Old 03-17-2005, 11:02 PM   #41
dct147's Avatar
Alright!
Thanks for your help .
Cheers all!!
@@@@@@@@ Kyosho FW05 RTR @@@@@@ war11x Australia For Sale/Trade 8 05-13-2008 03:24 PM
Centax for a FW05 deceiver Nitro On-Road 3 10-22-2006 03:04 PM
fw05 V1RRRRR Australia Wanted to Buy 5 07-23-2006 06:58 PM
Kyosho Fw05 R robertr R/C Items: Wanted to Buy 0 08-08-2005 02:39 PM
fw05 graham1234 Nitro On-Road 2 07-19-2004 06:03 AM
