Old 07-04-2007, 03:46 AM   #8731
Corse-R's Avatar
Originally Posted by wallyedmonds View Post
try 2 shoes with weights
super hard spring,nut at .9 to 1mm
gray pad
the msr spring is for 1/8 i think and in 1/10 makes the clutch slip to much or i found it did.
the yellow pad dose grab sooner though,its all in what you want the clutch to do.
keep playing with it.
I'm not such a friend of doing those things of removing weights (May cause instability on the pressure plate and not going completely straight and spit one of the weights). Instead of this I've tested further lightening enlarging the holes they have up to 4mm each one. Much better solution.
I don't know how much stiff is the MSR spring, but the extra hard from Mugen (H0774 if I'm not wrong) is the way to go. Doesn't need so much tension to give nice results.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 07-04-2007, 04:14 AM   #8732
wallyedmonds's Avatar
2 shoe with weights in the holes,this works very well
4 shoe and make the holes bigger works well too
you just got to play with it to see what works for you and the track you run at,i do both of these
wallyedmonds is offline   Reply With Quote
Old 07-04-2007, 04:51 PM   #8733
Seisick's Avatar
FYI part H0774 IS THE SAME AS THE MSR SPRINGS, ITīS JUST THAT IN THE
US SOME PARTS ARE SOLD USING THE MSR CODE, SUCH AS THE ULTRA HARD SPRING, WORKS GREAT BY THE WAY
Seisick is offline   Reply With Quote
Old 07-04-2007, 06:36 PM   #8734
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
The H0774 spring is a different color than the MSR spring.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 07-18-2007, 07:57 PM   #8735
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Hey guys what's new? Been a while as I been just working and enjoying my days off at the apt focusing on other needed items. Any news on some updates for the car? I been thinking since I don't use my 8th as much I'll toss the JR servo into the MTX4 for steering and the current steering servo in the sedan for throttle. The Q is how much more of a drain will I notice using two powerful servos. Both are digital btw. I have a 1400NIMH Rx and a 1200NIMH rx pack.
HarKonnenD is offline   Reply With Quote
Old 07-18-2007, 10:54 PM   #8736
JetMD's Avatar
I run 2 digital hi-tech servos in mine (with a personal tranponder) and i'm using a 1200mah batt. I've run all day many times on one charge without worries. As long as the battery is good, you'll have no problem.
www.vorra.org
MINO Racing
JetMD is offline   Reply With Quote
Old 07-18-2007, 10:59 PM   #8737
gentleman81's Avatar
what u know about batteries
MTX4R/PICCO(Trophy Taker) - SERP 950/SIRIO(Board Breaker)
PHI '08 - to be announced.....
www.vorra.org - ironbridgesportspark.com - 301raceway*4LIFE*.com
gentleman81 is offline   Reply With Quote
Old 07-18-2007, 11:01 PM   #8738
Default mtx4 rear arms
arent the lower arms the same as the mtx3
Old 07-19-2007, 01:42 AM   #8739
JetMD's Avatar
The R has different lower arms than the stock 4 (the 3 is different than both of them). The R arms have a cut-out so the steering screw on the upright will clear it. (the uprights are different too). I put the R set-up on my stock 4 and I love it. Works very well for all tracks.
Only problem is, the cut-out is a weak point. Instead of breaking uprights (like we usually do Gent), you'll break the new lower arm. So, if you decide to upgrade, get more lower arms than uprights. Just my opinion...
www.vorra.org
MINO Racing
Old 07-19-2007, 04:07 AM   #8740
theres also the 2š upright.that works very nice.
Old 07-19-2007, 05:27 AM   #8741
JetMD's Avatar
Yup, that's what i'm talking about. The track Gent and I race on has low grip and I actually had to take away steering (less caster) because it would turn in so well that it would pull the back end around. After I did that, the car was hooked up! If I can get my motor tuned right, better watch out, that's all i'm sayin.
www.vorra.org
MINO Racing
Old 07-19-2007, 06:38 AM   #8742
va_connoisseur's Avatar
Send a message via Yahoo to va_connoisseur
Hey Jet, I am breaking in my engine now. I did not realize the arms for the 4 were different then the 4R (which I have). When are you guys racing at VORRA again? I will be through Richmond this weekend so if the track is set up I will swing by. I need to get some pic of your races as well.
va_connoisseur is offline   Reply With Quote
Old 07-19-2007, 07:46 PM   #8743
JetMD's Avatar
Sorry, no race this weekend. We race 1st and 3rd sundays. We do have a race on the 29th though to make up for a race that got washed out.
Some other time then, and bring your car! The stock set-up on the 4R works well on our track (minus a little caster ) and you'd do fine with that RB motor of yours. I'd like to see it run anyway. The tires we run are 37's or 38's.
www.vorra.org (has our schedule)
www.vorra.org
MINO Racing
Old 07-19-2007, 09:01 PM   #8744
my bad, i meant the lower rear arms.
Old 07-20-2007, 07:32 AM   #8745
Seems like a lot of people want to see that thing run. I will be up at 301 later Sunday evening, may finish the break in there.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
