Old 05-30-2007, 04:25 AM   #8551
rmdhawaii's Avatar
Originally Posted by LogiK
dont have one
Check the "For Sale" thread here at RCTech. Also, you don't have to buy the most expensive one, just one that gets the job done. If you're serious about your racing, it's a good investment.
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 05-30-2007, 04:50 AM   #8552
Dynamite's Avatar
Send a message via MSN to Dynamite
hey guys, just got a q about the mtx4r.
the description of the kit at mugen says it comes with a one-way... its not a multi one-way/locker(solid) by putting a pin into it is it? it just looks similar to my xray multi in my T2 with the o-ring cover in the middle thats all...
www.racingfactory.org
Kyosho RRR Evo | Sirio Evo III STI | Ko Radio
Dynamite is offline   Reply With Quote
Old 05-30-2007, 04:56 AM   #8553
It is a multi. you just put the pins in to lock it
Capricorn LAB C03
Novarossi
Hipex
Delta9 is offline   Reply With Quote
Old 05-30-2007, 05:11 AM   #8554
Dynamite's Avatar
cool, sounds like i might have to add one of these kits to my collection soon
just to add, the only thing i dont like about the mtx4 is the room in the engine area.... but everything else seems like ticks... like screw on ball cups etc
Old 06-02-2007, 12:44 AM   #8555
asw7576's Avatar
How to remove engine in MTX4 easily :
1. Flip the belt tensioner, so it doesn't block the engine anymore.
2. Increase the height of engine bay's stiffener ( the bar or stiffener that connects upper deck to rear bulkhead ). Increase the height by using thick plastic shim, so you can slide out the flywheel later on.
Now, the removal process :
Unscrews 2 parts : the engine block ( 4 screws on the bottom of chassis ) and rear side belt pulley ( pulley behind manifold ). Slide the engine out. Flywheel will hit the brake disc, but it willl slide out...... just wiggle it.
Old 06-02-2007, 09:14 AM   #8556
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to rcfoolz
you can use a sanding drum to remove some material from the bottom of the brace above the flywheel and also to make it easier to remvoe the clutch bell, use a sanding drum to remove some aluminum right in front of the clutch bell area so that you can slide the bell off to make adjustments to the clutch spring without having to remove the engine.
rcfoolz is offline   Reply With Quote
Old 06-02-2007, 03:05 PM   #8557
JetMD's Avatar
I flipped the tensioner over and have noticed that no matter how you position the exhaust manifold, the outside of the side belt rubs on it a little. I think that was why they had the tensioner where it was originally. Anyone have any ideas on how to remedy this?
JetMD is offline   Reply With Quote
Old 06-02-2007, 04:09 PM   #8558
asw7576's Avatar
I hope you are using the rubber belt ( the longer one ), so you can push the belt tensioner to the lowest position.
Old 06-02-2007, 05:54 PM   #8559
ShrekNZ's Avatar
Noticed the same thing with a Ninja the belt rubs on the header. I filed mine a litte so there are no sharp but but it will still rub. To be quite honest the rubbing is not a problem and it's not on the power side (unless you have a spool).
One question I have about belt tension though is about adjusting the belt to run very close to each side will they touch what happens if they do?
ShrekNZ is offline   Reply With Quote
Old 06-02-2007, 06:37 PM   #8560
gentleman81's Avatar
how about mugen just fix it? theres a thought. i have to say, the fit of certain steering servos along with this tensionor issue gve me a bad tast about the car being rushed. that and how do u set the rear belt tension and be 100% sure that they wont shift when assembling the bulkhead ????
gentleman81 is offline   Reply With Quote
Old 06-02-2007, 08:38 PM   #8561
ShrekNZ's Avatar
Front and rear belt tensioners IMHO are great you want to try some of the electric ones where it's pure luck you get it right, it is much harder when the slot is in the bottom part of the bulkhead.
Old 06-02-2007, 08:51 PM   #8562
i wasnt asking how hard or easy it was, how do u get it right??? not being a twurp, just an honest question
MTX4R/PICCO(Trophy Taker) - SERP 950/SIRIO(Board Breaker)
PHI '08 - to be announced.....
www.vorra.org - ironbridgesportspark.com - 301raceway*4LIFE*.com
Old 06-03-2007, 02:47 AM   #8563
LogiK's Avatar
Trader Rating: 11 (92%+)
Hi,
First race today, was good fun..
Question, o-ring is shot in the tank, will the MRX-4 kit have one in it?
also, the ball cups on the turnbuckles at the rear?
Also im told I should stock;
All belts
Rear arms (both)
Front (uppers I think)
Both uprights
Bearings
and spurs and pinions/clutchbells.
Any help is appreciated .
LogiK is offline   Reply With Quote
Old 06-03-2007, 02:52 AM   #8564
asw7576's Avatar
Front & Rear eccentric belt tensioner : need extra patience to compare the notch ( on the eccentric ) to upper part ( shock tower unit ). It requires few test fit, a gap means not perfectly aligned, and need another comparison again....... No gap means perfect fit and you can screw the top.
If MTX4's eccentric tensioner sucks, MAYBE you can replace it with 12x18 bearings. ( This is what I do in my MRX4-R ....... soon in my MTX4 too ). Bigger bearing is better, especially for1/8 cars.
Old 06-03-2007, 03:04 AM   #8565
asw7576's Avatar
Originally Posted by LogiK View Post
Hi,
All belts
Rear arms (both)
Both uprights
Bearings
For rear uprights ball cups : see my pics... do you get the idea ?
Materials: longer screws ( 24 mm ), black ball cups from MTX3
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
