Old 05-27-2007, 09:29 AM   #8521
maskedrider's Avatar
Originally Posted by Sow&Steady
Did Philip Lee change cars? The listing on the FEMCA website says he drives the RRR?
Philip Lee from Team Hobby Bug Singapore drives Kyosho RRR
Kyosho- Sirio/ OS engine- AVID bearing- Blue thunder fuel- Proline- RC dynamite- Sanwa- RC Art
maskedrider is offline   Reply With Quote
Old 05-27-2007, 11:44 AM   #8522
cross wrench
Originally Posted by RC=Realy_Costly
hey guys,
i was reading through the mtx4 parts list to find the part number for the glow plug wrench and noticed two types were stated, a utility wrench and a cross wrench. which is the one you simply use to remove plugs with
Ghett0 is offline   Reply With Quote
Old 05-27-2007, 05:03 PM   #8523
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Originally Posted by Ghett0
cross wrench
I use the hot bodies glow plug wrench , also has the wheel wrench on it. Works really well. Costs litterally like 2.00
Artificial-I is offline   Reply With Quote
Old 05-27-2007, 05:13 PM   #8524
does it work for the locknut to secure the flywheel on the engine shaft, i think its like a size 10 or something
Old 05-27-2007, 06:11 PM   #8525
Moderator
Damn skippy. I forgot to add that...its the best one ive found.
Old 05-28-2007, 08:43 PM   #8526
dg8one's Avatar
i got the msr break pulley and the pins are coming out and melt my right bulkhead anybody run in to this problem
ohh i stripped my 2nd gear for the 2nd time since i got the car
Member of the CHEATERS CLUB
TEAM KAMIKAZE(MARYLAND CHAPTER)
TOKWA'T BABOY LTD
dg8one is offline   Reply With Quote
Old 05-28-2007, 09:14 PM   #8527
gentleman81's Avatar
4mm chassis suz
MTX4R/PICCO(Trophy Taker) - SERP 950/SIRIO(Board Breaker)
PHI '08 - to be announced.....
www.vorra.org - ironbridgesportspark.com - 301raceway*4LIFE*.com
gentleman81 is offline   Reply With Quote
Old 05-28-2007, 09:34 PM   #8528
dg8one's Avatar
i got my car the 1st time they came out since then this is the 2nd time i stripped a gear and i been runnin the 4mm actually my car rite now is consider the 4R since i have all the updated parts they come out w/
my problem is the pins from the brake pulley comin out
TOKWA'T BABOY LTD
Old 05-28-2007, 09:54 PM   #8529
i have the stock pulley, they are super close in weight, try it.
Old 05-29-2007, 12:03 AM   #8530
Corse-R's Avatar
Default Solution to 2nd gear stripping problem.
Weird. Change the brake pulley for a brand new, the one you have is faulty and the pins shouldn't be properly installed.
Regarding the 2nd gear stripping problem, get at least the 1st gear bell (I use the 3Racing, sourced from my MTX3 - never used the stock one and never stripped a 2nd gear).
The root of the problem seems to be a improperly oiled one-way bearing that locks itself when the 2nd gear is engaged locking the gearbox and stripping the 2nd gear.
When in doubt, change the two bells (1st and 2nd gear are quite cheap and you can get some lightened ones). The ones made by Eagle Racing (branded as 3Racing too) are really fine and hold a lot of use if the bearings is properly lubed - DON'T run it dry or the one-way bearing go south and lube them before using is the key for a long living one-way bearing and lack of problems on the gearbox.
Use one-way oil. What I'm using is one of the best I found: Serpent one-way oil. Check too for signs of wear on the main shaft. If you see shiny bands on the shaft this shaft is subjected to wear and needs to be revised or exchanged.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 05-29-2007, 12:08 AM   #8531
Nitro$junkie's Avatar
Send a message via MSN to Nitro$junkie
Kawaraha makes some nice lightend gear housings as well thats what i run never have striping prob's get two set's just in case you do strip a gear you got one ready to go
Futaba
Mugen
Novarossi
Byron's
http://www.hospitalrecords.com
Nitro$junkie is offline   Reply With Quote
Old 05-29-2007, 08:52 AM   #8532
Moderator
What kinda ride heights are you guys running? Also whats your camber and toe settings. Or heck feel free to post your entire setups. Im sure weve done this before but just feel like running over it again and comparing my car to yours currently.
Im also running the new rear camber link an new front uprights , not the 2 degrees from the mtx-4r. Also has anyone tried the 2 degree uprights vs the newer ones that came out a few weeks before?
Old 05-29-2007, 08:58 AM   #8533
This is the setup i use for a big open track
Futaba
Mugen
Novarossi
Byron's
Old 05-29-2007, 12:29 PM   #8534
StoneMan's Avatar
Has anyone adapted a center one-way for the MTX-4. Or, does anyone know of a manufacturer that provides one.
StoneMan is offline   Reply With Quote
Old 05-29-2007, 12:42 PM   #8535
5%
5%'s Avatar
Thanks, will try it this week
5% is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
