Old 05-24-2007, 11:54 AM   #8491
Good Luck asw7576, make the MTX4 guys proud!
Capricorn LAB C03
Novarossi
Hipex
Delta9 is offline   Reply With Quote
Old 05-24-2007, 01:28 PM   #8492
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Originally Posted by asw7576
FEMCA 2007
I need your blessing guys...... tommorow is my qualifying day
Good luck and have fun! BTW the drive to the track is long, but it takes me around an hr to get there. I definately will be lookin at an Impala and may get an 01 or 03 used and give mom my escort.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 05-24-2007, 09:22 PM   #8493
rizal_eg9's Avatar
FEMCA 2007
hey ASW....don't you think that your fuel line is too long with that fuel filter to pass the scrutineering???
rizal_eg9 is offline   Reply With Quote
Old 05-25-2007, 01:23 AM   #8494
jaykay's Avatar
Originally Posted by stefan
I have my second MTX4 now and I bought a healthy supply of spur gears when I read all this here in the beginning, when the car just came out.
Fact is, I still run my original spur gears on both cars and they have plenty of miles on them.
you´re not fast enough
I also haven´t had so much problems with the spure gears.
jaykay is offline   Reply With Quote
Old 05-25-2007, 04:42 AM   #8495
asw7576's Avatar
Don't worry ....... I already check it. Tank + Fuel line = 74cc.
The scrut teams are tough. They have all kind of tools to perform fair inspections. All cars must pass through inspection check before racing, and winners from the heat will be check again.
Old 05-25-2007, 04:52 AM   #8496
itchy b's Avatar
FEMCA 2007
Good luck ASW!!
Give "em a good show!!!
Do we shop at the same store?
Your bright fuel tube is the same colour as what i put on my car last night
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 05-25-2007, 04:54 AM   #8497
stefan's Avatar
Send a message via AIM to stefan
Look who's talking
stefan is offline   Reply With Quote
Old 05-25-2007, 12:08 PM   #8498
asw7576's Avatar
For those who still wandering about spur gears stripping syndrome. If you want...... Just read my spur gears and 2speed recipe in earlier post ( ..... if you want ).
Here is the fact : I DON'T change my spur gears and 2speed clutch during FEMCA 2007. Why so brave ? Because I have confidence they will work perfectly until I said so. Additional info: I haven't change anything since the last two races ( Last two races were 30 and 45 minutes finals ).
Of course, I always clean spray and oil the 1st gear one way before FEMCA, and always oil the clutch bearings every engine or centax rebuild.
I push my car & my brain very hard this time. In every corners, I close my eyes, make a wish, and apply full throttle at Apex point. Thanks to super grip condition, the grip is there. It's either the car flip or make it through that corner. .... So just blast it dude
In the past, my MTX3 will flip like a dolphin. MTX4 is just different animals
Old 05-25-2007, 12:14 PM   #8499
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Ok today put on a new motor. Adjusted the clutch differently. More towards swaugers settings. Its certainly got more rip down low.
One thing though the final screw is backing out and letting the cb come out too far. As well the clutch is just baking hot. Pretty much matching the temp of the motor.
I now see the clutch bell has rubbed against the 2 speed housing. What do you guys do to prevent this or was this just because the cb was backing out?
Artificial-I is offline   Reply With Quote
Old 05-25-2007, 12:37 PM   #8500
rmdhawaii's Avatar
I am glad to hear that you are doing well and that the car is working for you. I guess you made the right choice.
What tires are you running? In the photos of your car, it looks like Kawaharas. What shore?
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 05-25-2007, 12:46 PM   #8501
asw7576's Avatar
Originally Posted by Artificial-I
.......I now see the clutch bell has rubbed against the 2 speed housing. What do you guys do to prevent this or was this just because the cb was backing out?
In my car : I use bigger spurs and bigger pinions by 1 tooth. Bigger spur gears will slightly cancel out the effect of bigger pinions.
Centax clutch housing is very hot ? it's normal...... don't bother.
Instead, always listen to your engine sound when exiting a corner at full throttle, and observe how the car reacts to full throttle input. For examples:
(1). Very high pitch engine sound but with poor acceleration ( not snappy feeling ) means centax spring tension too stiff OR doughnut centax clutch shoe become thin OR centax clucth distance to clutch bell too far.
(2). Engine sound is singing like too rich ( feeling like super heavy car, unstable engine sound like too rich ) and you notice acceleration is lousy due to not enough high rpm, it means centax spring tension too soft OR centax clutch distance to clutch bell too close.
(3). The best clutch setup is very high pitch but the car can go ballistic ( better than snappy feeling ), and yet it still has some rpm to accelerate even more. That's is optimum power
Old 05-25-2007, 12:55 PM   #8502
asw7576's Avatar
It's Kawahara tyres with 37 shores ( morning ) and 40 shores ( afternoon onwards ).
So far so good.
Complete Heat 1,2,3.
Tommorow : Heat4, 1/32 final, 1/16 final. and 1/8 final.
Sunday : 1/4 final, semi final, main final.
I guest my level is 1/16 final ( not the car, it's the driver ).
Azri Amri from Team Malaysia will take MTX4 reign to the A Main Final guarantee
Old 05-25-2007, 01:00 PM   #8503
rmdhawaii's Avatar
If you tighten down the screw and pull the clutch bell in and out, does it still touch the 2-speed housing? If so, you may have to add a 0.1-0.2mm washer between the pin that holds the clutch shoes and the bearing in the rear bulkhead - or move the engine a bit further in so it doesn't touch.
What motor do you have in the car now??
Old 05-25-2007, 01:05 PM   #8504
asw7576's Avatar
Sorry guys.... I need to sleep now.... 2pm.
Tommorow I have to full throttle again.
Old 05-25-2007, 02:49 PM   #8505
Moderator
Omega motor modified by me. Its about as fast as the JLR. I call it the white dot...lol. Since I used white silicone filled crank. Ive got an ofna pipe on it too and it seems to scream with this new clutch setting. Awesome purchase too , got two full motors and like 2 full rebuild kits for $100.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
