Old 05-22-2007, 04:48 PM   #8446
MTX-4
Ninja
3 Racing Engine mount (one piece)
Urethane Belts
Spool/Diff & 24/25 tooth side pulley. (i have used most combos)
Clutch with the thrust bearing spacer, but otherwise standard.
Clutch Spring 0.8-.09mm
Clutch endplay .4mm (I think, i will doulbe check that one, it may be less)
Small amount of mesh clearance.
Mugen spur gears. (std tooth)
Mugen Steel pinions. (but std tooth)
GQ tyre's 40's
No stripping problems.
vdh design is offline   Reply With Quote
Old 05-22-2007, 04:57 PM   #8447
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Originally Posted by vdh design
MTX-4
Ninja
Urethane Belts
Mugen spur gears.
GQ tyre's 40's
Near perfect , also include what pinions and spurs your running. Maybe even clutch gap or anything else you can jot down.
Thanks!
Artificial-I is offline   Reply With Quote
Old 05-22-2007, 05:00 PM   #8448
Ryan41's Avatar
Send a message via MSN to Ryan41
I had a stripping problem to begin with, but it is now solved (just had the engine a tiny bit out of alignment..)
The MTX3 didnt strip gears as it did not have a .8 gear mesh like the MTX4..so if you dont get the mesh on the MTX4 perfect..you will hit troubles.
Capricorn Tourer
AE TC5R- Drifter
Revo to annoy the dog
Yokomo DRB drifter for the missus.
Ryan41 is offline   Reply With Quote
Old 05-22-2007, 05:09 PM   #8449
I had SGS (knocking on wood), but somehow the nitro gods have been nice to me lately. This problem does happen to most MTX-4 owners. I close friend of mine is sponsored by Mugen and he even strip gears. Here's how I limited the number of stripped gears.
4mm chassis
Thread lock Engine mounts (I use the blue one)
Use longer screws for the 2 bottom engine mounts like ASW7576 posted in post #8405
SUPER tight mesh
Steel pinions
24T side pulley
Gears:
Pinion Spur
17T/T23T 53T/59T
16T/22T 54T/60T
18T/24T 52T/58T
I've ran on a soda prepped track, VHT prepped track, no prep track, smooth track, bumpy track, etc... and my SGS solutions seems to be holding up (knocking on wood), but it did cost me a lot of spurs to finally get it down right.
jfro6512 is offline   Reply With Quote
Old 05-22-2007, 05:19 PM   #8450
rmdhawaii's Avatar
Originally Posted by Artificial-I
AS WELL IF A MUGEN DRIVER HIMSELF HAD A SPUR GEAR STRIP. As well as other multiple mugen drivers ive seen have the problem. Because if anyone knows how to build this kit , its them. End of story.
What it seems you're implying, is that Team drivers don't make mistakes or errors in judgement and do everything 100% correct, 100% of the time. Building a car and maintaining a car are two different things. If they let the latter slide, even a bit, even they can get themselves in trouble during the course of the race. They can also get into accidents, which can also shift things out of position, which can also lead to problems sometimes during the course of a race or subsequent races. Team drivers may be extremely good, but they are not perfect and they don't have 100% control over every aspect of their car 100% of the time.
I think you know where I'm going with this...
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 05-22-2007, 05:25 PM   #8451
kaotickc's Avatar
Trader Rating: 43 (100%+)
MTX-4
Ninja
Urethane Belts
GQ tyre's 40's
Can I ask what the purpose or effect the thrust bearing spacer has?
kaotickc is offline   Reply With Quote
Old 05-22-2007, 05:27 PM   #8452
Moderator
I didnt say 100%, but surely at the top of mugens game.
Old 05-22-2007, 05:31 PM   #8453
It prevents any drag on the clutch bell when idling, and mostly improves consistancy with the clutch engagement, and dis-engagement. Very clever really.
Old 05-22-2007, 05:37 PM   #8454
rmdhawaii's Avatar
If that's the case, would you be open to the possibility, that perhaps a Team member's gear strip may have been a result of their own action, inaction or forces outside of their control (i.e. part wear, accident, track debris, pit man dropping their car, etc..)?
Old 05-22-2007, 06:02 PM   #8455
evostyle's Avatar
Trader Rating: 102 (98%+)
If your having gear stripping issues, try replacing your clutch bell bearings first.
Do not use longer screws in the bottom of the engine mount as these may not tighten all the way down. Longer screws may bottom out on the rear hole. The rear hole is used from the top to hold the motor to the mount. Only use what's listed in the manual.
Also as a side note for those using the JL red dot. I have noticed on a few of these engines there is excessive play up and down side to side from the front bearing. This crank play could also lead to excessive gear mesh causing a stripped spur gear.
"If you no longer go for the gap that exist, you are no longer racing". Ayrton Senna
evostyle is offline   Reply With Quote
Old 05-22-2007, 06:03 PM   #8456
The longer screws are used on the clutch bell side of the mount.
Old 05-22-2007, 06:06 PM   #8457
Seisick's Avatar
uhm, i wish i had some stripping and see what went wrong just to post it here, well, ītil then still using my one year 52 spur
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 05-22-2007, 06:12 PM   #8458
Moderator
It could be anything. My point is, that a mugen driver is going to be on top of their game. Where as people are pointing out that its like novice type errors here. My point is , even the top guys are blowing them. I think you misunderstood that.
Old 05-22-2007, 06:15 PM   #8459
evostyle's Avatar
Not according to asw7576's picture.
Old 05-22-2007, 06:16 PM   #8460
evostyle's Avatar
Artificial-I do you have any crank play with your JL Red Dot?
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
