Old 05-17-2007, 05:39 PM   #8371
Nitro$junkie's Avatar
Send a message via MSN to Nitro$junkie
Atomic New Products for V-One RRR should fit the MTX4 as well
KR-015, F.R.P. Receiver Protector
Futaba
Mugen
Novarossi
Byron's
http://www.hospitalrecords.com
Nitro$junkie is offline   Reply With Quote
Old 05-17-2007, 05:45 PM   #8372
< Includes >
+ T0142 Al. Wheel Hub
+ T0151-B Front Lowe Arm
+ T0161 Rear Upper Arm Mount
+ T0164 Front Uprigh (2)
+ T0245 Front Universal Joint
+ T0268 Front Belt (Rubber)
+ T0269 Rear Belt (Rubber)
+ T0270 Side Belt (Rubber)
+ T0274 Rear Universal Joint
+ T0276 Front One-Way Drive Axle
+ H0369 Ventilated Brake Disk
+ T0717 Al. Engine Mount
Originally Posted by 427 COBRA
My R car has all 4 CVDs, thick vented brake rotor, all 3 rubber belts, and a multi front axle that can easily be converted from solid axle to a oneway with the use of pins and o-rings, it also has the finned aluminum engine mounts, new lower front arms and new front steering knuckles (or front uprights) The last two WC cars i built did not have these option parts. I was hoping that the R car would have the thicker rear shock tower and teflon brake pads but nope.
Futaba
Mugen
Novarossi
Byron's
Old 05-18-2007, 01:18 AM   #8373
Default alloy clutch housing
hi,
i will use a alloy centax housing on my mtx 4,
is it better to take a harder or a softer clutch shoe???
dieter
4racer is offline   Reply With Quote
Old 05-18-2007, 08:03 AM   #8374
Originally Posted by 4racer
hi,
dieter
if you are refering to the clutch bell, they recommend that racers use the mugen red shoe with the aluminium JP clutch bell.
for the standard bell use yellow or grey, up to you.
TomB is offline   Reply With Quote
Old 05-18-2007, 09:58 AM   #8375
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Do you know why the red would be good with the jp bell?
Artificial-I is offline   Reply With Quote
Old 05-18-2007, 11:03 AM   #8376
vlp
vlp's Avatar
Send a message via ICQ to vlp
Originally Posted by asw7576
I don't think you need to replace clutch shoe everytime after use. It's reuseable.
Stick to one brand of fuel. ( Different fuel needs different setting ). I cannot suggest a fuel brand. 16% nitro is minimum, 25% is maximum for .12 engines. 20% nitro is nice.
Don't use cheap fuel. Cheap fuel = Low quality lubricants.
Heavy smokes or Very thin smokes doesn't accurately tell your engine's optimum power. Use a temp gun, and set the engine to operate around 212 F - 248 F ( 100 C - 120 C ). Listen to crispiness while accelerating. Don't forget to properly set the centax clutch's spring tension. Not too soft ( engine bogging effect ) and not too stiff ( high pitch sound before the clutch enganged ). I usually set the spring tension at 0.8mm - 1.0mm
Thanks for the tips
I'm just placed order for Sidewinder fuel which is %20 , I think my problem is about clutch as well , Im trying to set it up right now , too bad i dont have this centax clutch setup tool hm ;p Im trying to set it up as described in nitrokb mtx4 knowleadgebase
thanks !
vlp is offline   Reply With Quote
Old 05-18-2007, 11:05 AM   #8377
vlp
vlp's Avatar
hmm looks good , I think I gonna give it a try
Old 05-18-2007, 02:37 PM   #8378
vlp
vlp's Avatar
well , finally after 5 times of complete rebuilding , I think Im able to setup the car properly now
just got my 1/10 hudy setup system , dayam thats looks like nuclear button case
mtx4 4lyfe :
Old 05-19-2007, 06:49 AM   #8379
itchy b's Avatar
mtx4 4lyfe :
Remember, practice makes perfect!
From setup to racing!
Great to see you like it Keep us all updated on how you get on too!
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 05-19-2007, 06:50 AM   #8380
itchy b's Avatar
Tomas, that question is for you to answer!
Come on!
Cough up the info bud!
EX1.5-SC10 4x4
Old 05-19-2007, 07:11 AM   #8381
i was told the red is suited better to the aluminium, it grips better or something. one of the Mugen drivers from N.S.W told me this from memory i think
Old 05-19-2007, 07:25 AM   #8382
asw7576's Avatar
I think what he said makes sense. The red is soft clutch, so it grips faster ( less friction to grip ) than grey or black. The alluminium clutch bell maybe weaken ( metal deformation ) under too much heat, eg. resulted from too much clutch's friction.
I'll stick with steel clutch bell, thank you very much.
Old 05-19-2007, 07:37 AM   #8383
itchy b's Avatar
I'm about to fit the optional blade type rear sway bar and i read here that you need to lingthen the links to the suspension arms.
does anyone know what the new measurement is for it ti work well and with proper clearance ?
cheers
Joe
EX1.5-SC10 4x4
Old 05-19-2007, 01:25 PM   #8384
kaotickc's Avatar
Trader Rating: 43 (100%+)
So whats the 1pc. engine mount of choice here guys?
kaotickc is offline   Reply With Quote
Old 05-19-2007, 02:18 PM   #8385
Moderator
My vote goes to the 3racing engine mount. Had the kawahara and the 3racing allows access to the backplate and seemed to hold the engine screws better.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
