Old 05-15-2007, 07:48 PM   #8356
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Gotcha. I use all the punch I can get especially for my track. The LW shoes will go on soon and more engine tuning will take place. Figured I'd get the Murnan Mod TZ setup for my other OS block w/ heatsink and use that when I get even better.
NJ-So even with the 25T pulley you still use softer fronts?
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 05-15-2007, 09:53 PM   #8357
kaotickc's Avatar
Trader Rating: 43 (100%+)
I went from the 24 to 25 pulley and thought it handled much better for me at my track.
kaotickc is offline   Reply With Quote
Old 05-15-2007, 11:20 PM   #8358
HarKonnenD's Avatar
Sounds good. I'll give it a try this sunday.
Old 05-16-2007, 04:49 AM   #8359
Nitro$junkie's Avatar
Send a message via MSN to Nitro$junkie
dose any one know if the receiver box from the NT1 fits the MTX4 if so i might have to get one
Futaba
Mugen
Novarossi
Byron's
http://www.hospitalrecords.com
Nitro$junkie is offline   Reply With Quote
Old 05-16-2007, 04:53 AM   #8360
rear tyers are always going to wear faster than the front just the nature of the bussines softer fronts seem to bring down the wear difference between front and rear it also depends on driving style im a very aggresive driver wich makes the rear to wear alot more then normal
Futaba
Mugen
Novarossi
Byron's
Old 05-16-2007, 04:56 AM   #8361
jaykay's Avatar
and does the 2 speed system of the nt1 fits in the mtx4? that would be greater!
jaykay is offline   Reply With Quote
Old 05-16-2007, 05:32 AM   #8362
Ryan41's Avatar
Send a message via MSN to Ryan41
I would also like to know this..
Capricorn Tourer
AE TC5R- Drifter
Revo to annoy the dog
Yokomo DRB drifter for the missus.
Ryan41 is offline   Reply With Quote
Old 05-16-2007, 05:41 AM   #8363
itchy b's Avatar
Everything most likely fits as they are 99% the same design
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 05-16-2007, 05:46 AM   #8364
Ryan41's Avatar
I might order one..(radio box) as my last receiver died..
I reckon its a good idea..
Capricorn Tourer
AE TC5R- Drifter
Old 05-16-2007, 10:05 AM   #8365
Default mtx4 vs mtx4r
what does the mtx4r has that the mtx4wc dont have
The Rookie is offline   Reply With Quote
Old 05-16-2007, 12:37 PM   #8366
vlp
vlp's Avatar
Send a message via ICQ to vlp
Default just burned out my spur gear !!!
well , I was previously playing with my engine settings as I just completed brake-in for os 12tz 5 ports ...
I was still in process of getting a feeling of properly running engine , I took the car to parking lot , ignited it up , and after 2 minutes its felt like its running on neutral with some funky smelling around ...
so I closed the engine and my temp gauge showed 302f !
i was like what the heck , I took it for repairing at home and I noticed that the aluminum clutch gear got so hot that its burned both spur gear in place where its contacts... I opened the clutch and its looks like most of the parts overheated there , the ball bearings got some funky yellow colour even =/
well , I just totally rebuilt the car , cleaned everything out , replaced the spur gears and my question is , should I replace the clutch also ?
Is there some parts which can be damaged due this overheating ?
also , could this overheating happen cause of bad fuel ? ( I bought some local fuel for rc , no brand ) , yeah I learned my lesson ;p
I wasn't running the engine too lean , there was lots of smoke coming out from exhaust pipe ... hmm
p.s Please recommend me a place where I can buy clutch setups for mtx4 , I just found out my favorite online shop don't have it , please suggest !
Thank you.
vlp is offline   Reply With Quote
Old 05-17-2007, 12:24 PM   #8367
asw7576's Avatar
Thank you.
I don't think you need to replace clutch shoe everytime after use. It's reuseable.
Stick to one brand of fuel. ( Different fuel needs different setting ). I cannot suggest a fuel brand. 16% nitro is minimum, 25% is maximum for .12 engines. 20% nitro is nice.
Don't use cheap fuel. Cheap fuel = Low quality lubricants.
Heavy smokes or Very thin smokes doesn't accurately tell your engine's optimum power. Use a temp gun, and set the engine to operate around 212 F - 248 F ( 100 C - 120 C ). Listen to crispiness while accelerating. Don't forget to properly set the centax clutch's spring tension. Not too soft ( engine bogging effect ) and not too stiff ( high pitch sound before the clutch enganged ). I usually set the spring tension at 0.8mm - 1.0mm
Old 05-17-2007, 01:38 PM   #8368
My R car has all 4 CVDs, thick vented brake rotor, all 3 rubber belts, and a multi front axle that can easily be converted from solid axle to a oneway with the use of pins and o-rings, it also has the finned aluminum engine mounts, new lower front arms and new front steering knuckles (or front uprights) The last two WC cars i built did not have these option parts. I was hoping that the R car would have the thicker rear shock tower and teflon brake pads but nope.
427 COBRA is offline   Reply With Quote
Old 05-17-2007, 04:51 PM   #8369
Seisick's Avatar
uhm, perhaps after next worlds a prospec version with the latest upgrades 4mm chasis, tower teflon and everything titanium, could be awesome
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 05-17-2007, 04:54 PM   #8370
gashuffer's Avatar
Trader Rating: 48 (100%+)
Check it out!
T-Sal
gashuffer is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
