Mugen MTX-4
#8206
Originally Posted by Slo-MTX4
Hey all just wondering if anyone know the part number for the aluminium spacers that go behind the hex drives?
#8207
Location: Time to put down the Golf clubs and poker chips and GO RACIN!
sterring servo
anyone ever had a 9411 servo just give out in the middle of a turn?
I pucked up a futaba 94151 I think it is.. will it suffice? could my saver be too tight?
#8210
Originally Posted by Tye
You probably should have just used the standard flat pack and had more battery time instead of lead weights and a light weight battery with low capacity. Just my opinion.
Tye
Tye
#8214
Hey guys
Just of curiosity how much thread have you got showing on your rear pivot ball to be at 200mm width, I have 3.8mm which leaves the universal just inside the diff out drive.
There used to be a lot less thread showing in the mtx-3, by the way Im using mtx-3 titaniam balls which makes no difference I guess.
#8216
More descriptions : ( # TAM53891 )
http://www.tamiyausa.com/product/ite...oduct-id=53891
http://www.speedtechrc.com/store/ebp...id=269&id=5938
http://rc-mushroom.com/product_info....oducts_id=9806
BTW, I use that shim for centax clutch shim, ie. before the clutchbell bearings. ( just info : ..... 5 x 1.9mm shim depends on collete's thickness. Narrow collete from Mugen is fine. Wider collete that comes from novarossi engines, is not. )
#8217
Originally Posted by Artificial-I
Is there such a part. I just got the kawahara hexes , they came with the 1mm shims.
#8218
Originally Posted by asw7576
Do you mean these kind of shims : .... its 5mm inside dia x 1.9mm thick
#8219
you can use the shims from any old thrust bearing, it has de 5mm inner diameter needed or any shim with a max of 100 outer diameter, the thickness will determine the width of your rear
