Old 04-13-2007, 10:47 AM   #8086
vlp
vlp's Avatar
Send a message via ICQ to vlp
Thanks everyone !
I have the http://www.nitrokb.com/mtx4/ on my favourites , as well as this thread
Its seems like im fully completed the kit , so what I got there is
mtx4kit , EB Modified O.S. .12 TZ (P)-T 5-Ports engine with k-missle exhaust pipe , 2 digital servos - futaba s9351(th) and ko2366(st), Spektrum DSM 3CH system with 3PKS futaba radio , 6v 3000 mah battery for transmitter and mazda 6 body ( havent painted it yet ;/ )
so this morning I tried my first break-in , I did followed some tips from the forum and also mostly the manuals of engine
well , i wanted to ask for advice , can I leave the fuel pipe whatever leght I want or it's should be soem specific one , I saw your mtxs photos guys and saw the fuel tubing goes kinda in spiral , why you need so much leght ?
Also after the break in procedure I tried to run the car , the engine showed about ~210 240 f all the time , but its seems like the engine stops after soem 10 seconds , i cant describe it exactly hm , i thought its stops when its shifts to second gear , so I tried to spin the car around on the first gear and after some 15 seconds the engine just stopped again ;p
yaaaaw I see I gotta learn lots of stuff and I like it
vlp is offline   Reply With Quote
Old 04-13-2007, 11:54 AM   #8087
vlp
vlp's Avatar
maybe someone is avliable on icq sometimes whos expirienced with mtx4 ?
I won`t take much of your time , just for a small tips , I would really appreciate if someone could dedicated me few minutes of his time , let me know please , thank you!
Old 04-13-2007, 07:28 PM   #8088
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
The pressure line is the one that goes from the exhaust pipe to the tank. Usually a long enough length creates enough pressure to keep fuel going into the engine especially if the car flips over. The filter on the line also prevents debris from entering the tank as you sometimes will see the pressure line near the exhaust is filled with unburnt fuel or so. I try to keep the fuel line away from the engine so it doesn't heat up before reaching the car. I prefer to have it go around the air filter and curl back to the carb. As for the engine how does it sound? Is it bogging or running really rich or is it running lean?
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 04-13-2007, 10:57 PM   #8089
asw7576's Avatar
I think you are doing good. I'm using fuel inline filter ( novarossi ) and I keep the fuel line short without kink. Cover the fuel line with some kind of tubing where it touch the engine for less heat transfer. For fuel pressure line, 13cm to 15cm in length is the best setup. Longer fuel line actually helps to minimise flame out when a car is flip over, but too long will make the fuel tank capacity out of 75cc regulation.
Interestingly too long fuel line ( over 10 cm in length ) cause starting problem in my mrx4-r.
Old 04-13-2007, 11:46 PM   #8090
SOLOARTIST 702's Avatar
Send a message via AIM to SOLOARTIST 702
Default mtx4r
still working on it the MTX4 SE now part of the MUGENATOR NATION watch it now no more port a potty trips 4 me this is why im hot
RC AMERICA / XRAY / HUDY/ MATRIX TIRES /KOPROPO / ORCAN GT3 /RED CUP RACING MEMBER / SPEEWORLD RACEWAY/ A+ performance parts /IVE SEEN THE XRAY TEAM DRIVE SO I GOT XRAY CARS / better to keep up than to catch up
WILLIAM PENDERGRASS
SOLOARTIST 702 is offline   Reply With Quote
Old 04-14-2007, 03:40 AM   #8091
vlp
vlp's Avatar
got it !
I'll adjust the pipes leghts right now !
I also have the mugen short and long filter , i think ill go with bigger one hm
well , thats the problem I guess , the engine sound , as for me its runs preatty nice i think , but i dont understand much as you see , when the car stands on starter box and the wheels in the air , i kick down some rpms and its work like a charm , blue smoke running out of exhaust , the engine wont stop...
but when i put on the floor , i have about 20 secodns to run the car before its stop without any reason ;p
im gonna play with carb settings a bit , maybe ill check the clutch ;p
ah , i dont have any rc club around me , so i gotta figure out everything on my own , well i guess its hardest but best way to learn about my new hobby
Old 04-14-2007, 03:47 AM   #8092
vlp
vlp's Avatar
heh just figured out i dont need any adjustment on the pipes leght
my air pressure pipe is about 150mm
the fuel pipe is about 130 mm
going to install the mugen long filter now ...
Old 04-14-2007, 04:47 PM   #8093
HarKonnenD's Avatar
All you need to do then is lean out the low end needle and you may need to reduce idle a well. The engine is running a little rich so it will load up and cut off unless you bleep the throttle a little bit.
Old 04-14-2007, 05:05 PM   #8094
vlp
vlp's Avatar
I tried to play with needles a bit today , and I got some better results already, the engine stops more rarely now.
I just want to figure out on my own the feeling of proper running engine , if the mixture if its too rich or lean... sure, I have reasearched tons of material on the forum , but still dont have the "feeling" on my own
p.s I need to get the set up system asap !
I didn't adjusted the ride yet ;p
I thought about team magic one , but looks like I gonna place a order for Hudy All in one set-up system
Old 04-14-2007, 06:04 PM   #8095
HarKonnenD's Avatar
Sounds good! Glad you got that fixed up. BTW with the Hudy you can't go wrong. It's high quality and the best thing to get for your ride when you want to really have a dialed car.
Old 04-14-2007, 06:53 PM   #8096
Ivan Dickson's Avatar
Trader Rating: 12 (93%+)
Best thing to do is get the feeling yourself to figure it out engine tuning same thing I did makes a big difference.
SPECIAL THANKS TO ✦ MY WIFE ✦✦ MOTIV RC ✦✦ GRAVITY RC ✦✦ JGO PAINTZ ✦✦ TQ RC RACEWAY ✦✦ TAMIYA RACEWAY ✦
Ivan Dickson is offline   Reply With Quote
Old 04-15-2007, 01:02 PM   #8097
asw7576's Avatar
For MTX4 clutch / centax setup, there was Mike Swauger's article covered in RC Extreme Magazine. Read that, it's very good reading.
For MTX4 suspension setting / setup tools : Hudy All in One system is the best.
For engine tuning : Ask more experience drivers ( Group A drivers ) to accompany you tuning the needle.
Don't forget to learn how to open and clean engine's internals after use. Materials to clean engine internals : Motor sprays ( ask electric car racers what brand to clean their electric motor ), Metal Polish, Clean clothes / rags, Novarossi after run oil, Small Zip Ties, and HUDY TOOLS
For examples: You need this screw driver to open Novarossi engine without damaging the top screws : see attachment.
Search your needs in www.hudy.net
Old 04-15-2007, 01:28 PM   #8098
vlp
vlp's Avatar
I played some more with the needle settings today , and the car runs even better , I managed to burn almost full tank without the engine stopping even for single time. weird thing my setting are not like recommended in o.s manuals ;p , I need to adjust my clutch now , i think its goes on too early , Im waiting for the tool to set it up.
I have the hudy promotional set of tools , and I really like it
Old 04-15-2007, 01:29 PM   #8099
vlp
vlp's Avatar
yep , I wanna learn it myself
Old 04-15-2007, 01:32 PM   #8100
vlp
vlp's Avatar
Thanks for the tips first of all !
I dont have anyone around with touring nitro , no rc clubs here
Ough you are totally right , I forgot to buy all those cleaning sprays , I'll put some order tonight !
as for Hudy , Im already ordered the set up system and expecting it next week , I have their promotional set of tools (9 pieces) and I really like their quality , after all , I'm not so rich to buy a cheap things
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
