Old 04-03-2007, 11:27 PM   #8056
AMGRacer's Avatar
MTX3 pinions will not work, wrong size.
AMGRacer is offline   Reply With Quote
Old 04-03-2007, 11:45 PM   #8057
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Oops. I forgot I did use new pinion gears. Interesting I thought they were the same. Thanks for correcting it.
Artificial-I is offline   Reply With Quote
Old 04-04-2007, 06:21 AM   #8058
blanks596's Avatar
Trader Rating: 14 (100%+)
Originally Posted by Bigbarn
Trying to get fast like Ishitani huh Max........
I'm goin crazy trying to figure out his reasoning behind the set up he used at Airtronics
Serpent/Desoto Racing
Max S
blanks596 is offline   Reply With Quote
Old 04-04-2007, 06:14 PM   #8059
Seisick's Avatar
anyone knows the weight for the stock alum pulley and for the stock brake pulley, the same for the msr lightweight ones?
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 04-04-2007, 08:22 PM   #8060
I got them on my car. I believe they are 2-3grams light then stock.
https://www.gofundme.com/ncontrol
Joe Maxey is offline   Reply With Quote
Old 04-04-2007, 09:38 PM   #8061
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
I've heard somewhere before than the alum pulleys can decrease the lifespan of the belts...and is this true? One person had experienced this so I just wanted to know. I really don't plan to do much to my 4 as I believe it doesn't need many items anyway. Still can't believe it will cost me $90 for front and rear universals for this car. Ah well so far the doggies(dogbones) haven't fallen out and no strip of the spur.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 04-04-2007, 10:02 PM   #8062
deviltires's Avatar
does anyone else has this problem my clutchbell rubs against my 2 speed housing if so how do i fix that
DARNELL WASHINGTON-- TEAM MUGEN----FUTABA 4PK--HOT RACE TIRES
deviltires is offline   Reply With Quote
Old 04-04-2007, 10:59 PM   #8063
asw7576's Avatar
I solved mine with bigger pinions ( 1 tooth bigger ).
Old 04-04-2007, 10:59 PM   #8064
Bigbarn's Avatar
Bigbarn is offline   Reply With Quote
Old 04-05-2007, 01:53 AM   #8065
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to rcfoolz
I switched over to the MSR ones, as they are lighter than the stock ones. I don't emember exactly how much, but I did switch only because they are lighter.
Am I going back racing?...Hmmm.. Not anytime soon... But soon enough.
rcfoolz is offline   Reply With Quote
Old 04-05-2007, 02:03 AM   #8066
rcfoolz's Avatar
Aluminum pulleys will decrease the lifespan........I don't know for sure, but another reason for the aluminum pulley on the car is because of the pipe mounting spring wears against the pulley. With the stock pulley, when your car gets hit from the side and it will wear the outside edge off and allow the belt to fall off.
Old 04-05-2007, 02:08 AM   #8067
rcfoolz's Avatar
Hmmm, this has been covered a few times, but lets put it this way.... If it is rubbing, something is wrong, it could be a few things.
1. Gear mesh isn't set correctly,(engine isn't square)
2. the 2 speed housing has expanded due to the 2nd speed clutch is hitting too hard, and your 2nd speed is or will lock up on you.
3. worn clutch bell bearings.
Old 04-05-2007, 06:01 AM   #8068
Seisick's Avatar
my bad,meant the alum pulley adaptors, not the pulley itself, same for brake pulley,
HobbymaniA
GoT MuGeN?
Old 04-05-2007, 06:03 AM   #8069
Seisick's Avatar
loose side brace perhaps
HobbymaniA
GoT MuGeN?
Old 04-05-2007, 06:14 AM   #8070
rcfoolz and other mugen drivers. mount your pipe mount on the top of the top deck, this will eliminate any issues of the pipe spring touching.
see attached pic
even with a massive hit, it can never hit the pulley, as the spring section is above it now.
TomB is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
