Old 03-24-2007, 01:20 AM   #7876
asw7576's Avatar
Originally Posted by lil-bump
I really have not had a chance to see the Nt1 in action yet. The nitro season in my parts has not started yet. But I would like to see the suspension geometry.
I believe the Nt1 has further modification to the chassis which are not easily seen by the naked eye which lowered the COG gravity but also lowers the roll center. Don't get me wrong I believe a lower center of gravity is a good thing but I don't believe in it if it hampers my ability to move the roll center.
NT1 has lower upper deck ( as low as G4S ) thus ultra low CG
Front and Mid section look like MTX4
Rear section look like V1-RRR.
Old 03-24-2007, 01:48 AM   #7877
Dal
Dal's Avatar
Send a message via Yahoo to Dal
Originally Posted by jaykay
I`m just thinking about the ackerman plates in the mtx-4. I have read here in the forum that:
A - aggressive
B - neutral
C - smooth
But when you look at the plates, you see that C has the holes in the middle. So C must be the neutral or not?!
HEY JAYKAY,
you are correct, c is the neutral one
Dal is offline   Reply With Quote
Old 03-24-2007, 04:41 AM   #7878
choisan's Avatar
And my friend who had his NT1 debut and won, he used MTX4's whole set of 1st(60) n 2nd Spur gea with its one-way bearing and metal housing.
choisan is offline   Reply With Quote
Old 03-24-2007, 06:05 AM   #7879
JetMD's Avatar
I was hoping to get some advice on front and rear belt tension. Since i've only had to worry about side belt tension before, front and rear are new to me as far as where they are supposed to be. The stock setting put the front tighter than the rear. So, is this how it's supposed to be? Even with the rear all the way tight on a new belt, it doesn't seem that tight to me. Plus, at the stock setting, the mugen label wore off the rear belt because it was rubbing on the chassis. So, I put it at the tightest position just to get it off the chassis. On a new belt, is this considered too tight? The drivetrain doesn't feel bound up at this position. Or, is it normal for the rear belt to rub a little on the chassis? Thanks for any help.
www.vorra.org
MINO Racing
JetMD is offline   Reply With Quote
Old 03-24-2007, 08:29 AM   #7880
Trader Rating: 15 (100%+)
Originally Posted by rcfoolz
I've ran both, ceramic and steel. They both last about the same. I now buy the 5.x8 steel bearings 50 at a time. Thats enough to last about a year.
What do they cost when you buy them in bulk like that and where do you get them?
THE DOCTOR is offline   Reply With Quote
Old 03-24-2007, 11:46 AM   #7881
lil-bump's Avatar
Trader Rating: 83 (100%+)
I believe avid bearing has them at 1.00 a piece but they are currently out of stock
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 03-24-2007, 03:04 PM   #7882
asw7576's Avatar
Default PRO SQUAT
Anyone try this : Lower suspension arms are tilted upward ( Pro Squat ) ?
See attachment. It helps little bit to reduce off power understeering in my car.
Old 03-24-2007, 06:16 PM   #7883
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to rcfoolz
I get them from a hobby shot that does business on ebay. They cost $25.00 shipped. They are kyosho branded.
Am I going back racing?...Hmmm.. Not anytime soon... But soon enough.
rcfoolz is offline   Reply With Quote
Old 03-24-2007, 11:51 PM   #7884
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Just got the 4mm rear shock tower for my 4 and it's awesome. Hopefully tomorrow is going to be nice enough for a test run.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 03-25-2007, 02:08 AM   #7885
wario69's Avatar
Yeah, I got the 4mm shock tower also a few days ago. They are sweet. It is a must have unless you are satisfied with gluing 2 stocks together.
-- Wario
wario69 is offline   Reply With Quote
Old 03-25-2007, 03:22 AM   #7886
Jetforce's Avatar
Hello!
Yesterday i received Mugen s optional rear stabilizer. Have one of you guys test it ? Whats the advantage ?
Jetforce is offline   Reply With Quote
Old 03-25-2007, 04:20 AM   #7887
yep works great to reduce exit rear end kicking out (pro squat that is) i use it myself and i really like how the car handles.
TomB is offline   Reply With Quote
Old 03-25-2007, 05:22 AM   #7888
jca2000au's Avatar
Trader Rating: 9 (91%+)
But doesn't that setup only for EP car? All Hudy setup book that come with setup station all refer to EP car. EP car the power band is smoother than GP car.
jca2000au is offline   Reply With Quote
Old 03-25-2007, 11:23 AM   #7889
asw7576's Avatar
Interestingly, it helps reduce slightly my understeering problem at off throttle. It helps to coast mid cornering without too much push.
Old 03-25-2007, 05:43 PM   #7890
Quick Question:
Iím currently tearing down my MTX-4 after this weekís race and I noticed that my servo saver has some play in it. Their seems to be some play with the servo saver on the metal shaft (1mm - 2mm of play up and down), I may have to shim that shaft so the servo saver doesnít slide up and down. Itís taking away from the MTX-4 steering abilities.
Just checking too see if anyone has had this problem after assembling the kit.
Ghett0 is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
