Old 03-18-2007, 11:18 PM   #7756
Car Breaker's Avatar
Ohh NO, it is a R, time to save up for MTX-5
Xray X12 2015
ARC R10 ATS
Car Breaker is offline   Reply With Quote
Old 03-18-2007, 11:19 PM   #7757
Ivan Dickson's Avatar
Trader Rating: 12 (93%+)
Cool
SPECIAL THANKS TO ✦ MY WIFE ✦✦ MOTIV RC ✦✦ GRAVITY RC ✦✦ JGO PAINTZ ✦✦ TQ RC RACEWAY ✦✦ TAMIYA RACEWAY ✦
Ivan Dickson is offline   Reply With Quote
Old 03-18-2007, 11:31 PM   #7758
Roger's Avatar
Originally Posted by Bigbarn
If only I could read Japanese.
Its got part numbers.
http://nitrokb.netne.net/profiles/RogerSerafin.html
Roger is offline   Reply With Quote
Old 03-19-2007, 12:35 AM   #7759
stefan's Avatar
Send a message via AIM to stefan
Originally Posted by ND
The M-Mod stuff is really high quality, and works very well. I use there stuff on my MTX-4 and MRX4-R. If your looking for some hop-ups these are worth a good look.
I would if their preices wouldn't be so outrageous
stefan is offline   Reply With Quote
Old 03-19-2007, 01:21 AM   #7760
rmdhawaii's Avatar
Originally Posted by FF25510
check it out
MTX-4R Parts List
T0142: Aluminum Wheel Hubs
T0151-B : Front Lower Suspension Arm (Guess, base on existing T0151)
T0161: Rear Upper Arm Mount
T0164 : フロントアッブライト (2 degree) [ Front upright, 2 degree angle ]
T0245 : Front Universal Joint Set
T0268 : Front Belt (Rubber)
T0269 : Rear Belt (Rubber)
T0270 : Side Belt (rubber)
T0274 : Rear Universal Joint Set
T0276 : フロントワンウェイドライブアクスル [ Front one-way driving axle - revised? ]
H0369 : Ventilated Brake Disk
T0717 : Aluminum Engine Mount [ This part is two pieces?]
If you have an MTX-4, you probably already have most of this anyway. The 2-degree front upright is an interesting upgrade. This is already an option part for the RRR.
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 03-19-2007, 04:58 AM   #7761
lil-bump's Avatar
Trader Rating: 83 (100%+)
Originally Posted by rmdhawaii
MTX-4R Parts List
What site are these parts from. I'd to see the two piece engine mount
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 03-19-2007, 05:23 AM   #7762
itchy b's Avatar
Mugen Germany has some pretty interesting parts for the MTX-4. Anybody using any of them? Check out the Produkte -> M-Mod by Mid section.
http://www.mid-mugen.de
Wow, those bits look mighty fine
i like the look of their side belt tensioner!
Aswell as the Batery holder, rear swaybar, break arm..................etc. etc.
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 03-19-2007, 05:28 AM   #7763
itchy b's Avatar
I think that with all these extras ( most of which we all have on our cars anyway, apart from the hat! ) the current Mtx4 and R will be very competitive for at least 2 years yet
EX1.5-SC10 4x4
Old 03-19-2007, 08:02 AM   #7764
JetMD's Avatar
Well, here we go again...I ran my MTX-4 for the first time at a club race yesterday and I stripped second gear about 3 min. into the main. I ran 2 qualifiers and a little practice with no problems. I've read a lot on here about this and I wanted to prevent having this problem so I checked and adjusted the gap in my 2-speed, bought a one-piece engine mount and the aluminum upper-deck brace, carefully checked my gear mesh for 1st and 2nd gear and it would seem that none of that helped. I have run in this same parking lot for a couple years and have never stripped one gear, always both and usually because the motor shifted. Well, the motor didn't shift because when I popped the new gear on, the mesh was the same as before. I'm pretty sure it happened when I hit a bump at the end of our back straight and the car went airborne for a second. My MTX-3 has handled that bump many times without a problem. So, once again, any suggestions???
www.vorra.org
MINO Racing
JetMD is offline   Reply With Quote
Old 03-19-2007, 08:06 AM   #7765
Trader Rating: 14 (100%+)
How does the 2 deg upright affect the handling?
Is it the same part as the "recently" released uprights?
Speedpassion : Speedpower : East Coast Bodies
thunderbt3 is offline   Reply With Quote
Old 03-19-2007, 08:11 AM   #7766
JetMD,
Any signs of wear where the rear roll bar is close to the 2nd speed clutch bell? Also check for wear on the brace that spans over the engine clutch bell. I have a shim behind the 2 speed assembly (behind the pin) so there is less chance the 2 speed clutch bell will hit the engine brace.
Old 03-19-2007, 08:21 AM   #7767
lil-bump's Avatar
Originally Posted by thunderbt3
JetMD,
Where did you get this shim? I had to modify a clutch bell shim
Elliott Hart
Serpent America
Desoto Racing Team
Old 03-19-2007, 08:36 AM   #7768
JetMD's Avatar
JetMD,
Thanks, I will look into that. I'm guessing that these problems only come up when you hit bumps right?
www.vorra.org
MINO Racing
Old 03-19-2007, 09:00 AM   #7769
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
I think in japan the championship edition = mtx4r. I still believe there is a mtx-4 prospec that is going to come out in a few months this is where we should see a greater change in parts.
Artificial-I is offline   Reply With Quote
Old 03-19-2007, 09:09 AM   #7770
asw7576's Avatar
Originally Posted by Artificial-I
This give the car the easy option of switching from one way to a spool, via slipping a pin in and out of the diff and covering with a rubber o-ring.
The spool allows you to use 4 wheel braking. Rather than the rear wheels, which can result in spinning the car out if you brake too hard. This gives the car the ability to brake harder.
The spool is more aggressive out of a corner. The one-way allows more turn in and on power grip. The reason , the one-way allows the wheels to rotate at different speeds in a corner, which both tires wont spin at the same speed in a turn as one is on the inside and the other the outside. So this gives more grip and decreases tire wear , where as a spool setup the front tires will wear more as the wheels turn at the same rate throughout the turn.
Spool Is good for tight technical tracks. One-Way is good for high speed sweeping tracks. Driving both is pretty different , essentially with a one-way your coasting through corners and using good lines and more turn in to scrub speed where as the spool your driving more aggressive, braking and accelerating. Id also gather with a spool your going to use more gas per minute. I personally like a spool. But have yet to really goto a track with high speed sweeping turns. But either way its good to have braking. Another benefit of the spool is almost zero maintenance. You never need to lube or worry about its action from one day to the next or one track to the next. Its a locked mechanism and therefore nothing should degrade except for slop in the shaft cups. Reason why I like spools. No real fuss and you can brake like an animal.
Thank you AI.
But you haven't answer my original question : The possible benefit for using One Way Spool ( Solid One Way ). Will it induce more steering off throttle ?
Kawahara front one way can be use in three ways :
1. Classis One Way System
2. Spool ( full lock left and right and get front brakes )
3. One Way Spool or Solid 1 way ( left and right tires are rotating at the same rate but NO front brakes ).
Thanks for your suggestion / expertise once again.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
