Old 03-15-2007, 05:42 AM   #7726
AMGRacer's Avatar
Originally Posted by PROVK
I have just built the mugen spool from the diff case and find that it rubs on the ackerman/tie rod
Is this a mugen fault or am I doing something wrong
Nope, Mugens fault. It will hit with the steering links in the most forward position.
AMGRacer is offline   Reply With Quote
Old 03-15-2007, 05:45 AM   #7727
MaDaGAS CAR's Avatar
Send a message via MSN to MaDaGAS CAR
is there any way of fixing it
MaDaGAS CAR is offline   Reply With Quote
Old 03-15-2007, 05:48 AM   #7728
PROVK's Avatar
Trader Rating: 14 (100%+)
Thanks AMG racer
I thought it was mugens fault.
Do i just shave some plastic off the tie rod ends?.
Also , my front upper arms have some play , back to front where castor clips
are , is this normal, if not, how do you fix it, one side has more play than the other.
George V
Mugen Seiki
Max Power Engines GRP Tires Nitro X Fuels "Mugen Blend"
www.rrcsa.org.au
PROVK is offline   Reply With Quote
Old 03-15-2007, 06:15 AM   #7729
AMGRacer's Avatar
Thanks AMG racer
You can shave the tie rods down a little, or they get worn down by the diff naturally, your call.
My upper arms had play right from the box. I have a pack of shims laying around that I used to remove the play.
Old 03-15-2007, 06:40 AM   #7730
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Same here. need to do the same. I was thinking of using the pro4 ones too , lol.
Artificial-I is offline   Reply With Quote
Old 03-16-2007, 01:36 AM   #7731
FF25510's Avatar
hi guys,
what brake pad did you use when using fiberglass brake disc ?
tks!
FF25510 is offline   Reply With Quote
Old 03-16-2007, 02:27 AM   #7732
itchy b's Avatar
Originally Posted by FF25510
hi guys,
tks!
When you use the P-dub fibreglass disk break you only use the standard metal backing plates by themselves without any brake liner.
Mike Swager and another Mugen driver used this combo at the 200mm worlds in Brisbane with great results,
Good consistent breaking without break fade and the disk itself is very light, less than a 1/4 of the weight of a metal one!
Should do a great job of lowering rotaiting mass
If you're worried that it will wear out for that price you can always buy 2!
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 03-16-2007, 02:38 AM   #7733
FF25510's Avatar
tks itchy,
i found one in LHS here (not same as above), lets try
Old 03-16-2007, 09:45 AM   #7734
asw7576's Avatar
Maybe you can try to use B or C steering ackerman ( shorter and shortest respectively ).
However, the steering feel will be different. A steering ackerman ( longest throw ) will give more aggressive steering while C steering ( shortest throw ) is less aggressive.
Old 03-16-2007, 10:23 AM   #7735
typer's Avatar
In a japanese magazine, april issue of rcmagazine, mtx4r is at the back page of mugen ads
typer is offline   Reply With Quote
Old 03-16-2007, 10:27 AM   #7736
rmdhawaii's Avatar
Do you have the magazine? If so, could you scan it or take a picture of it?
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 03-16-2007, 10:44 AM   #7737
Moderator
YES!!!!!
Old 03-17-2007, 10:03 AM   #7738
asw7576's Avatar
I have Kawahara Front One Way / Spool All in One system.
What is the benefit for having one-way spool ? Does it increase steering ?
Currently I feel my car is understeering off throttle ( I'm still using original mtx4 one way ).
Thanks for your suggestion.
Old 03-17-2007, 10:10 AM   #7739
typer's Avatar
I'll try to post it...dont have a scanner. Try taking a picture of it
Old 03-17-2007, 10:12 AM   #7740
rmdhawaii's Avatar
Were you running a one-way before? What diff oil do you have in the rear?
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
