Old 03-07-2007, 01:01 AM   #7606
rmdhawaii's Avatar
Originally Posted by superturtle808
The race was well done by bobby and his crew. They took really good care of us who are not from oahu with tent, table and chairs. I will be back next year with more Maui racers. Brian from Mugen was a character at the banquet . Mike and Brian represented Mugen very well.
Garett
Islandhobbies Maui
Garett ~ Congrats on your wins! You guys were awesome. Looking forward to racing with you guys again next year.
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 03-07-2007, 01:26 AM   #7607
Garett
Islandhobbies Maui
Garett, was great seeing you, George, Craig, Mark again. Great to hear you folks got onroad going on Maui again.
Sometimes I post just to look at Kraig's avatar
RoyU is offline   Reply With Quote
Old 03-07-2007, 11:47 AM   #7608
i managed to over tighten and stripped one of the screw holes in the the rear sway-bar holder. it just continuously turns and turns. is there any temporary solution? or do i have to get it replaced?
racer2 is offline   Reply With Quote
Old 03-07-2007, 11:49 AM   #7609
Derby Bros Racing's Avatar
Try a longer screw then check if it's hitting anything. If it's not then you should be good to go.
Derby Bros Racing is offline   Reply With Quote
Old 03-07-2007, 12:08 PM   #7610
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Ok guys after hunting down a tuning issue today. Figured out it was my header weld , came loose a tad and was spewing air/fuel. At WOT the car would shutter in rpms.
After that Ive tried setting up the 2nd speed engagement and #1 its hitting very hard from the start. When holding the car it gives you a nice slap. Ive tried bringing the gap of the shoes as close as possible with the 2nd speed housing. I notice this creates a good gap in between the shoe itself , more than im used to on other cars. Is this right , does anyone have some reccomendations. Im going to move onto screwing the tension back on the 2mm screws. Im guessing this should help some. I built it as per the instructions at first and it was barely going into 2nd. Ive got stock gearing except for 18/24 pinions.
Ive got everything nearly perfect , ride height and tires are trued and ready. The only problem is my 2 rear tires that came with the kit are VERY wobbly , has anyone had any issue with the mugen tires such as this? Think they would be kind enough to send me a 2nd set? I want to try these tires and see how I like em , otherwise ill be running my usual stock.
Other than that the car is handling superb. I cant wait to race it next month.
Artificial-I is offline   Reply With Quote
Old 03-07-2007, 12:24 PM   #7611
rmdhawaii's Avatar
After that Ive tried setting up the 2nd speed engagement and #1 its hitting very hard from the start. When holding the car it gives you a nice slap. Ive tried bringing the gap of the shoes as close as possible with the 2nd speed housing. I notice this creates a good gap , more than im used to on other cars. Is this right , does anyone have some reccomendations. Im going to move onto screwing the tension back on the 2mm screws. Im guessing this should help some. I built it as per the instructions at first and it was barely going into 2nd. Ive got stock gearing except for 18/24 pinions.
Ive got everything nearly perfect , ride height and tires. The only problem is my 2 rear tires come out of the box VERY wobbly , has anyone had any issue with the mugen tires such as this? Think they would kinda enough send me a 2nd set? I want to try these tires and see how I like em , otherwise ill be running my usual stock.
I'm not sure if you caught some of the posts that I had with Jo G, but this is the formula for setting up the 2-speed correctly [ revised 9-MAR-07 ]:
Inner diameter of the 2-speed housing minus the outer diameter of clutch shoes (widest points) equals 0.4-0.6mm
These leaves a gap of 0.2-0.3mm between the 2-speed housing and shoe.
Full instrunctions on how to adjust the shoes will be up in a day or so, once I catch up with the rest of my life and have time to revise the first draft of the diagram. Too bad I don't have Photoshop at the office!
Old 03-07-2007, 12:33 PM   #7612
Francis M.'s Avatar
I would just go and loosen the 2mm tension screws on the side if you just want to car to shift earlier.
Francis M. is offline   Reply With Quote
Old 03-07-2007, 04:36 PM   #7613
Seisick's Avatar
i just placed the shoes and the housing without the engine, set the shoes ītil they touched the housing, at this point i backed up a quarter and that was it, dont know for sure how may .oommm are apart but almost 10 months withouth stripping a gear, even with a 2t split, 17/23 52 60 or any combination, by the way i use a dab o mugen super joint grease on the 2 balls and the 2 speed shoe adaptor, just to make them last longer, at least it works on the unis
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 03-08-2007, 02:52 PM   #7614
Moderator
Hay guys. Iam looking for some kawahara parts for the mtx-4 , who carries them? Specifically need the kawahara cf engine brace.
I tried rcmodel and they are out. Anyone else?
Old 03-08-2007, 03:14 PM   #7615
Bigbarn's Avatar
Why is it Kawahara parts are so hard to find? They apparently make great stuff that everyone loves. There should be a ton of dealers.
Good Luck AI, Sorry I cannot help
Bigbarn is offline   Reply With Quote
Old 03-08-2007, 03:18 PM   #7616
Seisick's Avatar
futaba pro shop and rc champ carry everything kawahara, both located in japan
HobbymaniA
GoT MuGeN?
Old 03-08-2007, 03:26 PM   #7617
do they have a list of items online?
Old 03-08-2007, 03:30 PM   #7618
Seisick's Avatar
no, they donīt, just write them a request for your wanted parts by email, include the part number from the kawahara page and they will let you know price and availabiliy, and forms of payment
HobbymaniA
GoT MuGeN?
Old 03-08-2007, 10:08 PM   #7619
chippy's Avatar
http://www.pro-s-futaba.co.jp/
Just fill out the online order form for international orders cant go wrong with this shop there awsome. Price and shipping
chippy is offline   Reply With Quote
Old 03-08-2007, 11:10 PM   #7620
RC=Realy_Costly's Avatar
Default type r myth????
hey mtx4 owners and onlookers!
i am very soon going to purchase one of these babies although am stalling because i have heard rumours of a type r soon 2 be released. does any1 no if this is true, and prices or what it hass different to the original?
RC=Realy_Costly is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
