Mugen MTX-4
#7591
Originally Posted by Roger
I mentioned this in my interview with you last year.
BTW: how this the racing this past weekend at Hawaii ?
.12 1/10th Sedan - 61
.12 1/10th Outlaw/Fuel Open - 14
.12 1/10th Stock Sedan (rubber tires) - 20
Weather was great, everything went smoothly (Thanks to Bobby and Brian Y) and the food at the banquet was delicious. Team Mugen provided some fantastic door prizes and one lucky person walked away with a brand new .12 Ninja combo.
Mike and Brian put on an impressive show. You just don't realize how fast someone can get around our track until you see it for yourself. Even at Mike's speed, I think his fastest lap time was something like 22.9 seconds (correct me if I'm wrong, I was kinda busy and didn't hear/see all your lap times). IMO, Mike and Brian should have swapped engines.
#7592
Originally Posted by rmdhawaii
The only issue I did have, was that I could never get the car to shift into 2nd gear. I was running the stock gearing and it seemed like I was turning out the clutch shoes to the point of almost dissembling it. The straight is about 150ft. Any suggestions? Thanks
If you would like to try mine...... I've been using the same clutch shoes for 2 years since MTX3 era. I usually put dab of super glue into the holes, let it dry, give silicone oil, and you can screw it.
out of topic: Back to early newbies days, I didn't notice the car is actually already in 2nd gear mode. My advice, you need to tighten the springs all the way first, and then release the spring tension by 15 minutes increments until you hear the 2nd gear engage.
#7593
Knack Racing
0.8M Bevel Diff Gear set
Anti roll bar
rear under plate
Anti roll bar
rear under plate
#7594
I know this request has almost certainly been made before but could someone help me out by posting the Mugen MTX-4 spring rates please (ft/lb would be ideal)
Particularly interested in the front spring's.
Thankyou for your help.
Menace
Menace
#7595
Thankyou sir.....
What a database of info' you have at your fingertips....lol
Do you feel the power? ...
Thanks again.
Menace
Thanks again.
Menace
#7596
Menace
Menace
#7598
Finished...
#7601
Originally Posted by jfro6512
Side note: If the weather holds up, i'll be at your track next monday.
#7602
#7603
hmm
i should be getting mine shortly
#7604
Rainer: You got any pix of the track. 22.9 seconds for a 1/10th is a HUGE track. Tell Reynold, Brian, and the gang I said Aloha.
#7605
The race was well done by bobby and his crew. They took really good care of us who are not from oahu with tent, table and chairs. I will be back next year with more Maui racers. Brian from Mugen was a character at the banquet . Mike and Brian represented Mugen very well.
Garett
Islandhobbies Maui
Garett
Islandhobbies Maui
