Old 02-20-2007, 11:00 PM   #7456
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
KidDynomite- Just read the site and man it's got great stuff on there. Now I have the car to relate to it and thats what makes it better. I'm already going to see if the shop here has the alum hex hubs and the extra parts to create the front diff. The thicker shock tower will be next,universals and from then on it'd be spare parts, spare parts, and more spare parts. Basically the recommended items will be bought in one shot if I can. To add to the collection I also dislike the position of the rear sway bar and will upgrade to the optional one. Other than that I'll do what others do - mostly race it stock. This car has potential as I run a stock MRX4 which I have no issues with...except for the fact I nearly got disqualified because it was too light?!
To all- If I do make the front diff...what's a good starting point since the rear has 10k? Should I change it all around? I'm waiting for a friend of mine to come on for his setup as he runs at the tracks I do, but any others will be appreciated. Also, I had to use an optional collet to install my Carlsen OS. Using this setup though now I'm not able to install any shims. The clutch feels nice and tight as the clutchbell can move outward VERY little. I was left with option when I had the Ofna CD3 PRO centax on that car and the R40. I had no issue though, so should it be the same with the Mugen - zero issue?
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 02-20-2007, 11:35 PM   #7457
stefan's Avatar
Send a message via AIM to stefan
50k front, 30k rear
stefan is offline   Reply With Quote
Old 02-21-2007, 07:00 PM   #7458
JetMD's Avatar
Someone asked this earlier but I didn't see an answer. Does anyone know what shore tires come with the MTX-4 kit? Thanks.
www.vorra.org
MINO Racing
JetMD is offline   Reply With Quote
Old 02-21-2007, 07:48 PM   #7459
HarKonnenD's Avatar
Stefan- Thanks. Also, how about if I ran the solid rear axle setup in the front what gear oil would you recommend then?
Old 02-21-2007, 07:52 PM   #7460
lil-bump's Avatar
Trader Rating: 83 (100%+)
I called Mugenusa and asked the question. I was told 40 shore front and rear
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 02-21-2007, 08:17 PM   #7461
rmdhawaii's Avatar
I run 30K front, 10K rear - same as I do in the RRR. I also use Kyosho diff oil. Just be prepared to try different combinations. We all run on different tracks.
I had the same problem with my TZ. I think the shaft is too short. To solve this problem, I sanded the collet by 0.2mm. Here is what I did:
I mounted the collet in the flywheel, put a 1-2 drops of after-run oil on 400 grit sandpaper, put the collet on the oil and then moved the flywheel in a small figure eight, eight times, applying a moderate amount of pressue. I then put a 1-2 drops of oil in another spot, rotated the flywheel 90-degrees and repeated the procedure until I shaved off the 0.2mm. Moving the flywheel in a figure eight and rotating it helps ensure that you don't create a high spot - well, that's the theory at least.
Hope this helps.
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 02-21-2007, 08:41 PM   #7462
SOLOARTIST 702's Avatar
Send a message via AIM to SOLOARTIST 702
Default hmm
just curious whos got the best deal on an mtx4 keep it on the low pm me with the details holla
RC AMERICA / XRAY / HUDY/ MATRIX TIRES /KOPROPO / ORCAN GT3 /RED CUP RACING MEMBER / SPEEWORLD RACEWAY/ A+ performance parts /IVE SEEN THE XRAY TEAM DRIVE SO I GOT XRAY CARS / better to keep up than to catch up
WILLIAM PENDERGRASS
SOLOARTIST 702 is offline   Reply With Quote
Old 02-21-2007, 10:44 PM   #7463
Thumbs down
solo you you better not!
Vone rrr evo. Sirio sti evo III. airtronics
pioneer is offline   Reply With Quote
Old 02-21-2007, 10:56 PM   #7464
nitro_moe's Avatar
If I remember correctly,, it comes with 35 shore tires
nitro_moe is offline   Reply With Quote
Old 02-22-2007, 12:06 AM   #7465
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
It used to come with 37's. They could change at any time.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 02-22-2007, 12:52 AM   #7466
jaykay's Avatar
high traction: 50.000 front and 30.000 rear
lower traction: 30.000 front and 10.000 rear
but not everytime diff-diff is the best combination
jaykay is offline   Reply With Quote
Old 02-22-2007, 12:58 AM   #7467
itchy b's Avatar
Diff - diff is not always the best combo
I alway thought that a one-way was a diff
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 02-22-2007, 03:45 AM   #7468
asw7576's Avatar
When using gear diff at front, does it matter to keep 1:1 ratio for tire split ? Or slightly overdrive or underdrive ? Let me remind you, rear tires usually wear faster than front. What expert suggest ? Tks.
Old 02-22-2007, 07:51 AM   #7469
JetMD's Avatar
They feel a little firm since I usually run 38's so 40's sounds about right. Thank you. I really appreciate it.
www.vorra.org
MINO Racing
Old 02-22-2007, 07:54 AM   #7470
Francis M.'s Avatar
You really need to measure your tire wear during qaulifying and you should decide on that. Look at your o/d chart and make sure to run the correct pulley when running tire splits.
Francis M. is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
