Old 02-12-2007, 06:33 AM   #7351
lil-bump's Avatar
Trader Rating: 83 (100%+)
RC nitronation has a good selection of Kawahara parts
Originally Posted by blanks596
can anyone tell me where I could find Kawahara parts in the US if possible?
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 02-12-2007, 06:49 AM   #7352
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Alright guys building my shocks. BTW love these shocks and how they are built. Very smart. I also used green slime on the o-rings.
Im going to be running a tight , parkinglot track that is semi-prepared and sugar on the surface. Its somewhat bumpy.
What shock oil should I use. I saw a mtx-4 setup sheet with Keisuke Fukuda on a somewhat tight , low traction bumpy track and he was using 40WT oil / # 400. Im thinking on going the same route.
What are your thoughts on this type of track. What do you find works well on this sort of track?
Artificial-I is offline   Reply With Quote
Old 02-12-2007, 07:27 AM   #7353
jaykay's Avatar
400 and 40 are not really the same. Use only the same shock oil producer.
yes, 400 mugen oil but he use in the front shocks a 1.3 hole a not like stock 1.2. I have tried this to and since them i only one this setup!
jaykay is offline   Reply With Quote
Old 02-12-2007, 09:58 AM   #7354
blanks596's Avatar
Trader Rating: 14 (100%+)
Can anyone tell me if Atomic is a reputable company? How do they compare to Kawahara after market parts ie-locking one-way axle, etc....?
Serpent/Desoto Racing
Max S
blanks596 is offline   Reply With Quote
Old 02-12-2007, 10:06 AM   #7355
rmdhawaii's Avatar
Do not get the Atomic Multi-diff. A number of people have had problems with this part.
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 02-12-2007, 10:11 AM   #7356
Moderator
LOL great. I asked this a few pages back and no one said anything. Its already on my car. I have a friend with one and its lasted ok.
I know 3racing makes one , at least it looks like it. They call it a one-way but I see the pins and holes for it to be setup as a spool. So if your gonna try one Id try that. It also seems this part is a few dollars cheaper too. Sometimes the hongkong shops just dont list items correctly. Otherwise it seems the kawahara is the best bet.
Old 02-12-2007, 11:25 AM   #7357
blanks596's Avatar
Thanx, they had the items I'm looking for.]
Thanx rmd...., I was almost going to purchase the Atomic multi diff
Max S
Old 02-13-2007, 12:24 AM   #7358
itchy b's Avatar
Sounds good Jaykay,
since you have changed over to the option 1.3mm shock piston, how have you found it to change the cars handeling compared to using the standard 1.2mm piston?
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 02-13-2007, 01:57 AM   #7359
AMGRacer's Avatar
I own an Atomic and mine is so far so good. I cant say how it compares to the kawahara, but I do think the Kawahara would be better from looking at the pics.
AMGRacer is offline   Reply With Quote
Old 02-13-2007, 02:32 AM   #7360
jaykay's Avatar
Originally Posted by itchy b
Sounds good Jaykay,
I felt the combination of 1.3 and #400 oil has changed the handling more, than when you only use for example 1.3 and #600 oil. The car has become more steering and it was easier but faster to drive.
Old 02-13-2007, 03:21 PM   #7361
jaykay's Avatar
So, it´s 22:54 o´clock here in Germany and I just finished just a little bit more of my mtx-4. Not very much, but close.
I decide to use the rubbel belt, because is much smoother than the urethan.
When I build my car, I pay attention always to it, that everything runs free and smooth. For example, the front lower arm has to fall directly, when you raise it with your finger. If that is not the case, often the pin does not run degrees from hole to hole. If you install the pin without the arm, you will notice what I mean (pic1). To correct this, just pull down the pin, and move the front mount with it. (pic2) Be attention, just a little bit. Then, check it again. Repeat it until the pin fits correct (pic3). Now the lower arms runs free.
(pic1)
(pic2)
(pic3)
So, that was all for today.
Old 02-13-2007, 04:01 PM   #7362
lil-bump's Avatar
Good deal, when I built mine I had to do the same thing but I ran a small round file inside both holes including the a-arm itself; to free up all movement in the a-arms (upper and lower). The next friction point you'll see is when you install the caster clips. again I hit the a-arm mount with a flat file. just don't get to happy with the file or you'll develop slop in the a-arms. ALL A-ARMS SHOULD FALL FREELY under their own weight. Make sure you check the arms individually ie. left side lower then the left side upper and again once the steering knuckle is attatched.
Elliott Hart
Serpent America
Desoto Racing Team
Old 02-14-2007, 03:42 PM   #7363
jaykay's Avatar
So, after Rocky I and II ( I was watching the film by the way) thats the actually building status. Nothing special to say. Just look, that everything runs free, especially the brakedisc. Sometimes the hole are to tight, so that it doesnt runs free. Just use a fine rasp to shape the holes.
As I told, I use rubber belts. This one are form Kawahara. The only thing I changed, are the rods of the rear anti roll bar. Normaly the connection between the anti roll bar and the rear lower arm is 38mm long. I use 41-42mm, because sometimes the bar hits the second speed house. But I use part no. H0857 because there are longer than the standard part and you still have the same stability.
So, of course tomorrow after Rocky III and IV I can tell you more.
Old 02-14-2007, 07:53 PM   #7364
blanks596's Avatar
So what are people's thoughts on the Winternats so far in regards our favorite team and favorite 1/10 car? I hope the team gets the kinks worked out tomorrow
Max S
Old 02-15-2007, 12:18 AM   #7365
stefan's Avatar
Send a message via AIM to stefan
I think it was a strange desicion to have Mikey only run 1/8th and not have Fukuda in Ft. Myers.
I know Ishitani is very good, but he'll have a hard time to get a foot on the ground against the large teams of Serpent and the Mugen B-team (Xray).
But then again, Mugen makes a lot of strange desicions IMHO!
Jakay, have you ever tried to put your car into the oven (Backofen) after you finished building it.
I usually put all my car in the stove for an hour at 80 degrees C. Takes all the tension out of the plastic parts and makes it run very free.
stefan is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
