Old 02-04-2007, 07:51 PM   #7261
dg8one's Avatar
anybody knows when airtronic will release this 2.4 GHz M11 Module and Receiver
Member of the CHEATERS CLUB
TEAM KAMIKAZE(MARYLAND CHAPTER)
TOKWA'T BABOY LTD
dg8one is offline   Reply With Quote
Old 02-05-2007, 01:14 AM   #7262
Kanea6's Avatar
Trader Rating: 7 (89%+)
i have a problem with my Mugen MTX-4 i have had the car for about 1yr now and it has started to strip gears. on a race meets i will probly strip about 4 spurs a race meet. The gears striping has cost me so many race wins. it has most recently cost me win in the c final in the summernats wollongong Australia. could some please help me fix this problem.
Xray RX8 - OS Engines, VP Fuels, Matrix Tyres, KO Propo
Xray NT1 - Novarossi, VP Fuels, Matrix Tyres, KO Propo
Xray X12- Hobbywing, Thunder Power, Much More, KO Propo, Hudy
Kanea6 is offline   Reply With Quote
Old 02-05-2007, 01:53 AM   #7263
gtrmx's Avatar
Originally Posted by Kanea6
i have a problem with my Mugen MTX-4 i have had the car for about 1yr now and it has started to strip gears. on a race meets i will probly strip about 4 spurs a race meet. The gears striping has cost me so many race wins. it has most recently cost me win in the c final in the summernats is wollongong Australia. could some please help me fix this problem.
I owned this car before and only stripped one gear. Let's get the obvious out of the way first. You are using new spurs and pinions, right? Worn out pinions will eat away your spur gears.
Second, you need to set the mesh a little on the tight side in this car. I used to set it so the mesh between pinions and spurs was barely free. I would say theeth were engaged about 90%. This is almost no play at all. The teeth will brake in a little after a few spins.
You have to be careful not to mount the engine diagonally, also check your 1st gear one-way. One friend of mine started stripping gears and only stopped once he changed his one way. This could very well be your problem as you state you did not see this happen before and such parts are subject to wear. How about your 2-speed shaft? It could be a little worn out, too.
I hope that helps.
gtrmx is offline   Reply With Quote
Old 02-05-2007, 02:00 AM   #7264
jca2000au's Avatar
Trader Rating: 9 (91%+)
Kane, just change the 2speed gear housing first. I striped my every 4 mins at the World Champ Brendale and that was brand new car too. I asked the MTX4 designer and he said change 2 speed housing first.
jca2000au is offline   Reply With Quote
Old 02-05-2007, 02:02 AM   #7265
sparksy's Avatar
Trader Rating: 14 (94%+)
Check the gap between the 2speed bell and the 2speed clutch. You have to keep adjusting the shoes so there is only a poofteenth of a gap. Any more than half a mm and the shoes hit the bell with alot more force. You want it as close as you can get it without rubbing, then your shifts are nice and smooth and not putting too much shock loading on the teeth.
I reset mine after every race day and have only ever stripped one gear. And that only stripped because I got the car airborn over a ripple strip and kept it nailed. The shock loading on the transmision on landing stripped it.
sparksy is offline   Reply With Quote
Old 02-05-2007, 04:41 AM   #7266
Originally Posted by FF25510
blue should be used for buggy, yellow should be the best but if you brake hard, try Kyosho APP pad (now i'm using). The stock disc should be fine If you wants to upgrade the brake system, KAWAHARA brake cam should be a must.
Hi,
I am curious to know the thickness and the material of Kawahara's.
Thanks!
ThunderTech is offline   Reply With Quote
Old 02-05-2007, 05:55 AM   #7267
@sd
Default Kfactory Brake Disc
Hi guys!
Anybody tried the Kfactory brake disc for mtx-4?
http://www.kfactoryracing.com/produc...1349&pageNum=1
Are they good? What about the quality?
Planning to upgrade the brake disc.
Thanks.
@sd is offline   Reply With Quote
Old 02-05-2007, 06:29 AM   #7268
FF25510's Avatar
Originally Posted by ThunderTech
Hi,
Thanks!
It is made of steel like the two speed shift and you can see the shape is different. Part no. K-869 only 525 yen
FF25510 is offline   Reply With Quote
Old 02-05-2007, 08:13 PM   #7269
Then how about the thickness of the disc?
Old 02-05-2007, 08:32 PM   #7270
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
Originally Posted by @sd
Hi guys!
Thanks.
I have one on my car. Its just fine.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 02-05-2007, 10:27 PM   #7271
C Verano's Avatar
Here is Mugen Driver Brian Thomas' paint scheme for his MTX-4 for the Winter Nats (JGO)
Mugen MTX-4-dsc02046.jpg   Mugen MTX-4-dsc02047.jpg   Mugen MTX-4-dsc02048.jpg   Mugen MTX-4-dsc02049.jpg
RC Target, Capricorn RC, Matrix Tires, KO PROPO America, PowerMaster Fuel, Absolute Hobbyz, Bellybutton Paint
C Verano is offline   Reply With Quote
Old 02-05-2007, 10:44 PM   #7272
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
The fading on that body is amazing. Good work.
Artificial-I is offline   Reply With Quote
Old 02-05-2007, 10:46 PM   #7273
itchy b's Avatar
Does anyone have the part number for the Mugen rear swaybar (blade type)?
Also the number for the new 2 hole clutch bell
Cheers
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 02-05-2007, 11:09 PM   #7274
jca2000au's Avatar
Cheers
- T0162 Rear Adjustable Anti-Roll Bar Set.
- 2 holes Cutch bell, i believe it is still the same part number but with new stock.
Old 02-05-2007, 11:30 PM   #7275
itchy b's Avatar
Thanks Jay,your a champ
EX1.5-SC10 4x4
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
