Old 01-14-2007, 02:23 AM   #7021
Roger's Avatar
Originally Posted by nitro_moe
I think FF25510 is reffering to what will be added to the WC Kit,
T0138: Front Upright (why use the same part that comes with it already??)
T0161: Not on the parts list..
T0142: Alluminum Wheel Hub(4 pcs)
Other than that, I couldn't make out a single word of what was written in German.
Those parts should read:
T0138B - this is the new front steering knuckles.
T0161 - rear upper arm mount. This is also a new item.
T0142 - aluminum wheel hubs.
http://nitrokb.netne.net/profiles/RogerSerafin.html
Roger is offline   Reply With Quote
Old 01-14-2007, 02:30 AM   #7022
Kanea6's Avatar
Trader Rating: 7 (89%+)
Heres what he said
from the Web:
MID presents: MTX-4 Champ Limited edition kit
MID Mugen Seiki presents the car to the WM 2006 Brisbane/Australia in the version of the current world champion Keisuke Fukuda.
Mugen Seiki celebrates the world champion!
The world champions - Upgrades!
The Limited edition kit contains numerous Upgrades opposite the Mugen Seiki MTX-4.
In detail kits belong to the WC:
T0138-B knuckle VA (changed oh geometry)
T0161 wishbone attachment hectar (changed oh geometry)
T0142 aluminum rim
photographs new WM decoration handmarked Ninja cap of the world champion above
The MTX-4 in the Champ Limited edition is immediately under the art. NR. T0050WC available.
Xray RX8 - OS Engines, VP Fuels, Matrix Tyres, KO Propo
Xray NT1 - Novarossi, VP Fuels, Matrix Tyres, KO Propo
Xray X12- Hobbywing, Thunder Power, Much More, KO Propo, Hudy
Kanea6 is offline   Reply With Quote
Old 01-14-2007, 02:31 AM   #7023
Seisick's Avatar
looks like the stock plus alum hexes, new rear upper mount and new front
uprights, and a hat,
my wishes for the R or prospec version
wishing for it since I've got 2 rrr owners and 3 mtx3 desiring to switch to the full version whenever comes out
1 new front uprights
2 new rear mounts
3 front and rear unis
4 rear blade roll bar
5 yellow clutch
6 ultra hard spring
7 4mm rear shock tower
8 one piece engine mount
9 alum hexes
10 titanium set screws a and b
11 light weight pulluys and brake pulley
12 4mm chasis
13 hollow or light rear shaft
14 titanium middle shaft, hollow or harden aluminum
15 light first and second gear hub
16 light flywheel and clutch bell
17 rubber belts
18 kawahara type one way, soid axle and front diff
19 titanium pillow balls
that's it, up to $550 600 for a kit that has more than 250 in upgrades
it's a bargain!
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 01-14-2007, 03:31 AM   #7024
madbeats's Avatar
Default Translation MID presents: MTX-4 Champ Limited edition kit
Originally Posted by FF25510
from the web :
MID präsentiert: MTX-4 Champ Limited Edition Kit
MID Mugen Seiki präsentiert das Auto zur WM 2006 Brisbane / Australien in der Version des aktuellen Weltmeisters Keisuke Fukuda.
Mugen Seiki feiert den Weltmeister!
Die Weltmeister - Upgrades!
Der Limited Edition Kit enthält zahlreiche Upgrades gegenüber dem Mugen Seiki MTX-4.
Im Einzelnen gehören zum WC Kit:
T0138-B Achsschenkel VA (geänderte Achsgeometrie)
T0161 Querlenkerbefestigung HA oben (geänderte Achsgeometrie)
T0142 Aluminium Felgenaufnahmen
Neues WM Dekor
Handsignierte Ninja Kappe des Weltmeisters
Der MTX-4 in der Champ Limited Edition ist ab sofort unter der Art.-Nr. T0050WC erhältlich.
MID Mugen Seiki presents the auto to the WM 2006
Keisuke Fukuda.
Mugen Seiki celebrates the world champion! The world champions -
Upgrades!
Seiki MTX-4.
T0138-B knuckle VA (modified oh geometry)
T0161 wishbone attachment hectar (modified oh geometry)
T0142 aluminum rim accommodations new WM
The MTX-4 in the Champ Limited edition is off immediately under
Serpent 966/720 Mugen MTX4R Xray NT1-Mugen MTX-4 Knack R conversion Hong Nor X1CR
madbeats is offline   Reply With Quote
Old 01-14-2007, 05:18 AM   #7025
itchy b's Avatar
Thanks for the translation Manbeats
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 01-14-2007, 01:05 PM   #7026
rmdhawaii's Avatar
Three parts and a hat? That's it? That's just too funny.
Just goes to show you how good the car is out of the box.
Code:
T0138B  NEW FRONT UPRIGHT MTX-4          $5.19
T0161  	NEW GRAPHITE REAR UPPER ARM     $11.99
T0142  	ALUM WHEEL HUB (4pcs)  	    	$16.79
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 01-14-2007, 02:16 PM   #7027
AMGRacer's Avatar
Originally Posted by sparksy
Its good to know what the fast guys setups are. Some copy them exactly to see how the car feels, short cut the time to finding a setup that works etc.
Others like to know what the setup is and work out why they have done certain settings. It doesnt hurt, and its a good way to figure out what things do.
QFT. I love to see the pro setups to see what directions they take in setting their cars for a particular circumstance. I have learned quite a few useful tricks from this. Do I copy their setups exactly, no. My driving style is possibly different, but it good baseline info.
AMGRacer is offline   Reply With Quote
Old 01-14-2007, 02:19 PM   #7028
AMGRacer's Avatar
I can tell you T0161 is unreal on long sustained corners. It was the thing I could feel making the biggest difference.
Old 01-15-2007, 12:01 AM   #7029
itchy b's Avatar
Code:
You ain't just whistling Dixi bud
EX1.5-SC10 4x4
Old 01-15-2007, 12:04 AM   #7030
itchy b's Avatar
What difference did it make compared to the original one and was this at brendale with high traction or another surface?
I got these parts last sep but haven't got around to trying them yet.
EX1.5-SC10 4x4
Old 01-15-2007, 08:37 AM   #7031
Big Jeff BBQ's Avatar
JUST WONDERING IF ANYBODY HAS WORKED ON LAYING THE MOTOR DOWN
IN THE MUGEN ?
WITH ALL THESE CNC MACHINES IDLEING AROUND !
I SEEN PIC'S OF ONE BUT IT LOOKED KINDA RIGGED.
SEEMS SIMPLE NEW SET OF MOTOR BLOCKS AND SOME KINDA NEW BRACE
FOR THE MOTOR !
JUST THINKING OF SOMTHING NEW !
L8TER
JEFF E
Blowin' Smoke BBQ
Special Thanks To:
Steve Pitts
Kevin Hutchinson
Big Jeff BBQ is offline   Reply With Quote
Old 01-15-2007, 10:13 AM   #7032
YBSLOW's Avatar
Any pictures of this part? I looked on Mugens US site and could not find it?
YBSLOW Racing
RC Target - Capricorn
HOTRACE Tyres, Tru Source, Fantom
POWER MASTER Fuel, 2mm Designs
Protoform Bodies, Avid Bearings, AMR Engines
YBSLOW is offline   Reply With Quote
Old 01-15-2007, 11:38 AM   #7033
rmdhawaii's Avatar
You can find a good photo of T0161 here: http://shopping.rcmodel.hk/product_i...oducts_id=9597
Old 01-15-2007, 11:43 AM   #7034
ira
ira's Avatar
Trader Rating: 18 (100%+)
Here you go bro.
RC AMERICA, XRAY, FUTABA, O.S. ENGINES, BYRON FUELS, SPEEDWORLD RACEWAY, HOBBICO, MATRIX TIRES...
ira is offline   Reply With Quote
Old 01-15-2007, 11:47 AM   #7035
YBSLOW's Avatar
Originally Posted by ira
Here you go bro.
Thanks Ira!
Is it shorter so you can make the upper arms longer or what?
YBSLOW Racing
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
