Old 01-09-2007, 06:32 AM   #6976
itchy b's Avatar
Welcom to Mugenville to you Nitrogasm
fine choice of car too
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 01-09-2007, 09:08 AM   #6977
Bigbarn's Avatar
Originally Posted by chippy
As for 3 racing products a good rule is if it is a moving part dont use them
I used them on my MTX3 and they where s--t
Also the spring steel in there sway bars a very brittle
Hope this helps
I just ran the LIghtened Clutch Bell from 3 Racing this past weekend. After I ripped up two bearings inside said clutch bell I went back to the Mugen one. 3 Racing is cheap and you get what you pay for.
Bigbarn is offline   Reply With Quote
Old 01-09-2007, 09:59 AM   #6978
Seisick's Avatar
been using the 3 racing clutch bell with three duratrax bearings,
both products are cheap but no problems so far for the last 6 months
I do lubricate the bearings with light oil every other race meeting, so far no slop
but I do rotate the 3 of them
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 01-09-2007, 01:58 PM   #6979
dg8one's Avatar
same here i been using the 3R for the whole season last year and no problem
Member of the CHEATERS CLUB
TEAM KAMIKAZE(MARYLAND CHAPTER)
TOKWA'T BABOY LTD
dg8one is offline   Reply With Quote
Old 01-09-2007, 02:12 PM   #6980
Bigbarn's Avatar
I'm glad you guys have had better luck. I had new bearing in there and that didn't matter. I shimed it correctly and checked the play compared to the Mugen stock part. All seemed correct. However, when I took it off after a 5 min run there were balls everywhere.
Oh well
Old 01-09-2007, 03:26 PM   #6981
Seisick's Avatar
a 5x7x0.1mm shim between the two inner bearings helps, perhaps
the bearings of the engine are tired, or the endplay or gap was
too big, will try to use the yeah racing bell which is lighter, IŽll see how it performs later
HobbymaniA
GoT MuGeN?
Old 01-09-2007, 03:30 PM   #6982
Seisick's Avatar
Originally Posted by Nitrogasm
hi all mugenites , been some years since racing and recently got bit again by the nitro bug . so after a short bit of research i decided on the 1/10 nitro touring car class and the easy car choice after doing some research was the mtx-4
what sold me was hearing how bullet proof strong the car is and mostly the support behind the car .
the car should be here in a days or so and i already secured the recomended mods plus a huge pile of extra hop ups and spares in a sweet deal i couldnt pass up even if some of the hop ups wont be used . i like to stay as stock as possible for the most part
i am based in norcal and will be joining the fun at speedworld raceway with the rivercity rc guys as soon as i build the car
i wish to thank this forum in advance for the help i already found and the future questions im sure to have .
cheers,
nitrogasm
make sure you use a 5x8x0.5mm shim between the 6x13 bearing and the pin on the uprights, besides adding some offset, it will prevent the wear on the plastic hexe, no need to get aluminum and lighter weight!
happy racing
HobbymaniA
GoT MuGeN?
Old 01-09-2007, 04:53 PM   #6983
madbeats's Avatar
Default ProE Welcome to Da world of MTX4
ProE am glad you got the mugen MTX4 wish you well enjoy your car .
Here are some pic's of my car..
Mugen MTX-4-mtx4-chassis-1.jpg   Mugen MTX-4-mtx4-chassis-2.jpg   Mugen MTX-4-mtx4-front-1.jpg   Mugen MTX-4-mtx4-front-2.jpg
Serpent 966/720 Mugen MTX4R Xray NT1-Mugen MTX-4 Knack R conversion Hong Nor X1CR
madbeats is offline   Reply With Quote
Old 01-09-2007, 08:51 PM   #6984
Bigbarn's Avatar
I like the key set next to the car for "Scale"
Old 01-10-2007, 07:14 AM   #6985
Could someone tell me what are the advantages and cons of using aluminium pulleys instead of plastic?
Thanks.
TomiRC is offline   Reply With Quote
Old 01-10-2007, 08:57 AM   #6986
Big Jeff BBQ's Avatar
I personaly only use alum where it cant stress or get bent!
it may be lighter but you cant tell when it's got tweek in it.
so i stick to plastic mostly but some alum where i can.
l8ter
Jeff
Blowin' Smoke BBQ
Special Thanks To:
Steve Pitts
Kevin Hutchinson
Big Jeff BBQ is offline   Reply With Quote
Old 01-10-2007, 08:59 AM   #6987
sorry i did not see the word pulley there !
thats diffrent pullys dont wear out as quick and are lighter and stronger.
later
Jeff
Blowin' Smoke BBQ
Special Thanks To:
Steve Pitts
Kevin Hutchinson
Old 01-10-2007, 09:45 PM   #6988
Thanks for the info Jeff!!
Old 01-12-2007, 01:35 AM   #6989
Trader Rating: 52 (98%+)
Default Has anyone tried the 3 racing harden alum pinion gear
Has anyone tried the 3 racing harden alum pinion gear? The stock mugen pionon gear wears out too quickly and then it stripes the 2nd gear.
I know their blue plastic gear sucks, (I tried them and they are not round).
straightaway is offline   Reply With Quote
Old 01-12-2007, 01:54 AM   #6990
nitro_moe's Avatar
Haven't tried their alum pinions, but I can pretty much advise you to go with steel instead of alum. It lasts longer and is easiear on the spurs. It doesn't get as sharp as alum and strip the spurs. Unless you're racing, then it's a different story. I only use original Mugen steel pinions.
Good luck..
nitro_moe is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
