Old 11-22-2006, 02:17 PM   #6796
madbeats's Avatar
Default Check this part out
aluminium bulk upper
Serpent 966/720 Mugen MTX4R Xray NT1-Mugen MTX-4 Knack R conversion Hong Nor X1CR
madbeats is offline   Reply With Quote
Old 11-22-2006, 03:12 PM   #6797
Slo-MTX4's Avatar
Send a message via ICQ to Slo-MTX4
Originally Posted by lil-bump
I just finished building my Mtx-4 and decided to start the engine. I then notice it looks liked my clutch bell somewhat wobbles. Well after investigating I found that the inner two bearings in the clutch are migrating out of the clutch bell so when the clutch engages the only bearing holding the clutch bell centered is the out most bearing. Just looking for any ideas or if some one has seen this. I might swab the inner race of the clutch bell with just a little lock tight and then install the inner two bearings to try to keep them inside the clutch bell when the clutch ingages. This might attribute to stripped gears if the clutch bell is allowed to wobble.
Sounds like you have way too much end play on the clutch bell.
Podified Picco/MRX5/Futaba/Savox
PODIFIED ENGINES/Trackside RC
Slo-MTX4 is offline   Reply With Quote
Old 11-22-2006, 03:38 PM   #6798
Car Breaker's Avatar
it look nice and heavy , who make it ?
Xray X12 2015
ARC R10 ATS
Car Breaker is offline   Reply With Quote
Old 11-22-2006, 05:59 PM   #6799
lil-bump's Avatar
Trader Rating: 83 (100%+)
My end play is set at .2mm. I use feeler gauges to check the gap between the thrust bearing and clutch bell. That what is was before I started the engine I'll check it again.
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 11-22-2006, 06:10 PM   #6800
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Actually, I think you mentioned something very interesting. I noticed the wobble from my clutch but I have not had any issues with stripping gears. However, to enough of a degree, the wobble could be the culprit of mysterious gear stripping affected some of us.
What I noticed is that if I shim the inside of the clutch bearings out enough to avoid clutch bell drag, the innermost clutch bearing may not be fully seated in the clutchbell.
Racing4Evo is offline   Reply With Quote
Old 11-22-2006, 10:04 PM   #6801
lil-bump's Avatar
The way i think it should work is the bearings should be captured inside the clutch bell with maybe a snap ring and the movement of the clutch should come from the inner race of the bearing moving on the engine crankshaft.
Not the clutch bell moving on the outer race of the bearings.
just my two cents
Elliott Hart
Serpent America
Desoto Racing Team
Old 11-24-2006, 12:06 AM   #6802
Default over drive?
What front pulley is the over drive pulley the 24t or 25t?
I thought that the standard 25t pulley is over drive allready?
does the 24 over drive it more.
Im tyring to work it out but my brain is not working right today.
ragent is offline   Reply With Quote
Old 11-24-2006, 12:34 AM   #6803
24t give you more spin in the front.
Xray X12 2015
ARC R10 ATS
Old 11-24-2006, 01:08 AM   #6804
Hi guys,
What's the general consensus in regards to the 4 mm chassis? I would prefer the chassis to be recessed to maintain the existing roll centres, so I guess that excludes all but the Mugen or Kawahara (please correct me if I am wrong). I know the Mugen chassis is not compatible with a monoblock engine mount, so I am currently considering the Kawahara. Has anyone had any positive experiences with a particular chassis?
Thanks in advance.
SNACKPACK is offline   Reply With Quote
Old 11-24-2006, 01:13 AM   #6805
chookgb's Avatar
Trader Rating: 26 (100%+)
Originally Posted by SNACKPACK
Hi guys,
Thanks in advance.
yes go for either the mugen or kawahara i have had both the kawahara can be sourced cheaper than the mugen one and as you say is one piece compatable and also has some nice milling features on it
chookgb is offline   Reply With Quote
Old 11-24-2006, 01:15 AM   #6806
Thank's for your reply Greg, I think I will try the Kawahara.
Old 11-24-2006, 01:21 AM   #6807
keep in mind snackpack sometimes the mugen 4 handles better with a 3mm chassis.
if you are on a small to med track with normal to low grip, maybe a 3mm chassis wil be better suited
TomB is offline   Reply With Quote
Old 11-24-2006, 01:27 AM   #6808
chookgb's Avatar
i have run my car on the above tracks with both the 3mm and 4mm chassis and the car handles as good or better with the 4mm chassis as always it is all in the car setup.also the extra stiffness is invaluable to ensure the 2nd gear problems are reduced
Old 11-24-2006, 01:33 AM   #6809
All very valid points, thank's for the input guys.
Old 11-24-2006, 04:53 AM   #6810
lil-bump's Avatar
From the stock setings. What is a ball park setting for the two speed clutch.
Elliott Hart
Serpent America
Desoto Racing Team
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
