Old 10-31-2006, 12:04 PM   #6691
Osiris 75's Avatar
Trader Rating: 17 (100%+)
Maybe I should have greased my 2 speed bearing??
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS
RC TARGET/CAPRICORN USA / REFLEX RACING / ULTI TIRES
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old 10-31-2006, 12:12 PM   #6692
asw7576's Avatar
even if you grease so much to 1st one way bearing or 2nd gear bearing, If the gear mesh are not properly aligned, the stripping problem will be there.
Watch carefully the clutchbell could be touching 2nd spur gear ( usually happen when spur gear and pinion gear are worn out ).
The 2nd spur gear could be touching the engine brace ( the plastic part that connect rear bulkhead to upper deck ).
Old 10-31-2006, 02:06 PM   #6693
Osiris 75's Avatar
If the 2nd spur gear is touching the engine brace, how can I fix that? If I shim it, would it have a performance impact?? Because I do notice that it does touch barely.
Chris Kemper
Old 10-31-2006, 06:45 PM   #6694
wallyedmonds's Avatar
I cured my traction roll problem with softer springs ( purple 1.6 ), more front camber like 2.5 degree, and rear camber 4 degree.
yep this helped me to,i started at 2 and 3.
wallyedmonds is offline   Reply With Quote
Old 10-31-2006, 06:52 PM   #6695
Originally Posted by THE DOCTOR
I think that you can take the shims out from under the front upper A arms and that will help the roll overs also.
ya this will help and it will help in the chicanes,and make the car more responsive.
Old 10-31-2006, 06:56 PM   #6696
itchy b's Avatar
taking the shims out of the front upper arms it would increase the steering and make the rollovers worse
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 10-31-2006, 07:05 PM   #6697
i did not find this, but i do run on a small track so the speed may not be fast enuf,on a big track i do run 2mm. a higher RC will help TR. for me anyways.
Old 10-31-2006, 07:06 PM   #6698
richey's Avatar
Send a message via MSN to richey
Default Kawahara
If anyone is looking for the rear Adustable sway bar i have a couple instock. I have a limited supply. If you want one pm me.
Silver Bowl Raceway Operator
www.TeamTaylorRacing.net
Byron's Fuel, Airtronics
JoshStevensFoundation.org
richey is offline   Reply With Quote
Old 10-31-2006, 07:42 PM   #6699
asw7576's Avatar
You can dremel / take off some plastics from the brace where it touches.
or
You can use 0.2mm shim in place between bearing and the pin on the main shaft pulley . ( check your main shaft bearings and rear diff bearings for smooth operation. they need more frequent maintenance ).
Beef up the rear bulkheads & engine mounting with longer screws.
Old 10-31-2006, 08:30 PM   #6700
Osiris 75's Avatar
or
Thanks!!
Chris Kemper
Old 10-31-2006, 10:38 PM   #6701
Car Breaker's Avatar
This shim works, I have them in my MTX4 just incase
6x10mm Washer/Shim
Xray X12 2015
ARC R10 ATS
Car Breaker is offline   Reply With Quote
Old 11-01-2006, 02:15 AM   #6702
itchy b's Avatar
6x10mm Washer/Shim
did you already get yourself a mtx4 CB?
good to see you finally came round
EX1.5-SC10 4x4
Old 11-01-2006, 02:22 AM   #6703
asw7576's Avatar
6x10mm Washer/Shim
How is your G4S ? Do you like MTX4 more ?
Old 11-01-2006, 02:26 AM   #6704
rcabj's Avatar
ASW 7576...i pm U...
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 11-01-2006, 07:46 AM   #6705
@sd
Hi guys!
The bearing in my 2nd gear housing wobbles. Do I need to change the whole 2nd gear housing? Can I just change the bearing in the 2nd gear housing?
Your feedback would be appreciated.
Thanks!
@sd is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
