Old 10-30-2006, 09:11 PM   #6676
Tag
Tag's Avatar
Trader Rating: 31 (100%+)
hi Scott , how about if i move up the rear shocks or lay down the front ? will it help ?
Originally Posted by Scott Fisher
Traction rolling... This is something I am very good at. I like a car that has a lot of steering, because I drive with a jerky motion. I am not that smooth with the steering input. While I use a combination of things to try and eliminate traction rolling, I would use the following things most/all of which have been mentioned.
1. Make your tires smaller. At Revelation raceway (low tire wear, very very very very very high traction) in Cal I have started races with my front tires as small as 55.5mm.
2. Harder tires. This helps a lot too.
3. Stiffen front sway bar.
4. Adjust front upstops so there is very little room for a-arm movement.
While in theory the stiffer springs should help, I have always found when I put stiffer springs on the car traction rolls easier... especially in areas where you are changing directions quickly and often (chicanes, etc).
* Serpent 966 TE Novarossi 35+21, Airtronics M12 *
Tag is offline   Reply With Quote
Old 10-30-2006, 10:10 PM   #6677
itchy b's Avatar
moving the rear shocks up will decrease rear grip
Moving the front shocks down will increase front grip
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 10-30-2006, 10:15 PM   #6678
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
What itchy says goes for me. I think if you do these things you will make the traction rolling worse. I have also found that shock postion changes are subtle. When traction rolling is a problem, the tire size and shore are the most effective ways to cure that problem.
I see Jose lurking around in here. I think we should get the perspective of a factory Mugen driver
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 10-30-2006, 10:17 PM   #6679
JOSE CASAS's Avatar
what do you guys do when experience traction rolling besides using harder compound ? will reduce rear droop do the trick or laying the rear shock down ?
hi Tag next time you are at the track try this run your tires small about 56.5 through 57.5 fronts .Then depending on over drive pully set rear tires acordily. This is the trick when you cut your front tires do not round the edges and see what happens .This works very well fof me
RC America / XRay / Hudy / SRC / Ulti tires / Kopropo / Black Fabrica / Red Line fuel
JOSE CASAS is offline   Reply With Quote
Old 10-30-2006, 10:21 PM   #6680
I told you we needed the perspective from a factory driver!!! And he delivers
Old 10-30-2006, 10:22 PM   #6681
JOSE CASAS's Avatar
HEY WHATS UP SCOTT!
Old 10-30-2006, 10:26 PM   #6682
asw7576's Avatar
I cured my traction roll problem with softer springs ( purple 1.6 ), more front camber like 2.5 degree, and rear camber 4 degree.
Old 10-31-2006, 05:08 AM   #6683
Trader Rating: 15 (100%+)
I think that you can take the shims out from under the front upper A arms and that will help the roll overs also.
THE DOCTOR is offline   Reply With Quote
Old 10-31-2006, 06:10 AM   #6684
does anybody in the usa stock the kawahara k883 spool/front one way for the mtx4 ?
H STAMEN is offline   Reply With Quote
Old 10-31-2006, 06:14 AM   #6685
YBSLOW's Avatar
I just got one from RCNITRONATION.
YBSLOW Racing
RC Target - Capricorn
HOTRACE Tyres, Tru Source, Fantom
POWER MASTER Fuel, 2mm Designs
Protoform Bodies, Avid Bearings, AMR Engines
YBSLOW is offline   Reply With Quote
Old 10-31-2006, 08:47 AM   #6686
Osiris 75's Avatar
Trader Rating: 17 (100%+)
I just had my first Regional race this weekend, and made it to the 40 minute A-Main!! All of my Qualifiers went fine, other than hitting the wall a few times. But, only 2 minutes into the main, I started stripping gears, and not knowing why. I used a brand new red clutch shoe for the weekend in my Sirio, but did not know that I had to re-adjust my clutch after breaking in the shoe.. I honestly had no idea that I had to do that. I noticed that when I was replacing my spur gears with the engine running, the clutch bell was contantly spinning, so when i would hit my breaks, it would rip up both of my spur gears. Was the cause of this situation me not reajdusting my clutch by adding shims, or was it something else? And for all of you sportsman out there, please pay attention to the replies so this doesn't happen to you!!
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS
RC TARGET/CAPRICORN USA / REFLEX RACING / ULTI TIRES
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old 10-31-2006, 09:01 AM   #6687
Thumbs up
It sounds like your clutch-bell was locked. Its important to shim it right and before your start the motor, make sure everything spins backward free of friction. Also, when you grab your clutch-bell and try to push it in and pull it out, before mounting it to the car, there should not be that much play. Very little. And stay ontop of the thrust-bearing.
mgreen is offline   Reply With Quote
Old 10-31-2006, 09:10 AM   #6688
ira
ira's Avatar
Trader Rating: 18 (100%+)
Sounds like you have a locked up clutch, or a bad bearing.
You do need to re-adjust the clutch after the shoe breaks in, check it after every run. It should be completely seated (broke in) to the clutch bell after about 3 to 5 runs.
RC AMERICA, XRAY, FUTABA, O.S. ENGINES, BYRON FUELS, SPEEDWORLD RACEWAY, HOBBICO, MATRIX TIRES...
ira is offline   Reply With Quote
Old 10-31-2006, 10:23 AM   #6689
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to rcfoolz
I don't think that its so much that the clutch is locked up, but the 2 speed might be locked. If its stripping both gears, check that the 1 way for first is free and then the 2 speed is set propperly
Am I going back racing?...Hmmm.. Not anytime soon... But soon enough.
rcfoolz is offline   Reply With Quote
Old 10-31-2006, 11:54 AM   #6690
asw7576's Avatar
There is possibility of shifting engine location after few hits to wall. Need engine re-alignment again, and try spin test for spur / pinion gears.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
