Old 10-29-2006, 08:04 AM   #6661
Seisick's Avatar
for those with no desire to switch to alum. hexes, part hpi z694 5x10x0.5mm shim works very nice specially when the plastic hexes (shim edge within the hexe) is wore. it also adds offset to your tires.
happy racing
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 10-29-2006, 01:36 PM   #6662
asw7576's Avatar
Just got back from China and HongKong holiday...... it was nice. I bought some spare parts for MRX4-R, KO Propo Servos, Futaba receivers & crystals from RC Mart in Kwun Tong and City Hobby in Mongkok. The selling price is cheaper than in my country even without discount. I'm surprise RC shops in HK are not many and they don't carry large inventory like in Japan. Make sure you know what to buy and you know the market price..... otherwise you could be "nice dinner" for them.
I don't know the place to buy RC cars in Shanghai
Old 10-29-2006, 07:27 PM   #6663
Tag
Tag's Avatar
Trader Rating: 31 (100%+)
what do you guys do when experience traction rolling besides using harder compound ? will reduce rear droop do the trick or laying the rear shock down ?
* Serpent 966 TE Novarossi 35+21, Airtronics M12 *
Tag is offline   Reply With Quote
Old 10-29-2006, 09:06 PM   #6664
Default sway bar
THANKS A LOT FOR YOUR COMMENT SCOTT.
[QUOTE=Scott Fisher]I never said a blade was bad. I definitely agree that the blade is easier and definitely easier to adjust in short order. One thing I have found with blade sway bars is most people tend to only have 3 settings. Flat, 45deg, straight up and down. With the wire bars I have 5 (I think its five??) different choices and they are quite consistant. Really I got them because they were a lot cheaper to just get the wire bars.
Regarding making grey market purchases vs getting them from the US dist. It might be cheaper in some cases to get stuff from overseas. I just try whenever possible to support the networks setup to service my area. If a part is missing or bent etc.... it is always going to be easier to deal with someone here that you can just pick up the phone and deal with. Like I said I always try to support the people that are here to support me.[/QUOTE
speed is offline   Reply With Quote
Old 10-29-2006, 09:17 PM   #6665
Default traction roll
can do a lot of remedy on traction rolling. one is lower down your ride ht.
two is use harder springs. three is use harder tyres. 4 is increase strg of your
car. 5 is adjust your driving style (make all turns smoother in your strg wheel).
6 is check the tyre difference of your tyre(it should be the recommended tyre
size, you might be starting with a very big tyre also). 7 is check the tweak of
car if ony one side is having a traction roll. 8 is copy the setup of a sponsor
player
Old 10-30-2006, 02:46 AM   #6666
player
during hte worlds at Brendale QLD, Australia the drivers would put very thin shock oil with a open type piston and a hard spring. the theory being it shifts the weight back up quicker than a higher viscosity shock oil making the car less nosey and shifting the weight back up to a "flat" car position quicker.
another trick is to run higher front ride height as compared to the rear, and double check the track width is as wide as possible.
TomB is offline   Reply With Quote
Old 10-30-2006, 03:05 AM   #6667
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to rcfoolz
traction roll comes from too much roll in the car with too much side bite from the tires. Lets say your using 40's and the car is rolling over in the corners. try using super glue on the sidewall of your front tires. Another is to stand the front sway bar strait up and down with some harder springs. You can also use smaller tires.
Am I going back racing?...Hmmm.. Not anytime soon... But soon enough.
rcfoolz is offline   Reply With Quote
Old 10-30-2006, 11:03 AM   #6668
lil-bump's Avatar
Trader Rating: 83 (100%+)
Default mtx-4 front diff
I currently have a mtx-3 prospec and I'm moving up to the mtx-4. My question is; it looks like I can take all of the internals of the rear diff of the mtx-3 and use them in the front diff of a mtx-4. I'm not sure if the mtx-4 comes with the front diff housing and pulley. Anyone have any comments on this idea?
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 10-30-2006, 11:28 AM   #6669
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
Traction rolling... This is something I am very good at. I like a car that has a lot of steering, because I drive with a jerky motion. I am not that smooth with the steering input. While I use a combination of things to try and eliminate traction rolling, I would use the following things most/all of which have been mentioned.
1. Make your tires smaller. At Revelation raceway (low tire wear, very very very very very high traction) in Cal I have started races with my front tires as small as 55.5mm.
2. Harder tires. This helps a lot too.
3. Stiffen front sway bar.
4. Adjust front upstops so there is very little room for a-arm movement.
While in theory the stiffer springs should help, I have always found when I put stiffer springs on the car traction rolls easier... especially in areas where you are changing directions quickly and often (chicanes, etc).
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 10-30-2006, 03:42 PM   #6670
is there an aluminum insert for the front dif to make a solid front available ? i keep stripping the original plastic insert that comes with the kit
H STAMEN is offline   Reply With Quote
Old 10-30-2006, 03:47 PM   #6671
itchy b's Avatar
the best option for you is to go and get the Kawahara front 1 way/spool comination diff, as that will solve all your issues and is much quicker to change back and forth
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 10-30-2006, 03:49 PM   #6672
Seisick's Avatar
internal are the same except, the kit comes with the housing and pulley, just beware that unlike the mtx2, the 4 comes with one way pully and diff the same, if you glue it to use the one way, youll need another for the front.
happy racing
HobbymaniA
GoT MuGeN?
Old 10-30-2006, 04:58 PM   #6673
lil-bump's Avatar
I didn't know that. So if I understand the kit only comes with one pully to use with either the diff set-up or the one-way set-up.
Elliott Hart
Serpent America
Desoto Racing Team
Old 10-30-2006, 08:26 PM   #6674
wallyedmonds's Avatar
this is so true, thiner oil and stiffer springs iv found make the car lose forward grip,
wallyedmonds is offline   Reply With Quote
Old 10-30-2006, 08:31 PM   #6675
3racing has one but what ichy said is far better thing to do
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
