Old 10-19-2006, 03:23 AM   #6541
sparksy's Avatar
Trader Rating: 14 (94%+)
I actually feel dumber reading your last few posts ASW.
The CG can move. It is not a fixed point.
sparksy is offline   Reply With Quote
Old 10-19-2006, 03:34 AM   #6542
sparksy's Avatar
Run a lower ride height and you will lower your CG.
Place lead weights on your chassis and you will lower your CG.
Remove weight from the upper deck and you will lower your CG.
Switch to a different brand of radio gear and you will move your CG, not always up or down but sideways too.
Old 10-19-2006, 03:37 AM   #6543
asw7576's Avatar
Given the fix location of upper deck and fix location to put all the hardwares ( not to mentioned those hardwares are bolt on to upper deck ) please explain to me how are you going to change the CG of the car ?
Old 10-19-2006, 03:38 AM   #6544
asw7576's Avatar
My goodness.... you are so fast to answer before my questions.
Old 10-19-2006, 03:53 AM   #6545
rmdhawaii's Avatar
This will help clarify the center gravity issue for everyone:
http://members.aol.com/sccacuda/cars/4SmthTa.html
Additional Resources/Examples:
http://www.nesea.org/transportation/...0via%20EVC.pdf
http://www.longacreracing.com/articles/text/CGH_p.htm
It would be good if everyone tried to help each other understand how these things work, instead of arguing who is right and who is wrong.
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 10-19-2006, 03:57 AM   #6546
I will try Ti screws and lightweight gear houses.
Which do you use clutch shoe?I use only black one.I think Red clutch shoe more durable than yellow and black.But their clutch grab different.
mydo84 is offline   Reply With Quote
Old 10-19-2006, 04:10 AM   #6547
wallyedmonds's Avatar
Originally Posted by Scott Fisher
The CG of the car is not fixed and can be raised or lowered.
hey Scott,i thot the CG is fixed but the RC changes up or down, this is what i was told,is this wrong,and how do you change CG on a car thx,
wallyedmonds is offline   Reply With Quote
Old 10-19-2006, 04:12 AM   #6548
yellow is very good,stock is grey and works fine,the others i dont like.
Old 10-19-2006, 04:14 AM   #6549
Originally Posted by rmdhawaii
This might help clarify the center gravity issue for everyone:
ahhhh this is good,you guys allways find the good stuff for us to read.
Old 10-19-2006, 05:09 AM   #6550
asw7576's Avatar
I'm pretty sure MTX4' CG is fixed even if you have the ability to lower your radio equipments ultra low. Unless you significantly reduce the total weight of the car, only then the location of CG will be change to a new location.
After looking at the CG equation, 3 parameters are count : loads on each wheel, wheelbase, and trackwidth. ( Raising or lowering radio equipments are not count in equation). When we change the weight of the car, only then there is possibility you change the loads on each wheel, and thus change the location of CG. It's either going forward or backwards, or slightly off center between left and right.
Are we getting wrong perception about CG ? People always thought changing locations ex. lowering radio equipments and using Ti screws on upper deck would lower the CG value. Infact CG value is actually a location around the chassis.
I guess we were wrong
Okay guys..... I stop here..... what a day in office
I have to go to Airport and see you soon in 9 days.
Ciao !!!
Old 10-19-2006, 05:32 AM   #6551
ttso's Avatar
CG is NOT only related to where the mass is. It also related to how heavy the mass is! If you run a heavier chassis like 4mm one. The CG is lowered.
And that's only when everything static on ground.
Also, the link (http://members.aol.com/sccacuda/cars/4SmthTa.html) only tell the CG on front/rear. Where most of people said "lower CG" is the CG in height. Like I said, CG is a point in 3D space.
In fact I prefer to use CM (Center of Mass) rather than CG. CG is more like the projection of CM on designated dimension. But that's a bit complex than just refer "CG".
ttso is offline   Reply With Quote
Old 10-19-2006, 05:41 AM   #6552
rmdhawaii's Avatar
Before you draw that conclusion, you should try some experiments and take a look at the results.
Old 10-19-2006, 05:46 AM   #6553
rmdhawaii's Avatar
If I understand you correctly, I think you mean absolute CG: front/rear and right/left. That might be best addressed by ensuring that the weight measured under the front left/right wheels are the same. Same for the rear left/right wheels.
I know that this is a rather simplistic method for calculating center of gravity height, but it's the only one I could find.
Old 10-19-2006, 04:59 PM   #6554
rmdhawaii's Avatar
A few more interesting articles about weight:
Weight Transfer
http://www.turnfast.com/tech_handlin...eightxfr.shtml
http://racingarticles.com/article_racing-19.html
http://www.autozine.org/technical_sc...handling_3.htm
Old 10-19-2006, 07:16 PM   #6555
man this hobby is becoming a job LOL im just joking
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
