Old 10-17-2006, 02:06 PM   #6481
asw7576's Avatar
Originally Posted by mydo84
Does Lipo damage the receiver because of 7.4V ?I use always Nimh Battery 6.0V my Futaba Receiver.
Novak sells 5A Voltage Regulator to stepdown 7.4V to 6.0V
I would like to try direct ...... I'm sure my car's servos are supercharged
Old 10-17-2006, 02:27 PM   #6482
AMGRacer's Avatar
Originally Posted by rmdhawaii
There is [email protected], but they don't always get back to you depending on your question.
Whose setup do you want?? If you want Fukuda's, you can always try contacting Mugen Japan through the contact Web form at mugenseiki.com (English) or email at [email protected]
Mugen Japan has a setup sheet posted for Keisuke Fukuda for some event "SPL2". It's here: http://www.mugenseiki.com/setupsheet...03005_spl2.pdf
If you wait, Mugen Japan will eventually post Fukuda's setup on the "Setting Sheet" page at their site.
Mugen USA isn't really posting MTX-4 setups or anything for 2006 that I could see. Here is the link to their setup sheet page: http://www.mugenracing.com/index_racesetting.html
Thanks I have tried both of those and got nada. Lucky the car is good cause the race reporting and setup posting stinks
AMGRacer is offline   Reply With Quote
Old 10-17-2006, 02:59 PM   #6483
rmdhawaii's Avatar
Some good info on Lipo is posted in this thread:
New LiPo receiver pack -- replaces 5-cell packs
http://www.rctech.net/forum/showthre...highlight=lipo
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 10-17-2006, 03:56 PM   #6484
Thanks...
mydo84 is offline   Reply With Quote
Old 10-17-2006, 03:58 PM   #6485
Corse-R's Avatar
Originally Posted by kidDynomite
If you really want to loose weight and don't have to worry about tech at club races, a Lipo Rx pack is the best way to loose weight. I a 1300mah Lipo is half the weight of a 1400 5 cell. And it lasts 2-3x longer.
LiPo is a nonsense because you're removing weight on the place you want to have the most of it, on the lowest part of the car. With the Ti screw set you're removing from where you want to remove it, from the highest part of the car, thus lowering the CG.
Investing on LiPos is a nonsense and expensive (you need the battery pack and a suitable charger for it, more than the cost of the Ti screwset).
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 10-17-2006, 04:33 PM   #6486
rmdhawaii's Avatar
If a person wants the benefit of Lipo but doesn't want to lose the the CG benefit of the weight, the person can always add the weight back. Glenn also pointed out in his article that he lowered his fuel tank by 4mm.
Old 10-17-2006, 06:29 PM   #6487
wallyedmonds's Avatar
ya and its just a pain in the but to do it all in the car with the 6 volt reg thing, so what if it lasts for a long time.id rather spend my $ on tires.
wallyedmonds is offline   Reply With Quote
Old 10-17-2006, 08:13 PM   #6488
kidDynomite's Avatar
mydo, you'll need a voltage regulator.
Novak
HT Batteries
kidDynomite is offline   Reply With Quote
Old 10-17-2006, 08:45 PM   #6489
For me, the cost is not an issue because I can use the Lipo Rx for Micro Night racing and the size is easy enought to transfer into my other nitro cars that cannot fit 5cell NiMh flat packs. Plus a Lipo pack will out last 10+ NiMh packs. So please don't make cost an issue. For a $100 you can get a Lipo pack, regulator AND a charger. You can maybe get 3-4 NiMh Rx packs for that price.
As Rainer mentioned, you can also lower your tank. On a Kawahara chassis it's much easier because there's already a cutout in the chassis between the rear batt.tray screws. On the Mugen chassis, you'll have to break out the Dremel for a bit.
Now I used to think the same as others have. "If I change my battery weight, it'll screw up my handling...etc." Seriously though, don't knock it till you try it. Corner speeds are faster, transitions faster, off the line is faster, and Wally, tire wear is better. If you feel like somethings not right, do something about your setup. Don't be afraid to venture away from the ol' trusty stock setup. Lighter is faster, and Lipos have already changed RC for the better... More power, longer run times, no pricey matched cells, longer life. Amain
Old 10-17-2006, 09:13 PM   #6490
Dialed Pile's Avatar
I agee 100% with kidDynamite, the pack stays strong forever!!
MUGEN
Dialed Pile is offline   Reply With Quote
Old 10-17-2006, 09:30 PM   #6491
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
On this one I am going with Corse-R. The benefit of the lipo is minimal at best.
If you want to change hopup your car there are PLENTY of other ways to make your car handle better, and increase the power to the wheels.
Titanium pillow balls. These take off weight and in a good spot. The suspension!
Lighten rotating mass! This makes the car weigh less and also in a good spot.
1st gear oneway
2nd gear housing
2sp shaft
titanium middle shaft
The titanium upper screw kit is also good. Lighter weight up high is a definite benefit
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 10-17-2006, 10:38 PM   #6492
Arahawak's Avatar
Trader Rating: 32 (100%+)
Agreed!
Unless you are really sure that you are placing the batteries in a position where the car is balanced. Otherwise the balance of the car is totally whacked.
Support Bacteria - its the only culture some people have!
Arahawak is offline   Reply With Quote
Old 10-17-2006, 11:08 PM   #6493
Nitro$junkie's Avatar
Send a message via MSN to Nitro$junkie
1st gear oneway
2nd gear housing
2sp shaft
what about when youve done all that and your still craving for more
Futaba
Mugen
Novarossi
Byron's
http://www.hospitalrecords.com
Nitro$junkie is offline   Reply With Quote
Old 10-17-2006, 11:52 PM   #6494
Your car will probably be underweight at that point. If you lighten it at the battery, you will have to add weight back to make it race legal. Guess where the best place to add weight is?
Team drivers have been making brass battery trays to add weight at that spot.
Old 10-17-2006, 11:53 PM   #6495
asw7576's Avatar
Sorry, I think I have to straighten the CG issue vs weight.
The car CG and RC actually remain the same, CG and RC are just imaginary axis where the car is expected to transfer weight on four wheels. When people change to LiPo, only weight is affected. Lighter cars benefit for acceleration, fuel economy, and more top speed.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
