Old 10-16-2006, 08:55 PM   #6466
asw7576's Avatar
Originally Posted by FF25510
stock vs ti (Mugen)
you can reduce half weight. Also can reduce more on mounting servo , i used alu screws
FF25510 : Do you live in HK ? If yes, I would ask you these questions.
Does City Hobby sell large array of titanium screws ? ... hopefully Mugen Seiki or Team Speedmind ? Does it also sell Mugen Seiki cars and parts ? And Futaba ?
I'm going to HK this week for holiday.
Thanks so much for your information.
Old 10-16-2006, 09:00 PM   #6467
wallyedmonds's Avatar
Originally Posted by Team Kamikaze
Original 4mm Mugen chassis
the kanack chassis,you can use the 1pc motor mount,
wallyedmonds is offline   Reply With Quote
Old 10-16-2006, 09:05 PM   #6468
stock vs ti (Mugen)
but they do cost alot of $ but if you want to save weight this is good i still got 2 from my mtx2 car and all 8 from my mtx3 and they last forever with many hits not like ntc3 that break when you blow on them
Old 10-16-2006, 10:32 PM   #6469
itchy b's Avatar
Originally Posted by rcfoolz
I've been asked a few times about the best tire split. I run 1-1.5mm and I've been told that that is too little. Not to second guess myself on this, but what works best? anybody?
i've found that 2-2.5 works the best with 24t pulley.
with 5 min heats 2mm is enough but for mains i found that after 10 min or so the car will get a bit taily.
depends on the track type and traction conditions though
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 10-16-2006, 11:36 PM   #6470
asw7576's Avatar
You don't have to copy mine. I usually use 1 set front tires shave to 63 and 2 set rear tires un-shave. 1 set for heat and 1 set for final. For me over 3mm split is better for 45 minutes long race. If the final is 1 hour then I have to drive carefully after 45 minutes.
Old 10-17-2006, 02:16 AM   #6471
AMGRacer's Avatar
Anybody have an email address for anybody at Mugen USA. I am still trying to get information on the worlds setup..............
AMGRacer is offline   Reply With Quote
Old 10-17-2006, 04:02 AM   #6472
FF25510's Avatar
Yes, i live in HK.
City Hobby is the agent of Mugen in HK, no problem about the cars n parts.
Team Speedmind is one of his owned brand (also Sato Seiki) Ti screws (on my car) n etc...
Futaba, i don't think so.
enjoy your holiday...
FF25510 is offline   Reply With Quote
Old 10-17-2006, 04:05 AM   #6473
FF25510's Avatar
Old 10-17-2006, 04:25 AM   #6474
Hi
Do you use mugen titanium screws?
How much reduce the weight?
I want to buy K-Factory 2 Speed Hard Light Shaft and Mugen Titanium Screw sets for races.
mydo84 is offline   Reply With Quote
Old 10-17-2006, 10:38 AM   #6475
rmdhawaii's Avatar
There is [email protected], but they don't always get back to you depending on your question.
Whose setup do you want?? If you want Fukuda's, you can always try contacting Mugen Japan through the contact Web form at mugenseiki.com (English) or email at [email protected]
Mugen Japan has a setup sheet posted for Keisuke Fukuda for some event "SPL2". It's here: http://www.mugenseiki.com/setupsheet...03005_spl2.pdf
If you wait, Mugen Japan will eventually post Fukuda's setup on the "Setting Sheet" page at their site.
Mugen USA isn't really posting MTX-4 setups or anything for 2006 that I could see. Here is the link to their setup sheet page: http://www.mugenracing.com/index_racesetting.html
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 10-17-2006, 11:27 AM   #6476
kidDynomite's Avatar
Yes, for long mains, I usually go up over 3-3.25mm split w/24t pulley. But it really depends on your tire wear measurements that you should be keeping track of during any practice runs and throught your quals. This was my first year to run a point series that was at different tracks. Tire wear was completely different at every track. One track, I was able to use one set for all 4 qualifiers. At another track, I used one set for every qualifier.
Shore ratings are an important factor too. Some go soft to get a good qualifying time, then go harder for the main to make sure they can finish without a tire change. Strategy is key. I like my car to feel it's best during the last 10-13min of a 30min main.
kidDynomite is offline   Reply With Quote
Old 10-17-2006, 11:36 AM   #6477
Originally Posted by mydo84
Hi
I first weighed the Ti screw kit before putting them on the car. I THINK is was around 41g total. I then attempted to weigh the stock screw by putting them on the scale as they came off. I THINK it was around 70-85g. What screwed me up was that I didn't use all the Ti screws, because I used lighter aluminum screws for the spur gears and diff housings, front servo and a couple other spots.
If you really want to loose weight and don't have to worry about tech at club races, a Lipo Rx pack is the best way to loose weight. I a 1300mah Lipo is half the weight of a 1400 5 cell. And it lasts 2-3x longer.
Old 10-17-2006, 01:19 PM   #6478
asw7576's Avatar
Yeah... Lipo. Titanium screws are expensive way to go on diet. Thanks for reminding me about Lipo
Old 10-17-2006, 01:38 PM   #6479
Does Lipo damage the receiver because of 7.4V ?I use always Nimh Battery 6.0V my Futaba Receiver.
Old 10-17-2006, 01:40 PM   #6480
Osiris 75's Avatar
Trader Rating: 17 (100%+)
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS
RC TARGET/CAPRICORN USA / REFLEX RACING / ULTI TIRES
Chris Kemper
Osiris 75 is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
