Old 10-10-2006, 11:38 PM   #6406
kidDynomite's Avatar
Originally Posted by ira
YBSLOW, AMEN on the LOCTITE!!!!!!!
Yeah, Ira helped me out with the stripped gear problem this season.
I know I had my theories in past posts, but did figure that on the 3mm, you do get a bit of tweak when you're babooned by a ... baboon. Or when you drive yourself into a wall or whatever like a baboon. That's the only time I've noticed that the gear starts looking chewed. Pinion pulls away and starts grinding the tips of the spur.
To add to YBSLOW's comments... after you mount your engine on the block(s), seal up the motor and run the block (stock or mono) on a flat block w/ sand paper to remove any anodize or old LOCTITE residue and also rough sand the chassis. This will help give you a good solid lockdown when you mount the engine in the car.
kidDynomite is offline   Reply With Quote
Old 10-11-2006, 12:09 AM   #6407
Originally Posted by tantalus007
Just experienced my second gear spur stripping off last weekend… was considering replacing my spurs with the 3racing low friction delrin sprurs… are they any good or should I buy the mugen spur gears instead???
I’ve also noticed that something’s rubbing of my stock engine brace, not sure if it’s the 2 speed shoe or the 2nd gear housing itself… am thinking of replacing the engine brace with the kawahara engine brace… would this eliminate this problem??? Any comments on using this kawahara upgrade???
Here a pic of the kawahara engine brace:
It's a decent upgrade and adds a bit of stiffness to the chassis, especially when combined with the Kawhara radio plate support upgrade. I don't use the rubber rings though. I find it doesn't really change the way the car performs but your experience may differ.
going4#1 is offline   Reply With Quote
Old 10-11-2006, 01:21 AM   #6408
itchy b's Avatar
check the pinions for wear as when they get a little sharp that is one cause of stripping.
also check gear mesh too as this is critical.
oh and the hopp up brace will help too
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 10-11-2006, 01:25 AM   #6409
itchy b's Avatar
Originally Posted by wallyedmonds
and a good 2 cents i kinda do the same thing (and as you know i am the expert) lmgdao.
yes, that seems to be the rumour going round
EX1.5-SC10 4x4
Old 10-11-2006, 10:14 AM   #6410
tantalus007's Avatar
Trader Rating: 17 (100%+)
thanks for all the replies and tips guys... very much appreciated...
"para kang bata, nakahawak ka lang ng lapis kahit pader sinusulatan mo, magamit mo lang lapis mo..."
tantalus007 is offline   Reply With Quote
Old 10-11-2006, 11:40 AM   #6411
could you guys elaborate or further explain on the pinions getting a little sharp... was thinking that when my second gear spur got stripped off, my pinions got a bit rounded rather that being a bit more sharp... although the pinions being sharper therefore causing the stripping makes more sense to me... are pinions getting sharper as they wear???
Old 10-11-2006, 12:01 PM   #6412
Default Need Opinion
Guys,
I have a picco nsr3 turbo motor and wondering if I should get a turbo pipe for it or can I use different tune pipe non turbo? I am leaning towards getting the skyline vr12, what do you guys think
Is it matter if I get a turbo or non turbo?
BeBop is offline   Reply With Quote
Old 10-11-2006, 12:47 PM   #6413
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
As the pinions wear the shape of the teeth change. They get thinner and sharper and this can make it easier to strip spur gears.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 10-11-2006, 12:57 PM   #6414
ira
ira's Avatar
Trader Rating: 18 (100%+)
Originally Posted by kidDynomite
YBSLOW, Ira! How's it compare to other engines?
Ira, keep meaning to call you after work, but I always get tide up. What time do you usually get back from workout?
Hey Tommy, Give me a call any time. If I do not answer I will call you back.
Later
RC AMERICA, XRAY, FUTABA, O.S. ENGINES, BYRON FUELS, SPEEDWORLD RACEWAY, HOBBICO, MATRIX TIRES...
ira is offline   Reply With Quote
Old 10-11-2006, 04:39 PM   #6415
wallyedmonds's Avatar
SO on a RRR its very easy to strip the gears right.
wallyedmonds is offline   Reply With Quote
Old 10-11-2006, 09:55 PM   #6416
I know when the teeth on the Mugen pinions wear they change shape and it can cause gear stripping. I have no idea if it is very easy to strip gears on the Kyosho. Why don't you tell me. You are the expert on everything.
BTW: Deathmetal suckzz
Old 10-11-2006, 10:24 PM   #6417
itchy b's Avatar
sorry about that,
yes, as the teeth wear down they get thinner until there is no flat spot left on the edge, thus "getting sharp"
when you're ready to fit new pinions and spurs, i can highly recomend the steel pinions.
after fitting my first set, after 200 minutes of running they still look like new.
very good wearing gears
EX1.5-SC10 4x4
Old 10-11-2006, 10:26 PM   #6418
itchy b's Avatar
EX1.5-SC10 4x4
Old 10-11-2006, 11:18 PM   #6419
Where does the O rings go?
Sometimes I post just to look at Kraig's avatar
RoyU is offline   Reply With Quote
Old 10-12-2006, 12:47 AM   #6420
Underneath both ends of the chassis brace. On the top the screw holes are beveled out to allow a flathead screw to hold the brace to the car.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
