Old 10-10-2006, 10:39 AM   #6391
tantalus007's Avatar
Trader Rating: 17 (100%+)
Just experienced my second gear spur stripping off last weekend… was considering replacing my spurs with the 3racing low friction delrin sprurs… are they any good or should I buy the mugen spur gears instead???
I’ve also noticed that something’s rubbing of my stock engine brace, not sure if it’s the 2 speed shoe or the 2nd gear housing itself… am thinking of replacing the engine brace with the kawahara engine brace… would this eliminate this problem??? Any comments on using this kawahara upgrade???
Here a pic of the kawahara engine brace:
"para kang bata, nakahawak ka lang ng lapis kahit pader sinusulatan mo, magamit mo lang lapis mo..."
tantalus007 is offline   Reply With Quote
Old 10-10-2006, 11:20 AM   #6392
kidDynomite's Avatar
Originally Posted by twoo
Everyone at the Worlds was given 2 optional parts. The new hub does not seems to do much. It change your steering rod to be level with the track. Then some shim it back to close to where it was anyway. The second one is the carbon fibre camber link for the rear. It moves your camber link toward the inside with new holes.
With the limited partice time at the Worlds, it was difficult to see what the new part does.
Thanks for the insight, twoo. Definitely worth testing out. In carpet racing, sometimes it benefits having a little bump steer. Maybe not so noticable in nitro.
kidDynomite is offline   Reply With Quote
Old 10-10-2006, 12:13 PM   #6393
Osiris 75's Avatar
I would recommend any of the hop-upped braces, because I had the stripping problem too. The Derlin Spurs don't help, because you will just strip those too. I went to the Traxxas engine mount screws, and the Skyline brace. I still strip, but now it's after about a gallon of fuel, and before it was after every 3rd tank or so..
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS
RC TARGET/CAPRICORN USA / REFLEX RACING / ULTI TIRES
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old 10-10-2006, 12:44 PM   #6394
Seisick's Avatar
readjust the mesh first by angle, by looking from both bottom and top of the chassis, they should be parallel, then look at the full contact side by side, there should be full contact with the centax on and off, and finally if not enought contact, you should consider using a shim behind the collect. no need to use aluminum rear brace, a 6x0.2mm shim behind the pin of the 2 speed shaft will avoid the contact with the rear brace,
going to my 3rd gallon with the same spurs, by the way I use a one piece engine mount and I managed to strip a gear with it before readjusting as above
happy racing!
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 10-10-2006, 01:07 PM   #6395
YBSLOW's Avatar
Default stripping second gear
O.K.
I know evryone has a theory about this and I am going to share mine because sense I started doing this I have been able to get about 5 gallons and still going on the same spurs. First of all I quit running the 52t spur because it was the only one I stripped over and over(the pitch is wider onthis due to the fewr number of teeth to maintain the same diameter). Second and the most important part of this is to use loctite on all 4 upper engine mount scres and all 4 lower engine mount screws. I also make sure I install the upper screws to the mounts with the engine removed from tha car and I do this by removing the belt tensioner everytime I take the engine out. I use both the 3 and the 4 mm chassis and the prospec mounts.
Just my .02 cents
YBSLOW Racing
RC Target - Capricorn
HOTRACE Tyres, Tru Source, Fantom
POWER MASTER Fuel, 2mm Designs
Protoform Bodies, Avid Bearings, AMR Engines
YBSLOW is offline   Reply With Quote
Old 10-10-2006, 01:17 PM   #6396
dg8one's Avatar
got my last year and never strip a gear
but this is my 4th set of pinion gears
Member of the CHEATERS CLUB
TEAM KAMIKAZE(MARYLAND CHAPTER)
TOKWA'T BABOY LTD
dg8one is offline   Reply With Quote
Old 10-10-2006, 01:24 PM   #6397
ira
ira's Avatar
Trader Rating: 18 (100%+)
YBSLOW, AMEN on the LOCTITE!!!!!!!
RC AMERICA, XRAY, FUTABA, O.S. ENGINES, BYRON FUELS, SPEEDWORLD RACEWAY, HOBBICO, MATRIX TIRES...
ira is offline   Reply With Quote
Old 10-10-2006, 02:05 PM   #6398
YBSLOW's Avatar
Waz up offroader?
My Ninja was nice in Vegas yesterday!
YBSLOW Racing
Old 10-10-2006, 02:39 PM   #6399
AMGRacer's Avatar
Got nearly 2 gallons through my car with zero 2nd gear issues. I do very similar to YBSLOW.
AMGRacer is offline   Reply With Quote
Old 10-10-2006, 02:47 PM   #6400
ira
ira's Avatar
Originally Posted by YBSLOW
Waz up offroader?
The new R is the sh$$.
So you like the Ninja? I'm going to order the offroad ver. for the buggie.
Later
Old 10-10-2006, 04:43 PM   #6401
wallyedmonds's Avatar
O.K.
Just my .02 cents
and a good 2 cents i kinda do the same thing (and as you know i am the expert) lmgdao.
wallyedmonds is offline   Reply With Quote
Old 10-10-2006, 07:27 PM   #6402
richey's Avatar
Send a message via MSN to richey
Well good news Brad you must be doing it right because Wally almost does the same thing.lmao
Silver Bowl Raceway Operator
www.TeamTaylorRacing.net
Byron's Fuel, Airtronics
JoshStevensFoundation.org
richey is offline   Reply With Quote
Old 10-10-2006, 07:29 PM   #6403
thats right LMGDAO but realy most guys do it this way
Old 10-10-2006, 10:19 PM   #6404
Default Theory
O.K.
Just my .02 cents
Thanks for your comment. I also got alot of spurs stripped on my car. I did
the same thing and its perfect. Thanks
speed is offline   Reply With Quote
Old 10-10-2006, 10:43 PM   #6405
Later
YBSLOW, Ira! How's it compare to other engines?
Ira, keep meaning to call you after work, but I always get tide up. What time do you usually get back from workout?
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
