Old 09-27-2006, 12:35 PM   #6241
blanks596's Avatar
Trader Rating: 14 (100%+)
Originally Posted by Nitro$junkie
youve geared it the wrong way and their for using more fuel cause its working the engine more geting more top end speed try the 60t first and 24t second should rev its tits out but less strain and time to do so also you could put a longer fuel line for when your sitting on the start line waiting for the race to start
I have to correct my gearing statement. I'm running 60/18 54/24. So, what you're saying is that I should lighten my gearing to possibly stock settings 59/17 and 53/23, which would cause the engine to rev out and produce less top speed and more bottem end punch?
Serpent/Desoto Racing
Max S
blanks596 is offline   Reply With Quote
Old 09-27-2006, 01:08 PM   #6242
SalvadoriRacing's Avatar
Send a message via MSN to SalvadoriRacing Send a message via Skype™ to SalvadoriRacing
Originally Posted by EEChris
Your engine and pipe combo seem fine. I am having the same problem you are, I may have to work on shimming the engine. I have not tried the VR12 Plus but I hope it will make me run the 5 mins at least. Anybody have any ideas on shimming the 12+3??
for 30% nitro use the stock shimming........
20% use 0.20~0.25mm......
Salvadori Racing
www.salvadoriracing.com.br
O.S. Engines - KM RACING - CONTACT TYRES - SAVOX - LRP - ARC | Blitz | Titan
SalvadoriRacing is offline   Reply With Quote
Old 09-27-2006, 01:10 PM   #6243
Osiris 75's Avatar
Trader Rating: 17 (100%+)
I never understood this. Where do you shim the engine?? Sorry!!
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS
RC TARGET/CAPRICORN USA / REFLEX RACING / ULTI TIRES
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old 09-27-2006, 01:15 PM   #6244
asw7576's Avatar
I have sort of novarossi engines ( LL5, NSR S3, S5, FX3, FX5 ). I notice LL5 engines get maximum rpm too fast than NSR engines. LL5 is screaming longer than NSR at long straight. My home track is 75 meter long straight.
I overcome the problem with 58/18 and 52/24 for LL5 engine setup.
You could try 59/18 and 53/24 as first try, or try mine above if you feel the engine is still screaming too long.
FYI : MTX4 first gear ratio produce very high acceleration compare to MTX3. Not nice for my home track condition.
Also check your clutch shoe ( doughnut type ) for wear, and the centax spring tension. It should be 0.6mm to 0.8mm ranges, or ask some experts on race track with MTX4 cars.
Old 09-27-2006, 01:19 PM   #6245
asw7576's Avatar
Underneath the underhead ( where you put the glow plug ).
Old 09-27-2006, 01:26 PM   #6246
asw7576's Avatar
R U sure ? ( are you living in high altitude ? )
I think 30% nitro need additional shim(s) for safe reason. Original Novarossi get 0.30mm silver shim included. It is good for 25% nitro but that's the maximum safe limit.
Every 5% increase in nitro content, it is advised to add 0.10mm shims.
Old 09-27-2006, 03:39 PM   #6247
wallyedmonds's Avatar
wallyedmonds is offline   Reply With Quote
Old 09-27-2006, 03:43 PM   #6248
doing this gearing the motor is not bogy i run 17/60 and 23/54 mostly
Old 09-27-2006, 03:45 PM   #6249
stock shimming is for 16% or 20%max 25% add a shim and so on ,
Old 09-27-2006, 03:58 PM   #6250
kidDynomite's Avatar
On my Sirio EVO III, I only had to add a 0.1 shim to the stock shims for 30%. I have over a seaon and a half of racing on this motor using the Cyrul method and it's still going strong. Shimming specs came from Andea at Sirio.
kidDynomite is offline   Reply With Quote
Old 09-27-2006, 04:29 PM   #6251
ok thats cool that may be max
Old 09-27-2006, 04:36 PM   #6252
yes, i'm pretty sure.......
the guy asked about the plus 12-3ct engine and this engine can run with 30% nitro with stock shimming at 800m of altitude..........
Salvadori Racing
Old 09-27-2006, 04:37 PM   #6253
Old 09-27-2006, 04:44 PM   #6254
BTW........2 friends of mine went to the WC in Brisbane........one of them ran a Plus12 shimmed with only 0.10mm for the 16% nitro fuel available at the event...........
the engine ran flawlessly through all the practice sessions, qualifying sessions and the 1/32 final........almost 2 hours of hard racing and the engines is perfect (combustion chamber, plug and piston crown).......
Salvadori Racing
Old 09-27-2006, 04:48 PM   #6255
Speedbug's Avatar
We went and raced at the Pre worlds in Feb this year, and used the same fuel. It was Runnertime 16% and it is awesome fuel. The only problems we experienced was when we got back home and changed back to normal fuel.
Speedbug is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
