Old 09-25-2006, 10:30 PM   #6226
EEChris's Avatar
Trader Rating: 21 (100%+)
Originally Posted by Racing4Evo
Chris, I was at the Kyosho race also running the same engine as you. I didn't have a problem making runtime once I had the tuning down. I started bresking in the motor the week before and it's still not broken in after the race. Actually, I don't think that Revelation is too high RPM oriented. What pipe are you using? Did you shim up?
Peter,
I am still not making 5 mins. The most I will make is 4:35. I was using a Vantage Pipe but I am going to switch. I know you'll endorse the VR12 Plus and I will now run that Pipe. I did shim up adding 0.15 to the head. How many shims did you add?
Chris Ibarra
EEChris is offline   Reply With Quote
Old 09-25-2006, 11:15 PM   #6227
kidDynomite's Avatar
Originally Posted by BeBop
Hi,
Just got my mtx-4 and I do not have the tool to adjust camber/ turnbuckle, its like a hook or something what do you call that tool to adjust camber?
You can use a small allen or body clip to adjust the stock turnbuckles.
kidDynomite is offline   Reply With Quote
Old 09-26-2006, 01:38 AM   #6228
rmdhawaii's Avatar
Bought an MTX-4 today.
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 09-26-2006, 02:04 AM   #6229
Nitro$junkie's Avatar
Send a message via MSN to Nitro$junkie
some give this man a beer
Futaba
Mugen
Novarossi
Byron's
http://www.hospitalrecords.com
Nitro$junkie is offline   Reply With Quote
Old 09-26-2006, 07:27 AM   #6230
Originally Posted by THE DOCTOR
I checked once and found the stock Mugen chassis is stiffer then the Kawahara 3mm.
sh1t ok , how did you find this out? ...hmmm... i always thought the 3mm kawaharra was machine..is it though??
TomB is offline   Reply With Quote
Old 09-26-2006, 08:58 AM   #6231
Osiris 75's Avatar
Trader Rating: 17 (100%+)
It's about time man!! With what engine??
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS
RC TARGET/CAPRICORN USA / REFLEX RACING / ULTI TIRES
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old 09-26-2006, 10:07 AM   #6232
rmdhawaii's Avatar
Haven't bought the engine yet. Still doing homework.
Old 09-26-2006, 10:24 AM   #6233
Ron C.'s Avatar
Also, the car is working really good now. It seems like we got a good setup that works pretty much everywhere. Marco Acosta seem to have the fastest car in the main. Whoever gave him the setup is dialed and doesn't race much.
So we see..
You're car looked REALLY good over the weekend Peter - impressive!
Yours and Marco's.
Mugen Seiki / MSR / Airtronics / Enneti Tyres / O'Donnell Racing / Checkpoint / Hobbico
Ron C. is offline   Reply With Quote
Old 09-26-2006, 10:26 AM   #6234
Osiris 75's Avatar
Yea, I've noticed. Seems that the Sirio would be the best pick!!
Chris Kemper
Old 09-26-2006, 11:13 AM   #6235
Awesome, brotha! Get a Sirio. I got over 1 1/2 seasons on my EVO III. Still going strong. I bought another one as a back up last year and haven't had to touch it yet. How's that Orion in you RRR doing?
Anyways, congrats! I guess we'll be seeing more info on the MTX-4 KB site
Old 09-26-2006, 12:27 PM   #6236
rmdhawaii's Avatar
Old 09-27-2006, 11:08 AM   #6237
blanks596's Avatar
Trader Rating: 14 (100%+)
Originally Posted by EEChris
Max,
You may have the wrong engine and pipe combo. Revelations track layout is high RPM and if you notice a lot of people came in for splashes throughout the weekend for the quals. I'm having the same problem so I may change my pipe. I too am not making time but than again im running a powerful but thirsty 12+3
Waz up Chris-I'm using the VR12plus pipe with my N12LL3. I recently leaned out the bottom end by 2 hours hoping to save some gas but I don't think it helped. I also wasn't able to really tell for sure because I did it before the mains and didn't take a chance on pitting at 5min. If the problem is my motor and pipe combo, should I go with longer pipe or longer manifold?
Serpent/Desoto Racing
Max S
blanks596 is offline   Reply With Quote
Old 09-27-2006, 11:24 AM   #6238
blanks596's Avatar
It's the other way around. A 77cc tank came out first. Lots of racers started getting disqualified by tech at big races. They then altered the tank to a legal 75. I have a 77cc and use an AE gas tank insert thats screwed to the floor of the tank. If you havent alread, you may want to try and lighten up the car and figure out how to free up the drive-train more. Efficiency=longer run time.
How many gallons do you have through your LL3? Check your LSN, it may be a tad rich.
I'm not sure how many gallons I've had through it but I think I put at least 8 through it. I spent at least 1 gal for break in. I did add a pressure chamber and lean out the LSN by 2hrs, but I wasn't able to figure out any increase in time because I did this adjustment 10min before the main. I never used a pressure chamber before but it seemed that I was able to lean out the LSN 2hrs easily without drastically raising the idle.
Max S
Old 09-27-2006, 11:38 AM   #6239
SOLOARTIST 702's Avatar
Send a message via AIM to SOLOARTIST 702
Default hmm
hey max you doin pretty good as a blue shirt
RC AMERICA / XRAY / HUDY/ MATRIX TIRES /KOPROPO / ORCAN GT3 /RED CUP RACING MEMBER / SPEEWORLD RACEWAY/ A+ performance parts /IVE SEEN THE XRAY TEAM DRIVE SO I GOT XRAY CARS / better to keep up than to catch up
WILLIAM PENDERGRASS
SOLOARTIST 702 is offline   Reply With Quote
Old 09-27-2006, 12:08 PM   #6240
EEChris's Avatar
Your engine and pipe combo seem fine. I am having the same problem you are, I may have to work on shimming the engine. I have not tried the VR12 Plus but I hope it will make me run the 5 mins at least. Anybody have any ideas on shimming the 12+3??
Chris Ibarra
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
