Old 09-22-2006, 10:34 AM   #6196
lil-bump's Avatar
Trader Rating: 83 (100%+)
You have to look how tall your tires are. If you cut your tires down to 60mm or so; you should have no problems
lil-bump is offline   Reply With Quote
Old 09-22-2006, 12:06 PM   #6197
Osiris 75's Avatar
Trader Rating: 17 (100%+)
Or adjust your droop!!
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS
RC TARGET/CAPRICORN USA / REFLEX RACING / ULTI TIRES
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old 09-23-2006, 06:50 AM   #6198
can any users please give me their opinions on the kawlahalalala 3mm chassis? i had one and sold it before i used it, now i've decided to purchase one. is it the same as the mugen 3mm or is it stiffer? how does it fair in a crash? easy to bend?
TomB is offline   Reply With Quote
Old 09-23-2006, 09:56 AM   #6199
Just need some advise. Does the MTX4 front CVD can be used in the MTX3? What other parts that MTX4 can also be replace in the MTX3, ie, front & rear arms?
MIKA is offline   Reply With Quote
Old 09-23-2006, 10:00 AM   #6200
tantalus007's Avatar
thanks for all the replies and the tips guys...
Originally Posted by typer
get the 4mm rear shock tower...
thanks for the tip dude... hope you could run with jay and my other friends at jp raceway someday...
tantalus007 is offline   Reply With Quote
Old 09-23-2006, 03:27 PM   #6201
AMGRacer's Avatar
So has anyone got the worlds winning setup yet? Seems Mugen has forgotten it won the worlds, no updates on their websites yet!
AMGRacer is offline   Reply With Quote
Old 09-23-2006, 04:09 PM   #6202
Roger's Avatar
Probably still celebrating the victory. Im sure they'll be up soon.
http://nitrokb.netne.net/profiles/RogerSerafin.html
Roger is offline   Reply With Quote
Old 09-23-2006, 08:08 PM   #6203
Default setups
mtx 4 newbie here.
I'm trying to setup the car and had a few questions. First off, when setting front droop do i set both arms using the set screw or do the right one first then turn the little nob on the left arm untill both arms are 2mm or equal?
Second, i'm running low on the 600wt oil and was wondering what are the Losi/trinity/Team assciated equivalents? As i have a gang of bottles ranging from 30wt to 60wt oil.
thanks in advance.
rai13 is offline   Reply With Quote
Old 09-23-2006, 10:01 PM   #6204
rcabj's Avatar
hello guys.....nothing actually ...just orderded the kit, most probably will get into my hands in a few days
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 09-23-2006, 11:43 PM   #6205
typer's Avatar
Hopefully by next week.. try to leave early
typer is offline   Reply With Quote
Old 09-23-2006, 11:44 PM   #6206
typer's Avatar
it is much stiffer and plus it has air duct underneath for engine cooling
Old 09-24-2006, 06:40 AM   #6207
blanks596's Avatar
Trader Rating: 14 (100%+)
I heard a rumor that there are 2 types of fuel tanks available for the mtx4; suppossedly the ealier models came with a smaller tank. I'm having trouble making 5 min. Ive changed the gearing to as high as my engine could handle, but still had problems (58/18 and 52/24) I basically have to run a perfect race to make the laps and times. I'm running a N12LL3 which I've had for a year.
Serpent/Desoto Racing
Max S
blanks596 is offline   Reply With Quote
Old 09-24-2006, 07:41 AM   #6208
Nitro$junkie's Avatar
Send a message via MSN to Nitro$junkie
youve geared it the wrong way and their for using more fuel cause its working the engine more geting more top end speed try the 60t first and 24t second should rev its tits out but less strain and time to do so also you could put a longer fuel line for when your sitting on the start line waiting for the race to start
Futaba
Mugen
Novarossi
Byron's
http://www.hospitalrecords.com
Nitro$junkie is offline   Reply With Quote
Old 09-24-2006, 07:53 AM   #6209
ND
Originally Posted by rai13
mtx 4 newbie here.
thanks in advance.
Hi
Setting the droop you should first remove the roll bar and set the droop the same left and right, then reconnect the roll bar and make sure the droop is still the same as you set it earlier. If it is different use the cam on the left arm to make it the same. It is important to set this right or the car will not handle as good as it can.
I would not advise using other brands of oil, reason being they are all different weights. Losi 60 is not the same as Mugen 600, try to stick with Mugen oil as it's very consistant from bottle to bottle, and then you can just copy from a set up sheet and know it's the same.
ND is offline   Reply With Quote
Old 09-24-2006, 09:05 AM   #6210
kidDynomite's Avatar
It's the other way around. A 77cc tank came out first. Lots of racers started getting disqualified by tech at big races. They then altered the tank to a legal 75. I have a 77cc and use an AE gas tank insert thats screwed to the floor of the tank. If you havent alread, you may want to try and lighten up the car and figure out how to free up the drive-train more. Efficiency=longer run time.
How many gallons do you have through your LL3? Check your LSN, it may be a tad rich.
kidDynomite is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
