Old 08-31-2006, 01:29 PM   #5956
asw7576's Avatar
http://www.nitrohouse.com/
http://www.brooklynhobbies.com/
Old 08-31-2006, 02:36 PM   #5957
Corse-R's Avatar
Originally Posted by Osiris 75
I say stick with KO!!
Hehehe... Ditto. I still have my trusty Mars-R with their Blue Led of Death just to terrorize and torture the poor driver that puts around me at the rostrum...
When the Helios came out, said: "sheeeesh! UGLY!". Many years after I still saying: Ugly... I think the day my Mars-R dies, probably I look for another. Helios is ugly as a monkey a$$...
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 08-31-2006, 02:39 PM   #5958
Derby Bros Racing's Avatar
Originally Posted by bigboss
where can i buy one of these tools??
I have one I can sell to you for $25 shipped priority mail (you're here in U.S. right?). PM me if interested as I don't need the tool anymore
Derby Bros Racing is offline   Reply With Quote
Old 08-31-2006, 03:18 PM   #5959
Send a message via MSN to Adim_X
If you put the 2nd gear pinion on by hand as tight as you can, then you can use that pinion and hold with pliers that have large teeth, and tighten the other pinion down with another set of pliers. I do this all the time, I have not bought any special tools. Just take your time, use your brain and you will figure it out.
Adim_X is offline   Reply With Quote
Old 08-31-2006, 07:10 PM   #5960
Trader Rating: 15 (100%+)
hey guys can u take alook at my pinion gears to spur gear, i dont fink it loks right
its just the pinion gear not having full contact on the corresponding spur gear
and one more fing.... my first gear pinion gear wen spinning starts to go loose, (wen i spin it to check the mesh with my hands) and makes the gear spin with the flywheel
any ideas? maybe use thread lock on pinion gears???
thanks
Don't use thread lock or you will never get them off if you need to. It looks new, once you run the car it will tighten up as it drives the car on its own. You just need them to be snug on the clutch bell.
THE DOCTOR is offline   Reply With Quote
Old 08-31-2006, 07:35 PM   #5961
FF25510's Avatar
Originally Posted by TomB
any mtx4'ers have experience with the rrr ferodo brake pads on the mtx4?
also any opinions on the kawahara one way/spool
I think you mean the APP brake pads(APP02-2), right? I'm using it with the original MTX-4 brake disc, work perfectly. You needed some extra work to drill one hole longer and fits two screw. I also test Mugen yellow pads with Mugen options disc, APP get more sensitive to me. will post photo tomorrow.
FF25510 is offline   Reply With Quote
Old 09-01-2006, 01:46 AM   #5962
i just cant get the gear to mesh properly, wen i take of the first pinion gear, the 2nd pinion mesh is perfect
but wen i put the first pinion back on, the gears are very very tight
i fink thats due to the fact that the first pinion gear is not put on tight enuff
im gonna take it to a model shop today and see wot they fnk of it
any advice?
thanks
bigboss is offline   Reply With Quote
Old 09-01-2006, 02:11 AM   #5963
thanks
First thing is, did you put the brace in before you do the mesh? Must put the brace in first.
If it becomes tight later is because due to bearing slop on 2 speed housing. There will always be slop and they don't rotate true. You will need to add more gap in for it to spin free. Is an experience thing, after you strip a few you will learn how to mesh them correctly!
I have been trying something new that will get the perfect mesh each time. Which is to use spur that are 2 tooth bigger. Set the mesh to be tight and then change the spur back to a smaller one. Same gap everytime.
twoo is offline   Reply With Quote
Old 09-01-2006, 03:30 AM   #5964
Seisick's Avatar
thanks
readjust the mesh first by angle, by looking from both bottom and top of the chassis, they shoulb be parallel, then look at the full contact side by side, there should be full contact with the centax on and off, and finally if not enought contact, you chould consider using a shim behind the collect, no need to mugen tool, it just makes it easier, an strong allen wrench throught the 2 holes in the bell grabbed by a press or by wide pliers should do it, just be careful with the teeth.
happy racing
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 09-01-2006, 04:20 AM   #5965
As far as I know the spurs are the same size no matter how many teeth they have. They just change the size of the teeth but not the diameter of the gear itself. This is the same for the pinions.
Old 09-01-2006, 04:45 AM   #5966
thanks for the advice guys,
i hav taken the car to a model shop, he'll sort it out for me and i'll learn from my mistakes. hopefully he'll diagnose and tell me what i did wrong
thanks
mat
Old 09-01-2006, 09:02 PM   #5967
My mistake. Thanks for the info.
Old 09-01-2006, 09:59 PM   #5968
Talking
I dont think you are correct, that would totally throw off the pitch of the gears.
Old 09-01-2006, 11:37 PM   #5969
SOLOARTIST 702's Avatar
Send a message via AIM to SOLOARTIST 702
Default hmm
where is MIKE JONES
RC AMERICA / XRAY / HUDY/ MATRIX TIRES /KOPROPO / ORCAN GT3 /RED CUP RACING MEMBER / SPEEWORLD RACEWAY/ A+ performance parts /IVE SEEN THE XRAY TEAM DRIVE SO I GOT XRAY CARS / better to keep up than to catch up
WILLIAM PENDERGRASS
SOLOARTIST 702 is offline   Reply With Quote
Old 09-02-2006, 12:36 AM   #5970
Chris West's Avatar
Send a message via MSN to Chris West
get a vernier and measure the diameter of the gears
MUGEN SEIKI | NINJA | SANWA
Chris West is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
