Old 08-23-2006, 06:15 AM   #5896
Seisick's Avatar
Originally Posted by ElectricConvert
I am frustrated by this car with the constant stripping of 2nd spur gear.
I gave up running the final in my club yesterday because I stripped a gear in the qualifying and could not be bothered replacing it. This car blows the gear every 2 races, what the hell is wrong with it?
I've already done the following but the problem still exist.
Installed a monoblock.
Installed an aluminum upper brace.
Recheck/replaced the engine clutch ball bearings.
Decreased the gap that the clutch bell travels by adding shims inside the clutch bell, compensated with a tighter clutch spring setting.
Always removed first gear and meshed 2nd gear, then install the first gear. Installed 18/24 steel pinions.
Tapered the 2nd gear housing so it doesn't touch the clutch bell.
Shimmed behind the 2 speed shoe housing pin so it doesn't catch the aluminium brace.
What is the root cause of this nagging issue?
Can someone elaborate on the logic behind these suggesions?
-Replaced the inner 2nd gear clutch balls with some bigger ones (S710's ball diff balls)
-Replaced the 2nd gear clutch shoes with the MTX-3 shoes
-How about going to a 4 mm chassis? Is chassis flex the cause?
Thanks in advance for your constructive input.
SIMILAR SITUATION OCURRED TO A FRIEND OF MINE, WHEN CHECKING FLEX BY HOLDING THE FRONT AND BACK OF THE KIT WITH HIS TWO HANDS, HE FOUND OUT THAT THE SCREW NEXT TO THE CHASIS BRACE THAT HOLDS THE RADIO PLATE WAS NOT TIGHT, IT CAUSED A MINIMAL FLEX BUT VOILA, THAT WAS IT, NO MORE STRIPPING 2ND GEARS SINCE, THIS FLEX STRIPPED 5 GEARS IN TWO MEETINGS.
HOPE IT HELPS
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 08-23-2006, 06:25 AM   #5897
Seisick's Avatar
Originally Posted by Slo-MTX4
How many of you guys run the 24t pulley?
And have you had any issues with the side belt coming off?
Cheers Daniel
YOU CAN GAIN MORE TENSION BY DREMELING A LITTLE THE CARBON PIECE HOLDING THE BELT TENSIONER, YOU CAN ALSO REVERSE THE ALUMINUM PIECE WHERE THE SCREW HOLDING THE BEARINGS OF THE TENSIONER,
OR USE A FRONT TENSIONER, I USE THE MTX3 ON FRONT AND THE URETHAN BELT WORKS FINE AND NO MORE COMING OFF SINCE THE REAR COULDN'T BE LOWERED MORE.
HobbymaniA
GoT MuGeN?
Old 08-23-2006, 07:39 AM   #5898
Corse-R's Avatar
Cheers Daniel
No probs with the 24T here... I don't know which kind of batch your car is, but mine two carried three front center pulleys (23, 24 & 25T) and two center belts (one came separate with a yellow addendum page).
This one who came separated is the rubber one and is shorter than the one that came 'stock' on the big bag (urethane one).
The lettering on the 'short' belt is "Mugen Seiki Co. Ltd E5SD 22089 031"
The center belt is a little loose and the belt tensioner is tightened all the way down (Just to be sure to put the little nail that guides the tensioner on the CF place facing upper side). Belt didn't skipped nor broke never (in fact I'm scared to death because the center belts has 40 litres of fuel and is looking brand new).
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 08-23-2006, 10:02 AM   #5899
Osiris 75's Avatar
Trader Rating: 17 (100%+)
HOPE IT HELPS
Cool, I'll give that a try. I've tried all the other remedies and they still strip!!
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS
RC TARGET/CAPRICORN USA / REFLEX RACING / ULTI TIRES
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old 08-23-2006, 03:47 PM   #5900
Deves's Avatar
Default Mugen Seki T shirt
SOLD
Hey Nitro Fans!
Are any of you guys interested in a Mugen Seki T shirt?
It's a size Extra large brand new in the bag. It's gray with the Mugen Logo on the back in white letters surrounded by orange and yellow flames. Price is $15 shipped to US
Deves is offline   Reply With Quote
Old 08-24-2006, 12:57 PM   #5901
TonysScrews's Avatar
UPDATE!
Mugen MTX4 1/10th On-Road screw kits are now in stock!
Mugen MTX4 1/10th On-Road 235-piece high grade 12.9 alloy steel socket head screw kit. Kit includes all applicable cap, flat and button head screws, as well as nuts, washers, lock washers and set screws.
Kits will begin shipping today, August 24th, 2006.
Thanks and best regards,
Tony P.
Tonys Screws LLC
http://www.tonysscrews.com
High Grade Alloy Steel Screws, Screw Kits and Mugen Parts
TonysScrews is offline   Reply With Quote
Old 08-24-2006, 11:52 PM   #5902
asw7576's Avatar
You can use bigger diameter flange ball bearings to press down the middle belt even further.
Old 08-25-2006, 12:53 AM   #5903
Chris West's Avatar
Send a message via MSN to Chris West
yeah but theres only so far you can go
MUGEN SEIKI | NINJA | SANWA
Chris West is offline   Reply With Quote
Old 08-25-2006, 03:52 AM   #5904
wallyedmonds's Avatar
guys you realy dont wont to do this
wallyedmonds is offline   Reply With Quote
Old 08-25-2006, 04:45 AM   #5905
asw7576's Avatar
Why not ?
Old 08-25-2006, 08:01 AM   #5906
Corse-R's Avatar
Sorry, I do not feel the need for more tighteness on the center belt. As is my car is really free of transmission binding.
Cheers,
Corse-R
Old 08-25-2006, 08:03 AM   #5907
Corse-R's Avatar
Why not ?
Because if all tightened down and you put bigger bearings you're approaching more the teeth of the belt and you can risk to touch themselves as it runs (and of course, do more harm rather than good).
Cheers,
Corse-R
Old 08-25-2006, 11:51 AM   #5908
asw7576's Avatar
I'm sure we have reasonable expertise, brain and experience with RC cars. So we know how big the bearings that fit into mtx4 belt tensioner without harming any other parts.
Anyway, I have new toys ...... mrx4r
Old 08-25-2006, 12:55 PM   #5909
Corse-R's Avatar
I'm sure we have reasonable expertise, brain and experience with RC cars. So we know how big the bearings that fit into mtx4 belt tensioner without harming any other parts. [/QUOTE]
Yep. But the main problem and one thing that needs to be taken into account is the belt stretching and the vibration who is subjected when running at high speed, maybe when at your starter box looks good, but the belt needs their own space to move and vibrate.
Congrats for your new toy, welcome to the 'guys with big guns league'... Is a 4R or is the 4R version 2 (hard chassis without millings under the engine and special new front uprights).
Cheers,
Corse-R
Old 08-25-2006, 01:15 PM   #5910
asw7576's Avatar
It's version 2. I heard I have to be careful when ordering front upright ( old and new style ? )
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
