Old 08-22-2006, 09:04 AM   #5881
typer's Avatar
Originally Posted by Scott Fisher
The nova Plus 12 3ct is a pretty darn good choice in that price range. The novarossi engines are still the best combination of speed and reliability that you can buy.
There are other fast engines on the market right now but you still hear the tales of broken rods, cranks, carb issues etc. You just don't hear those things about the novarossi engines.
Get a novarossi and then you can worry about something else, not the engine.
You're absolutely correct. The sirio engines for me is the worst compared to rb and nova.
typer is offline   Reply With Quote
Old 08-22-2006, 09:10 AM   #5882
Trader Rating: 15 (100%+)
Originally Posted by wallyedmonds
coming off and breaking and breaking the front belt and cvd breaking , so i just run the 25 with 1mm diff front and rear tires and the car drives better and the belts stay on and dont break
When I run the 25t I start the tires out the same size front and rear. The rear tires will wear faster then the front but that is normal. After the back tires wear a little the car is only being driven buy the back tires unless the rear tires start to slip then the front start to pull also.
If you start out with the front tires 1 mm smaller then the drivetrain is bound up until the tires are the same size. This is only when you run the 1mm split smaller fronts and the 25t side gear.
THE DOCTOR is offline   Reply With Quote
Old 08-22-2006, 09:25 AM   #5883
wallyedmonds's Avatar
all i know is the car runs better with the 25 and its faster .
wallyedmonds is offline   Reply With Quote
Old 08-22-2006, 09:26 AM   #5884
and this is so true
Old 08-22-2006, 10:48 AM   #5885
YBSLOW's Avatar
I run the 25t almost all of the time with a 1.5 or 2mm split.
YBSLOW Racing
RC Target - Capricorn
HOTRACE Tyres, Tru Source, Fantom
POWER MASTER Fuel, 2mm Designs
Protoform Bodies, Avid Bearings, AMR Engines
YBSLOW is offline   Reply With Quote
Old 08-22-2006, 11:28 AM   #5886
Do you use the diff or the one-way in the front?
Old 08-22-2006, 12:23 PM   #5887
YBSLOW's Avatar
Good point. It is almost always with the one - way.
YBSLOW Racing
Old 08-22-2006, 01:02 PM   #5888
if you use a diff with 24 the car is like ummmmm DIRT with a 1 to 2mm split i dont know why but it is,a oneway or noway i say.
Old 08-22-2006, 03:11 PM   #5889
rmdhawaii's Avatar
Hi Guys,
Iíve been busy working on an MTX-4 Knowledge Base (KB), similar to the one I did for the V-ONE RRR. It should be up within the next two weeks or so. Here is a list of what the site will include:
- FAQ: A summary of all the best questions and answers from the MTX-4 thread.
Scott Fisherís Notes: Scott has contributed a lot of really good info on the car and I got his okay to put together a special section with all of his tips. If you want to get smart fast, this is certainly the way to do it.
- Build guide by Racing4Evo, including what you need to build a Skyline MTX-4.
- Web Graphics by kidDynomite. The site is going to look really awesome!
- Racer Spotlight: Interviews with MTX-4 drivers that have won major events: First up Ė Jamie Corrado, winner of this yearís GLC.
- Links to where you can buy the car and parts.
- MTX-4 news and updates
Ö and much more as the site grows.
Iím very thankful for all the assistance and support Iíve been getting to put this site together. Since I don't own a 4 yet, I certainly could not have done it by myself. I hope it will serve as a invaluable resource for everyone.
If you have pictures of your car, with and without the chassis on, I would really like to include it at the site, along with a list of performance upgrades you've added to the car. This will serve as a great visual resource, upgrade guide and source of inspiration for other drivers. If you are interested, send me a PM.
Thanks,
Rainer
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 08-22-2006, 03:31 PM   #5890
Squintz's Avatar
Good Stuff Rainier, Can't wait to see it
Brad
X-Factory X-6 Squared/X-60/SCX-60 (#9)
Squintz is offline   Reply With Quote
Old 08-22-2006, 03:44 PM   #5891
ira
ira's Avatar
Trader Rating: 18 (100%+)
[QUOTE=chookgb]
Originally Posted by ElectricConvert
I am frustrated by this car with the constant stripping of 2nd spur gear.
I gave up running the final in my club yesterday because I stripped a gear in the qualifying and could not be bothered replacing it. This car blows the gear every 2 races, what the hell is wrong with it?
I've already done the following but the problem still exist.
Installed a monoblock.
Installed an aluminum upper brace.
Recheck/replaced the engine clutch ball bearings.
Decreased the gap that the clutch bell travels by adding shims inside the clutch bell, compensated with a tighter clutch spring setting.
Always removed first gear and meshed 2nd gear, then install the first gear. Installed 18/24 steel pinions.
Tapered the 2nd gear housing so it doesn't touch the clutch bell.
Shimmed behind the 2 speed shoe housing pin so it doesn't catch the aluminium brace.
What is the root cause of this nagging issue?
Can someone elaborate on the logic behind these suggesions?
-Replaced the inner 2nd gear clutch balls with some bigger ones (S710's ball diff balls)
-Replaced the 2nd gear clutch shoes with the MTX-3 shoes
-How about going to a 4 mm chassis? Is chassis flex the cause?
Thanks in advance for your constructive input.[/QUOTE
the steel pinions are a must have item as once you start stripping gears with the aluminium ones they will keep stripping, also the 2 speed shoes need to be adjusted out until they almost touch the 2 speed housing. this gives you a less harsh change, you will have to re-adjust your change point after doing the adjustment
Are you using Lock Tight? Alot of people I know that have this problem do not use it. I use the blue Lock Tight and tighten the hell out of the mount screws ( upper and lower). Make sure there is no oil or dirt on the threads of the screws, mounts, and chassis. Also make sure you are using the right length screws.
RC AMERICA, XRAY, FUTABA, O.S. ENGINES, BYRON FUELS, SPEEDWORLD RACEWAY, HOBBICO, MATRIX TIRES...
ira is offline   Reply With Quote
Old 08-22-2006, 03:54 PM   #5892
FF25510's Avatar
Brad
FF25510 is offline   Reply With Quote
Old 08-22-2006, 07:06 PM   #5893
GrandeGixxer's Avatar
I will give you some stuff to throw on there as soon as I get some time, as well as my car back together. I am fighting with the front bearing in the motor right now.
Joe Cude
Mugen MBX-7R Mugen MTX-6R Mugen MTC-1 Mugen MRX-6 Mugen MST-1 Tamiya Euro Truck
GrandeGixxer is offline   Reply With Quote
Old 08-22-2006, 10:02 PM   #5894
I agree 100%.
Old 08-23-2006, 04:22 AM   #5895
Bad Mika's Avatar
The diffrence between the two is that the other one has ceramic bearing. I think its the ct that has it.
Thanks ! ...
Bad Mika is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
