Old 08-18-2006, 10:50 PM   #5836
itchy b's Avatar
Originally Posted by Scott Fisher
YBSLOW will probably disagree with me, but running a 25t pulley with 2mm split with give a noticable on power push. That setup will give front underdrive meaning on power your front tires will be turning slower than the rears.
Bottom line, is you can test for yourself but I would not use the 25t pulley with a 2mm split. Use the 24 as was suggested.
so do you recomend same size tyre all round for best balance?
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 08-18-2006, 11:21 PM   #5837
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
If you run the 25t pulley, run the same size tire. Problem is most of the time people wear rear tires more quickly than fronts.
If you run a 24t pulley, try a 2mm split.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 08-19-2006, 02:10 AM   #5838
asw7576's Avatar
Agree, sometimes I use 23T with 3mm split when I need more steering. I feel the car could turn better with 23T for A main final and tire wear rate about equal front and rear.
Old 08-19-2006, 06:05 AM   #5839
itchy b's Avatar
thanks scott
i found when i tried the 25t the rear tyres didnt wear as much as they do when using the 24t and 2mm split.
seemed to have a little more steering.
i'll see how it goes when i run it tomorrow as they use vht on race days and it will change the handling
cheers
joe
EX1.5-SC10 4x4
Old 08-19-2006, 04:17 PM   #5840
TPB
Lightbulb
Does anyone know where I can buy this from?
TPB is offline   Reply With Quote
Old 08-19-2006, 04:19 PM   #5841
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Didnt know Mugen had their own Dominoes... Where can I buy this from?
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 08-19-2006, 09:01 PM   #5842
wallyedmonds's Avatar
what are they
wallyedmonds is offline   Reply With Quote
Old 08-19-2006, 09:08 PM   #5843
tire wear is sometimes just setup ( RC) but i realy fined and others too that 25 pulley just works better it did in the mtx3 and mtx2 but try it just like setup of the car its fun to try different things on it to see what works.
Old 08-19-2006, 09:11 PM   #5844
kidDynomite's Avatar
Originally Posted by wallyedmonds
what are they
They're foam bricks incase you get really mad at the track...no one gets hurt. jk
Actually, I believe they are car stands.
kidDynomite is offline   Reply With Quote
Old 08-19-2006, 09:13 PM   #5845
hey thats cool ya i like to know where i can get these too.
Old 08-20-2006, 07:05 AM   #5846
busman's Avatar
Having problems stripping 2nd gear, whats the fix? are there better gears out there?
1st does'nt strip just 2nd, Whats up, did I do something wrong?
Mike
But, Is it farther to Seattle or by Bus??????
Be obsequious as opposed to obtuse
The more Government expands, The more Freedom contracts!!
busman is offline   Reply With Quote
Old 08-20-2006, 11:26 AM   #5847
boy2rc's Avatar
Mike
The problem is the two speed shoe too closed to the upper deck connector, by cutting a little bit its rear section, problem solve.
I strip mind 3 of them in the first run, after doing this, never again.
P.S this method is I read from this previous thread.
William
boy2rc is offline   Reply With Quote
Old 08-20-2006, 11:38 AM   #5848
Riketsu's Avatar
Mike
There are many theories and urban legends developed here to solve this problem. Heres what I have done:
-Installed a monoblock
-Installed the aluminum upper brace
-Replaced the inner 2nd gear clutch balls with some bigger ones (S710's ball diff balls)
-Replaced the 2nd gear clutch shoes with the MTX-3 shoes
-Recheck your engine clutch ball bearings
-Decrease the gap that the clutch bell travels by adding shims inside the clutch bell
-Remove your first gear, do your mesh then install the first gear. (Without the first gear, both clutchbell/2nd gear should move freely.
-Change the aluminum pinions for some steel ones (they last a life time)
Hope this helps.
Old 08-20-2006, 08:18 PM   #5849
ElectricConvert's Avatar
Default What's the matter with this car?
I am frustrated by this car with the constant stripping of 2nd spur gear.
I gave up running the final in my club yesterday because I stripped a gear in the qualifying and could not be bothered replacing it. This car blows the gear every 2 races, what the hell is wrong with it?
I've already done the following but the problem still exist.
Installed a monoblock.
Installed an aluminum upper brace.
Recheck/replaced the engine clutch ball bearings.
Decreased the gap that the clutch bell travels by adding shims inside the clutch bell, compensated with a tighter clutch spring setting.
Always removed first gear and meshed 2nd gear, then install the first gear. Installed 18/24 steel pinions.
Tapered the 2nd gear housing so it doesn't touch the clutch bell.
Shimmed behind the 2 speed shoe housing pin so it doesn't catch the aluminium brace.
What is the root cause of this nagging issue?
Can someone elaborate on the logic behind these suggesions?
-How about going to a 4 mm chassis? Is chassis flex the cause?
Thanks in advance for your constructive input.
ElectricConvert is offline   Reply With Quote
Old 08-20-2006, 08:32 PM   #5850
SalvadoriRacing's Avatar
Send a message via MSN to SalvadoriRacing Send a message via Skype™ to SalvadoriRacing
if the 2nd speed engages too suddenly (or too late) the spur will suffer and won't hold the higher stress.........
Salvadori Racing
www.salvadoriracing.com.br
O.S. Engines - KM RACING - CONTACT TYRES - SAVOX - LRP - ARC | Blitz | Titan
SalvadoriRacing is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
