Old 08-14-2006, 02:08 PM   #5791
jhigga15's Avatar
Wjen you were putting on the clutch spring what tools did you yuse? I don't have the mugen tool and I don't want to deform the ring?
jhigga15 is offline   Reply With Quote
Old 08-14-2006, 02:25 PM   #5792
Before I got the mugen clutch tool, I used an old snap ring pliers.
http://www.harborfreight.com/cpi/cta...emnumber=45327
sook is offline   Reply With Quote
Old 08-14-2006, 03:11 PM   #5793
wallyedmonds's Avatar
Originally Posted by asw7576
I think you are wrong. You raise front roll center without shim.
Upper Arms / Camber Link :
Lower RC = More shims ( MTX4 ) or less angle
Higher RC = Less shims or more angle
Lower Suspension Arms :
Lower RC = Close to chassis ( A block )
Higher RC = Higher from chassis ( C block ).
Low grip track condition or technical track theoretically need C block
High grip track condition or wide open track theoretically need A block.
yes you are right
wallyedmonds is offline   Reply With Quote
Old 08-14-2006, 03:14 PM   #5794
Originally Posted by TomB
50k more exit steer less entry, 30k more entry less exit.
depending ont he type of track you might or might not notice the difference. the thicker diff oil will be noticed more on low bite conditions, the car will feel tailier on exits.
this is very true
Old 08-14-2006, 10:57 PM   #5795
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Aight... I have memorized this. One question. What effect does it do on the car lowering/highering the rollcenter on the front/back?
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 08-15-2006, 12:34 AM   #5796
asw7576's Avatar
Theoritically lower RC should make your car roll less and vice versa.
Lower RC is theoritically correct for very high grip condition. It makes your car slide but not traction roll at the limit point.
However, reality is different story than theory ( textbook ). Different cars react differently to RC setting. For examples. My MTX3 suddenly can be driven more agressively after using C rear block from A. On the other hand, my MTX4 is going from B to A to relax a bit.
Always use basic setup as starting point before you fine tune the setting to your like.
Old 08-15-2006, 10:59 AM   #5797
SalvadoriRacing's Avatar
Send a message via MSN to SalvadoriRacing Send a message via Skype™ to SalvadoriRacing
HIGHER roll center makes the car roll less...........
the car is more responsive altough less traction is generated.........
LOWER roll center makes your car roll more........
the car steers so smoothly, more grip is generated but the slowly steering response makes the car lazy to get in the turn and to change direction........
Salvadori Racing
www.salvadoriracing.com.br
O.S. Engines - KM RACING - CONTACT TYRES - SAVOX - LRP - ARC | Blitz | Titan
SalvadoriRacing is offline   Reply With Quote
Old 08-15-2006, 11:32 AM   #5798
Riketsu's Avatar
Thanks guys. I think i got it.
Old 08-15-2006, 12:04 PM   #5799
asw7576's Avatar
Yes, you are right. I remember now Sorry Riketsu.
Old 08-15-2006, 07:58 PM   #5800
SuPeR's Avatar
Originally Posted by kidDynomite
Try these:
- flat front sway / stock rear sway
- 37s all around / 2.3-3mm split (depending on race length)
- 50k front diff / 10-20k rear diff
(if it's loose go 30k / 10k)
- Caster clips all in back of front arm
- +.5mm shim under front arm
- try 500 wt oil in front first / then maybe purple springs in front / then purples all around
- you may even try standing up all shocks one hole or at least the rears
- 1.5-2mm droop over ride height in front / 2-4mm droop over ride height rear
- ride height 1mm higher in the rear
- B block rear lower arms
- .5-1 degree toe out front
- 2-2.5 degrees toe in rear (to much rear toe will make your car push more on low grip tracks)
I would experiment with these things one at a time. That way you know what's happening with each change. With your track conditions, you want the car to roll more than normal. Hope some of these help, good luck!
Yeah I will try all the necessary bits and pieces to get the car better and yes I do need that good luck more than anything right now! Thank you
Car: Kyosho RRR EVO2
Engine: OSSPEED VERSION 1
Nickname: The B KING!!!
SuPeR is offline   Reply With Quote
Old 08-16-2006, 09:36 AM   #5801
jhigga15's Avatar
I am still having a hard time getting the clutch spring fitted, any suggestions?
Old 08-16-2006, 10:19 AM   #5802
Osiris 75's Avatar
Trader Rating: 17 (100%+)
maybe use some pliers first to push down the spring to relieve some of the tension, then try to turn the nut...
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS
RC TARGET/CAPRICORN USA / REFLEX RACING / ULTI TIRES
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old 08-16-2006, 01:38 PM   #5803
asw7576's Avatar
You need special tools to do that. Mugen has it ( read the manual for the tool number ) or go to Ace Hardware and find special plier ( long nose with cylindrical tip ).
Old 08-16-2006, 03:05 PM   #5804
Corse-R's Avatar
Better to get the Mugen clutch adjustment tool, much cleaner and doesn't marrs the nut.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 08-16-2006, 03:32 PM   #5805
AMGRacer's Avatar
Follow up report on the Pro-Spec brake disc. Checked the disc and surrounding plastic areas for wear, none found. As stated before I slightly rotated the carb to provide a little more clearance and after quite a lot of running there were no marks on the back of the carb. Verdict, it fits fine unmodified with my N12LL3 motor with the slight carb rotation. Brake force was not particularly any greater, but I suspect that the bigger brake disc will provide less overheating. It added quite a lot of rotating mass, 13g vs 6g for the old disc.
AMGRacer is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
