Old 08-08-2006, 10:18 PM   #5716
Sandra's Avatar
Originally Posted by wallyedmonds
cool so there here now lol, thats u.s bucks eh
Yes sir that is USD.
Sandra is offline   Reply With Quote
Old 08-08-2006, 10:20 PM   #5717
racer-oZ's Avatar
R/C Tech Charter Subscriber
ok... did some reverse math and came up with internal drive of 2.1585
racer-oZ is offline   Reply With Quote
Old 08-09-2006, 03:17 AM   #5718
wallyedmonds's Avatar
i dono how to do this, i just use the mugen gear chart and run and see what works.
wallyedmonds is offline   Reply With Quote
Old 08-09-2006, 06:00 AM   #5719
Default scott
hey scott how did u do at the glc?
isuzuguy is offline   Reply With Quote
Old 08-09-2006, 06:47 AM   #5720
Trader Rating: 15 (100%+)
Originally Posted by itchy b
do they ship to australia??
which countries eastern standard time?
it's 12;55pm here
cheers
joe
We are right beside, Washington DC USA
Same time zone as the eastern seaboard in the USA.
THE DOCTOR is offline   Reply With Quote
Old 08-09-2006, 07:54 AM   #5721
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
Not good. I ran out of gas or had to pit in 4 of my 5 qual runs. The one I did not run out of gas, I had issues with the quality of my driving and some traffic. I ended up in the B-main. In the main, my engine would not start so I ended up with less than a minute of warmup which proved to be an issue as well. We were not able to get the engine tuned properly so the engine stalled on my first pit stop. A few mins after my first stop I popped a camber link off and the engine also stalled again. We got both of those issues fixed but it was of course way too late to try and make up 4 laps so I rode around the track knowing I was going to be marshalling the next race, and not racing. Overall I had a lot of fun and got to see some people that I don't get to see too often and that is what it is all about.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 08-09-2006, 08:35 AM   #5722
YBSLOW's Avatar
There is no way you are up this early? You must not have gone to bed yet?
YBSLOW Racing
RC Target - Capricorn
HOTRACE Tyres, Tru Source, Fantom
POWER MASTER Fuel, 2mm Designs
Protoform Bodies, Avid Bearings, AMR Engines
YBSLOW is online now   Reply With Quote
Old 08-09-2006, 10:58 AM   #5723
Seisick's Avatar
i'M ABOUT TO REPLACE MY YELLOW CLUTCH SHOE FOR A NEW ONE, IT HAD OVER 10 HOURS RACING, AND THE BELL IS ABOUT TO BE TOUCHING THE PLATE, HAS ANY0NE TRIED TO USE SHIMS BETWEEN THE PLATE AND THE SHOE, IN ORDER GAIN A FEW 0.03-5mms THEREFORE, HAVING MORE LIFE ON THE SHOE?
I HAVE ACCESS TO 3X4X0.2MM SHIMS AND IM' ALSO GOING TO TRYI A LARGE SHIM BUILT THAT WILL BE SEATED ON THE ENTIRE PLATE.WITH A THICKNESS OF ABOUT 0.3-05MM
INPUTS APPRECIATED
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 08-09-2006, 03:53 PM   #5724
INPUTS APPRECIATED
just run a new shoe dont start shiming a used up shoe,its not worth the tires you will run and youll just get pissed off. whats a shoe $10.00,i run a new one every 2 weeks and a spring too,your cluch is the hart of the car if it dont work right nothing works right and you may hurt the motor too.
Old 08-09-2006, 07:35 PM   #5725
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to rcfoolz
I can attest to what Wallyedmonds sais. I just came back from the GLC. The track there is a great place to test your clutch. I had a hard time getting the clutch settup by myself. I actualy didn't know what I was doing till I was told by a great person from Canada what I was doing wrong. I had my engines comeing in at 360 and 365, two runs back to back! Engine now is excellent after setting the clutch properly. Shoe and spring are key and adjustment of them is even more important!
Am I going back racing?...Hmmm.. Not anytime soon... But soon enough.
rcfoolz is offline   Reply With Quote
Old 08-10-2006, 01:00 AM   #5726
asw7576's Avatar
INPUTS APPRECIATED
Yes, I do that with the rubber gasket for rear diff and cut it into four pieces. I put them on all four pins ( use the hole provided on the gasket ). I do that since 2005. Always finish the race. I race at least once a month.
Yes, you can save money by doing that.
Old 08-10-2006, 05:42 AM   #5727
shimming under the shoe is probably not the best way to go. Shoe don't just wear in depth, it also wear on an angle. If you look closer, the ring that wears agains the bell is wider as the shoe wears.
If you do shim it, I would suggest you glue the gasket on the plate. As the shoe moved, the gasket could moved and jam the clutch!
twoo is offline   Reply With Quote
Old 08-10-2006, 07:55 AM   #5728
Seisick's Avatar
asw, do you glue them? nice idea since using a metal shim means more weigth,the gasket could do the same but with less rotating mass.
twoo, i agree that the shoe wears on an angle, as the shoe wears on its contact point, more gap between the shoe and the bell right?therefore this gap (adjusted with shims between nut and first inner bearing) should be checked every while. I could say that the shoes are designed to provide the best grip 'til they wear, but if I can a few practice weekends from using the shims on used yellow shoes, then ok for practice, for racing new one of course!
wally, spending $260 a year just on shoes is no fun! I used gray shoe and super hard, but switched to yellow and ultra hard, it lasted 10 hours just the shoe, and the spring since it's designed for 1/8 will last more than the super hard for sure
thanks for the inputs
I'd like to share a tip, to prevent wear of the chassis on the fronT and rear I use 2 zip ties, my chassis is like new and I chage the zip ties every 30 minutes racing, the ties go around the bumper and the front before the blade bar, and in the rear around the 2 holes of the rear arm mount and the chassis, beware the lock itself should not be on the bottom but hidden. (I now can use for practice very small foams with a higher gearing with no fear of wearing the chassis)
happy racing
HobbymaniA
GoT MuGeN?
Old 08-10-2006, 07:58 AM   #5729
Osiris 75's Avatar
Trader Rating: 17 (100%+)
happy racing
Do you have a picture you can post?
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS
RC TARGET/CAPRICORN USA / REFLEX RACING / ULTI TIRES
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old 08-10-2006, 12:40 PM   #5730
Osiris 75's Avatar
Need some ceramic clutch bearings, know where I can get some for a good price?
Chris Kemper
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
