Old 08-01-2006, 04:15 AM   #5626
AMGRacer's Avatar
Originally Posted by Slo-MTX4
I am moving there at the end of november so i miss the season at brendale. How did you end up with your Sirio? I know the old importer has caused a bit of trouble. But the new guys have been great so far have had all the parts we needed in stock and actually run out of some stuff which is understandable after the drought. We will definatly have to catch up. Do you still race at brendale very much?
I ended up getting screwed royal on my EVO 2. Never got a crank and had to fork out $110 for a new one. Needless to say I am not a huge Sirio fan now.
Yeah I get out to Brendale a fair bit, let me know when you are coming down and I will come on over.........
AMGRacer is offline   Reply With Quote
Old 08-01-2006, 10:39 AM   #5627
Arushmen's Avatar
Default On line manuals
Hi, the mtx4 on line manuals, Where it is?
I canīt find it
Thanks in advance
XB9 x 2
http://txvzla.blogspot.com/
Arushmen is offline   Reply With Quote
Old 08-01-2006, 01:14 PM   #5628
Arushmen's Avatar
Default More simple
What are the number of teeth of mtx4's pulleys:
rear diff pulley-brake pulley-rear side pulley-front side pulley-front center pulley-front diff pulley?
Thanks again
XB9 x 2
Old 08-01-2006, 02:32 PM   #5629
asw7576's Avatar
C rear block = high roll center right ?
I find it is very difficult to insert the hinge pin when C rear block in place.
Old 08-02-2006, 02:35 PM   #5630
wallyedmonds's Avatar
yes and its a bit hard just play with it
wallyedmonds is offline   Reply With Quote
Old 08-02-2006, 06:22 PM   #5631
GrandeGixxer's Avatar
Trader Rating: 15 (100%+)
Wally, I don't think that came out right!
Joe Cude
Mugen MBX-7R Mugen MTX-6R Mugen MTC-1 Mugen MRX-6 Mugen MST-1 Tamiya Euro Truck
GrandeGixxer is offline   Reply With Quote
Old 08-02-2006, 07:06 PM   #5632
LMGDAO ya i think your right
Old 08-02-2006, 10:16 PM   #5633
Chris West's Avatar
Send a message via MSN to Chris West
MUGEN SEIKI | NINJA | SANWA
Chris West is offline   Reply With Quote
Old 08-02-2006, 11:22 PM   #5634
asw7576's Avatar
LMGDAO = what ?
What do you suggest in regards to A,B,C rear block for losing rear grip ( spin 180 degree ) at slow corner. It happens only when I enter slow corner off throttle. My friend told me is the track due to dust and no VHT. I'm using B rear block. Should I switch to A or C ? BTW, C is impossible to perform because the hinge pin touch the rear diff
http://www.rctech.net/forum/attachme...hmentid=157021
Old 08-03-2006, 12:51 AM   #5635
Send a message via Yahoo to speedy100
LMGDAO = what ?
it looks like your track is very low traction. To rectify the issue, you may try 35 shore rear to gain more traction and use softer spring, i think the light blue comes with the box kit. If it does not improve, you may try to disconnect the rear sway bar.......this is what I would do in low traction
speedy100 is offline   Reply With Quote
Old 08-03-2006, 01:00 AM   #5636
Default motor chocie
I am looking for a back up motor but i do not know where I should go with...I am runing the TZ3 and it is very impressive.....however, I would like to try something new other than OS....I also have the Max tuned but it just a bit faster than TZ3. I have nightmare with the siro with the broken crankshaft. Does anyone run the stock novarossi ? I would apprecaite it if you guys could give me some info in the motor choice.......thank you.
Old 08-03-2006, 01:10 AM   #5637
itchy b's Avatar
LMGDAO = what ?
for low traction track i had a similar problem with rear grip.
once i tried running the car without the rear swaybar and the b block the car hooked up a lot better into and out of the corners
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 08-03-2006, 01:45 AM   #5638
asw7576's Avatar
Thanks. I never use front and rear sway bars in my car. Here was my car set up :
Front :
Tires : 37
Sway bar : None
Camber : 3 and 3 degree
Downstop : 0
Springs : Purple
Trackwidth: 200 mm
Upper Link Position : No shim
Suspension Hole Position : no. 2 (middle)
Steering Ackerman : C
Rear :
Tires : 37
Sway bar : None
Camber : 4.5L and 4R degree
Downstop : 4
Springs : Purple
Trackwidth: 199 mm
Upper Link Position : lowest hole inside and 1mm shim on rear upright
Suspension Hole Position : no. 4 (middle)
Rear Block Position : B (middle).
Am I correct to switch to A rear block susp. ?
( It's really confusing after reading Hudy T2 setup book about Highest vs Lowest Roll Center ).
Old 08-03-2006, 03:25 AM   #5639
LMGDAO = what ?
im useing c now (arms at the highest point) and its fine, if the track is slippery than the car will slid out no mater what you do.but on a big track i would put it to B,upper link inside to the highest point and 2mm on the outer to start.and at the front upper start at 1mm the shocks rear down to 4th hole 400 oil light blue springs the front 400 oil 1.2x1 pistons and mid hole,drop 5 at the rear and 1 at the front if you have a mugen chassis. oh and lmgdao is like LOL
Old 08-03-2006, 04:33 AM   #5640
asw7576's Avatar
Thanks wallyedmonds,
I guess I try next time when the track is clean.
I might as well try A and B rear block to feel the different.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
