Old 07-30-2006, 03:04 PM   #5596
asw7576's Avatar
Just a little question.
Today I play with my MTX4 and the track condition is slippery due to dust and no VHT.
My Q : everytime I want to enter slow corner Fast ( Aggresive entry ) the car turn 180 degree. At long sweeper corner the car is normal. Should I lower the rear arm position to A ( lowest ) and add 1 more shim to outside rear upper link to create more body roll thus more grip ? Am I in the right direction ?
( I don't get such problem when the track is in race condition ).
Old 07-30-2006, 03:13 PM   #5597
GrandeGixxer's Avatar
Trader Rating: 15 (100%+)
How does the car handle in the grass?
Joe Cude
Mugen MBX-7R Mugen MTX-6R Mugen MTC-1 Mugen MRX-6 Mugen MST-1 Tamiya Euro Truck
GrandeGixxer is offline   Reply With Quote
Old 07-30-2006, 03:19 PM   #5598
asw7576's Avatar
What do you mean ?
Someone will pick up the car when the car is in the grass.
Old 07-30-2006, 03:22 PM   #5599
AMGRacer's Avatar
Build is almost done, been taking my time. Another question if I may......
I noticed that my front upper arms have quite a lot of backwards and forwards play as well as a little side to side play. Lower front arms are fine. Is this normal or do I have a bad set of upper arms?
AMGRacer is offline   Reply With Quote
Old 07-30-2006, 03:25 PM   #5600
Corse-R's Avatar
Noticed when I assembled mine and tried to remove it using teflon shims from my electric days. Car handled like crap, a buddy told me to leave the play on the upper a-arms, did it and handled good.
Weird but true.. leave that play on your car.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 07-30-2006, 03:40 PM   #5601
AMGRacer's Avatar
Cant argue with that, just wanted to see if it was normal
Another question, I have a large inventory of 0 offset foam tires that I intend to use on the car. A test fit shows that fronts are OK and the rears rub the upright. I am thinking to use some 1mm shims between the hexes and the rim itself to restore the correct width front and rear. This should work OK?
Also the instructions did not mention what sort of gap there should be between the hubs and the lower arms to get the cars width correct. I assume I need to guess it, get both sides even and set the cars width by measuring ?
Old 07-30-2006, 04:16 PM   #5602
Originally Posted by asw7576
What do you mean ?
It was a joke.
Joe Cude
Old 07-30-2006, 04:45 PM   #5603
jhigga15's Avatar
I thought that was pretty funny...My car is almost done, I am waiting for the .12 Ninja. The battery plate is pretty weak, for 400+ bucks they could have included a battery carbon plate.
jhigga15 is offline   Reply With Quote
Old 07-30-2006, 06:12 PM   #5604
wassup all! I just got a mtx-4 and started building her up. I'm almost done...but I got a few questions and I hope you guys understand what I'm asking.
I've completed installing the clutch and pinion gears on the motor. However, I'm not sure if I did it correctly...as far as adjustment. My question is about the .06 ~ 1mm adjustment. Do I turn in the screw until flush with the conical piece then make the shim adjustment? And, when I do get the corrected amount of shims...do I tighten the screw all the way down tight or do I leave it flush with the conical piece? The picture below shows the parts I'm talking about. Thanks for whoevers picture that is...I saw it on a previous post.
The way I did it was made the screw flush with the conical piece...do the pull and push calculation and ended up using 3 shims...then tightened the screw all the way down. This is the first time I'm working on this type of clutch/pinion setup so I'm a little lost. Can someone please confirm I did it correctly or incorrectly?
kriptikracing is offline   Reply With Quote
Old 07-30-2006, 06:13 PM   #5605
wallyedmonds's Avatar
this is normal
wallyedmonds is offline   Reply With Quote
Old 07-30-2006, 06:17 PM   #5606
i use the tamiya wheel spacers and they work great.and yes to measuring the track width once you do it a bit its easy to do.
Old 07-30-2006, 06:46 PM   #5607
the .6 mm to 1mm adjustment is for the clutch ingagement,do this start with .8 and see how you like it, now the c0602 bearings and the bell t0723,you must get shims to go in between the two bearings so the bell dos not rub the shoe h0765 but just not dont shim to much, then do the last ajustment for the clearance of clutch
Old 07-30-2006, 07:15 PM   #5608
and one thing about striping gears that i forgot and this gos for the RRR too, if your striping gears check the rear belt and see if its to tight if the belt is to tight it will strip gears and wear out the pinions aswell.
Old 07-30-2006, 07:21 PM   #5609
Pay attention to upper plate ( where the brake lever sit ). Check for scratches underneath the plate.
Once I use MTX3 Prospec brake disc rotor and it touch the bottom and side of the upper plate. Furthermore it almost touch the carburator, so I give up using it and back to standard disc. I know the look is less fancy but it saves some weight and I don't use brake very often.
the stock one dos this to when the holes get to big.
Old 07-30-2006, 08:57 PM   #5610
Yes, the kit comes with some black plastic spacers to use with the 0 offset rims.
THE DOCTOR is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
