Old 07-28-2006, 11:31 AM   #5566
Corse-R's Avatar
Originally Posted by Riketsu
I just want the car to be faster on curves and have more steering on-throttle. I have done some things to get more steering i.e. 198mm on front, 199mm rear. 2mm front upper arm spacers, and 2mm rear upper right. I want to know, which other places can I change so the car steers without going into oversteer. I think I need more entering steering...
Try reducing a little the caster.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 07-28-2006, 02:02 PM   #5567
Originally Posted by ira
If you want more steering entering a corner try the outside hole on your front shock tower.
So does standing the shocks give you more side bite?
look is offline   Reply With Quote
Old 07-28-2006, 02:29 PM   #5568
ira
ira's Avatar
Trader Rating: 18 (100%+)
The front shocks.
No, it will give you more initial turn in with a little sacrifice of mid corner side bite. But you can stand the rear shocks in the fourth hole from the bottom to let the car rotate mid corner.
RC AMERICA, XRAY, FUTABA, O.S. ENGINES, BYRON FUELS, SPEEDWORLD RACEWAY, HOBBICO, MATRIX TIRES...
ira is offline   Reply With Quote
Old 07-28-2006, 05:31 PM   #5569
GrandeGixxer's Avatar
Trader Rating: 15 (100%+)
Ira, I see you are posting a lot more these days, Are you bored?
Joe Cude
Mugen MBX-7R Mugen MTX-6R Mugen MTC-1 Mugen MRX-6 Mugen MST-1 Tamiya Euro Truck
GrandeGixxer is offline   Reply With Quote
Old 07-28-2006, 09:43 PM   #5570
wallyedmonds's Avatar
you want to balance the front and rear just like you run the same shor tires front and rear, the split in tire size is mostly for wear and if you run overdrive i dont run overdrive cuz it hurts the belts i found,but i do split the size by 2mm this may diff from track to track,you want the tires to come off after a run the same size or the front 1mm less than the rear,if the front tires are bigger you will have push,the goal is to get the car to point and roll into the turn with speed and not to slide,the car has to roll side to side and thats roll center you just got to fined the balance,
wallyedmonds is offline   Reply With Quote
Old 07-28-2006, 10:55 PM   #5571
kidDynomite's Avatar
The front shocks.
Hmmm, sounds like a set up we used recently on cheesehead territory.
Yeah, this worked great on tracks where everyone and their dogs couldn't get bite.
kidDynomite is offline   Reply With Quote
Old 07-28-2006, 11:04 PM   #5572
Joe, he's just trying to relieve himself before he ends up exploding all over the new track, . He posts in spurts
Old 07-28-2006, 11:17 PM   #5573
Old 07-29-2006, 12:58 AM   #5574
AMGRacer's Avatar
I am building my MTX4 and when assembling the brake disc onto the carrier I noticed that there is no play, it is TIGHT. Is this normal?
AMGRacer is offline   Reply With Quote
Old 07-29-2006, 01:37 AM   #5575
asw7576's Avatar
The elongated holes go to bottom.
The best way to get free movement is to sand blast the screws where the plates sit. Or buy G4S brake plate screws.
Old 07-29-2006, 03:29 AM   #5576
AMGRacer's Avatar
Sorry I explained badly. There is a carrier with 3 posts that connects to the main shaft. The brake disc fits over the 3 posts. The fit of the brake on the posts is ultra tight. Is that normal?
Old 07-29-2006, 03:32 AM   #5577
Chris West's Avatar
Send a message via MSN to Chris West
just needs abit of running in, as long as its straight its ok mine was like that for a bit aswell, if your really worried file a bit out of the holes but dont take too much off
MUGEN SEIKI | NINJA | SANWA
Chris West is offline   Reply With Quote
Old 07-29-2006, 04:01 AM   #5578
asw7576's Avatar
Don't you worry....., after few tanks, the brake disc should wobble freely.
Most importantly the disc should rotate forward easy. It needs alignment from brake pads. 2mm - 2.5mm between plates.
Old 07-29-2006, 04:45 AM   #5579
itchy b's Avatar
the brake disc will loosen up over time, no need to worry
good to see you have chosen a mugen AMG and resisted the darkside
remember; always beware of the darkside kyosho
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 07-29-2006, 05:58 AM   #5580
you have too file the disc to make play,i found you have to do this to make the brake work properly,alot of play is ok cuz the pads will guide the disc and the axle to
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
