Old 07-22-2006, 03:50 AM   #5491
Originally Posted by Nitro$junkie
yes and shims under rear camber link as well
Nitro$junkie, too much XXXX (Queensland beer) mate. Some of the info you have given TomB is incorrect. Removing shims from underneath the upper front arms is RAISING the roll centre
Rody is offline   Reply With Quote
Old 07-22-2006, 04:31 AM   #5492
Nitro$junkie's Avatar
Send a message via MSN to Nitro$junkie
yep thats right less shims raises the RC
and more shims lowers the RC
who knows what i was thinking this morning
Futaba
Mugen
Novarossi
Byron's
http://www.hospitalrecords.com
Nitro$junkie is offline   Reply With Quote
Old 07-22-2006, 05:28 AM   #5493
wallyedmonds's Avatar
has any one had problems with the 3racing 2speed all af a sudden first starts sliping its a real pain in the ass what i did to fix the problem is shim up the screw and washer as well as lock tight the spacer first gear sits on other wise it would slip on the 2speed shaft
my problem is the spacer inbetween the 1st gear and the 2nd gear, it wears out and makes the 1st gear wobaly
wallyedmonds is offline   Reply With Quote
Old 07-22-2006, 09:34 AM   #5494
Roger's Avatar
its from the 1/10 all in one set up station not the xray electric car
read when i posted that 12:30 in the morning i was wasted just got home from the clubs
I have the xray T2 set-up book and the wording is exactly the same. Since both set-up manuals are produced from hudy, everything in regards to suspension dynamics and set-up are gonna be in the same context word for word.
http://nitrokb.netne.net/profiles/RogerSerafin.html
Roger is offline   Reply With Quote
Old 07-22-2006, 05:53 PM   #5495
jhigga15's Avatar
I just got my MTX-4 home today...any tips I should know?
jhigga15 is offline   Reply With Quote
Old 07-22-2006, 06:37 PM   #5496
madbeats's Avatar
Enjoy Ittttttttttttttttttt
Serpent 966/720 Mugen MTX4R Xray NT1-Mugen MTX-4 Knack R conversion Hong Nor X1CR
madbeats is offline   Reply With Quote
Old 07-23-2006, 05:21 PM   #5497
Trader Rating: 15 (100%+)
Originally Posted by Roger
Man, this sounds all too familiar. I've read this information somewhere. Oh, let me guess, this is from the set-up book for the xray electric car. Man, you typed all this exactly what the manual reads. Oh, by the way, there is NO WAY (unless modified) you can change the wheelbase of a MTX-4 or 3. Track width, you can change ( 198,199,200mm ), not wheelbase. Trust me, i've spoken to Swauger about this afew times and I had to modify the rear for a shorter wheelbase for my MTX-4.
"the way you adjust the wheelbase is the c spacers that clip on the actual front upper hinge pin it self "
Could you explain this to us. The " C spacer " (or caster clips) that you are reffering changes the caster, NOT THE WHEELBASE !! "
Now, on a xray FK05 or a T2, you can change the wheel base in the REAR ONLY !!!!
You can file the arms a little to be able to put the little clips that you use to change the caster in front or in the rear of the arms to change the wheel base.
THE DOCTOR is offline   Reply With Quote
Old 07-24-2006, 03:22 AM   #5498
you dont need to do this,but if you wont go for it,theres a guy here that did this and it works ok.
Old 07-24-2006, 03:28 AM   #5499
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to rcfoolz
I laugh I did this for a short small track, but, I got better results by learning to set the car up.
Am I going back racing?...Hmmm.. Not anytime soon... But soon enough.
rcfoolz is offline   Reply With Quote
Old 07-24-2006, 04:50 AM   #5500
asw7576's Avatar
Use small / technical track setup
Shorten front track width.
Old 07-24-2006, 08:37 AM   #5501
jhigga15's Avatar
Who makes good hop-ups for the MTX-4? I see that 3 racing has a lot. I need some bling, I am thinking of covering my gas tank with pink rinestones so that it matches Paris' sidekick
Old 07-24-2006, 11:43 AM   #5502
kidDynomite's Avatar
Mugen Seiki and Kawahara.
kidDynomite is offline   Reply With Quote
Old 07-24-2006, 02:32 PM   #5503
jhigga15's Avatar
Old 07-24-2006, 02:52 PM   #5504
RichChang's Avatar
Default Roll Center
This is the simple way I remember roll center in regards to the upper camber links:
more PARALLEL - lower roll center and increase roll of the car. More traction at that end of the car. Less camber change.
more ANGLED - raise roll center and less roll of the car. Less traction at that end of the car. Can use softer shock settings. More camber change
SHORTER - less traction. Car rolls less. Reacts quicker initially and less overall (REAR: more steering (but can cause rear to lift); FRONT: less steering).
LONGER - more traction. Car rolls more to outer edge of tire and gives you more side bite. Reacts slower initially but will react more. (REAR: less steering - need more camber; FRONT: more steering).
Hope that helps (and is correct. LOL!).
-Rich
RichChang is offline   Reply With Quote
Old 07-24-2006, 05:15 PM   #5505
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
-Rich
How do you change a roll center to be shorter/longer?
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
